Everything posted by madkat
[Vand] Instalatie Xenon H4
madkat replied to madkat's topic in Accesorii, alte produse si servicii auto
din pacate sunt ca si date azi trebuie sa ma vad cu omul sa i le dau - daca pica... anunt... -
Nu este un UP - doar o listare a detaliilor tehnice - am fost intrebat tot felul de chestii - la care cel mai bine raspund datele de mai zos. Btw - are de fapt 4x30w RMS A 24 bit Burr-Brown audiophile quality D/A converter is featured on this radio CD / MP3 / WMA / AAC receiver. 128 x 23 (64 colour) full dot FL display with eight tone levels and blackout. Voice-index guidance helps you locate tracks effortlessly. PhatNoise media organiser software included on CD-ROM to organise your music collection. Piano black finish front panel features the motorised SLIDE type mechanism with three step angle adjustment. Facility to add CD changer, walkman type input, accessory remote control. Can be linked to many factory-fitted remote controls and dashboard displays (requires adaptor). Radio tuner features: RDS (radio data system) & EON (extended other networks) tuner Full coverage of LW / MW / FM wavebands with 24 presets (18FM, 6MW, 6LW) Auto-memory entry feature stores preset stations Display of radio text information CD / MP3 / WMA / ACC features: Compatible with CD, MP3, WMA and AAC format files AAC compresses audio much more efficiently than the MP3 standard. Also used on the Apple iPod, Kenwood AAC compatible head units can reproduce files compressed using AAC-LC, including MPEG-4 and .m4a formats CD-R and CD-R/W compatible Voice index aids locating files on CD by reading aloud play mode and file names PhatNoise media manager software on CD-ROM to store, index and organise audio files. Includes 60 sample MP3 tracks Display of CD text when present on media Display of MP3 ID-3 tag information Discs in optional CD changer can be manually assigned names 24 bit Burr Brown D/A converter gives highest quality playback of compressed audio files L/R 0-bit muting for total silence between tracks Random track play, track repeat and intro scan functions Amplifier features: Four channel 4 x 50W max power amplifier (4 x 30W RMS) RCA auxiliary input for connecting external walkman type devices Three stereo preamplifier RCA outputs (2.5 volt) for connecting optional external amplifier Separate adjustments for bass, treble, balance and fader Loudness control System Q-EX equaliser with three control bands and six preset settings System E's optionally cuts bass for front and rear speakers at an adjustable frequency, thus improving sound quality when a separate subwoofer is in use Adjustable rear subwoofer output Built in amplifier can be turned off if external amplification is used BMS external amplifier control offers parametric EQ control of the Kenwood PS range of external amplifiers. You can also display amplifier status information such as voltage, current, temperature and fan speed on the GUI/OSD Dual-zone sound output facility Source tone memory stores equaliser settings for each source (FM radio, AM radio & CD) Other features: Peak hold spectrum analyser display Installer memory switch will return unit to a preset optimum calibration, as programmed by owner or installer 64 colour x 8 shades (128 x 23) FL dot display with display blackout switch Motorised removable front panel flips down to insert CD disc Three step front panel angle adjustment Automatic display brightness dimmer Compatible with Kenwood CD disc changers Compatible with Kenwood infra-red remote controls Will accept auxiliary input cable for Walkman type device playback though radio Compatible with Kenwood iPod interface to control, display information from and re-charge battery of Apple iPod DAB reception can be added with accessory DAB tuner Can be linked to many models of dashboard information displays and factory-fitted remote controls (requires accessory adaptor) Rotary volume controller Red or green (switchable) illuminated control buttons Complete with release keys, ISO connecting loom, full fitting and operating guide Security, warranty and insurance Removable front face with case Security code protected
Nu merge. Merge la cielo in faruri. -
Se vinde mp3-ul din dotare - Kenwood Kde ce-W 7531 scurta descriere (pe net se gasesc mult mai multe date, si mai profesional exprimate) radio am/fm cu rds 50Wx4 (22Wx4) MOS-FET 3 perechi de pre-out-uri - front/rear/subwoofer aux in control cd-changer cd-player mp3 cu DAC pe 24 biti control bass medii inalte - fiecare cu setarea frecventei de mijloc. loudness setarea crossover-ului hi/lo pe fiecare iesire, precum si pe amplificarea proprie control iesire subwoofer - inclusiv faza. fata detasabila (evident) tot felul de moduri de afisare ale displayului VFD, cel din poza fiind cel mai simplu, tot soiul de animatii etc... functionarea si aspectul sunt impecabile, vine complet cu adaptor DIN-Kenwood pretul este absolut fix 250ron sau 300 impreuna cu magazie de cd-uri audio Kenwood, cu cabluri complete. contact madkatweb@yahoo.com sau mp aici.
Datorita userului @raven84 - care dupa ce nu a ridicat coletul pe post ramburs, m-a tot amanat cu rezolvarea problemei, pierzandu-se intrun final in ceata, sunt nevoit sa pun din nou in vanzare instalatia de xenon H4 De data asta sa imi acopar costurile de transport si sa imi mai ramana d-o bere-doua... asa ca: Instatlatie xenon H4 - faza scurta/faza lunga (pe acelas bec) - cu balasturi ca in poza. Functioneaza f bine - am reverificat-o dupa ce a stat prin posta coletul mai bine de o luna. pozele sunt reale. pret - 70ron. contact mp aici sau madkatweb@yahoo.com
Efectul este foarte fain. Eu am facut la fosta Alfa - la JTD treaba asta - si urmeaza sa o fac si la V6-le actual. Cu Aluband, si tot a fost ok - si nu am avut probleme cu mirosul neplacut in masina... Iar Bora am luat-o deja complet antifonata - cu o chestie pe nume STP sau asa ceva... Downside-ul este ca, daca ceva se strica prin usa trebuie sa tai tot sau cel putin zone din anifonare, sa poti interveni...
ce pana mea faci cu cutia de ricambi originali?
la fel ca si in cazul tank-ului de cielo - astept oferte - in caz contrar zboara la ghena de gunoi...
este inca intreg - 80 ron
Se vinde un AV wireless transmitter Este vorba de un device prin intermediul caruia se poate transmite semnalul audio/video, la distanta, prin intermediul undelor radio. In plus se poate trasmite si un semnal infrarosu (de exemplu de la o telecomanda) La emitator se conecteaza iesirile unui DVD/reciever sateli/DVB/Digi etc - si la reciever se conecteaza televizorul. In plus se poate comanda recieverul, prin telecomanda acestuia din camera unde se afla televizorul - receptorul avand o celula ir, si emitaorul un led ir - transmitand semnalul ir. este marca Welltech model 40458 functioneaza excelent - are 4 canale - eu nu am avut interferente pe niciunul. Transmite in camp deschis si la 50m (mai mult nu am avut unde testa), iar in casa de la parter la mansarda peste etaj 1 (practic etaj 2). Asta am putut eu testa. Nu am avut interferente de la telefoane mobile sau wi-fi. Este complet - emitator si receptor, transformatoare, celula IR originala (inca cu scociul de pe baza nedesfacut) Pretul este de 100ron pentru pachet contact: madkatweb@yahoo.com sau 0723365781 sau mp aici
saptamana viitoare intra la disectie partea de mp3 si sursa se vor muta in alt cass oem.
La IBM/Lenovo - gamele mai scumpe - tastaturile asa sunt facute, cu "tavita" si chiar cu 1-2 scurgeri. Se sacrifica tastatura, dar scapa restul laptop-ului.
Scutul la genul asta de pozitionare a motorului/baii de ulei - ajuta exact la nimic. Pentru ca nu se poate pune distantat de motor. Ca n-ai unde. @Laurentiu - asa e - o alta dovada a retardului inginerilor italieni este ca la o utilitara, care prin definitie trebuie sa fie robusta si sa treaca fara probleme de denivelari si borduri, au facut aceeasi greseala... @Dj - in mod cert, stilo fiind propulsat de motoare de foarte inalta performanta
Problema la fiaturi nu e ca ar fi prea joase cu totul. Ci in imbecilitatea lor, proiectantii au amplasat foarte jos compartimentul motor. La stilo baia de ulei era cel mai de jos punct al masinii, mai jos decat lonjeroane, o mare prostie la clasa asta de masina. Si deasemenea indiferent de suspensie, normala sau sport - fatza era mult mai joasa decat spatele Din ce am vazut si la Bravo s-a mentinut aceasta greseala. Deh, Fiat...
pret nou 40ron
stiu astia de la beloud sa recomande CEVA?
Cielo cu o baterie decenta si cu aprinderea in stare cat de cat ok - porneste si dupa o luna de iarna la prima cheie.
Revine la vanzare un radioacestofon original de Nubira 2 - modificat prntru redare mp3 de pe SD sau USB Putere 4x20w (real dupa datasheetul integratului final) radio AM/FM control digital bass/inalte/balans/fader partea de mp3 - este un modul cu redare de pe usb (am incercat 8 gb si citeste) si sd (maxim am incercat 4 gb ca atat am avut) - montat in locul mecanicii de casetofon, cu sursa stabilizata. are telecomanda, cateva preseturi de egalizare, si volum reglabil. Practic se obtine un radio mp3 daewoo cu look si integrare OEM in bord. Se potriveste chiar si la mufa cu Nubira 1 si 2, Matiz, si Leganza. Am si adaptor mufa nubira-iso - pentru a putea fi pus pe alte masini. Asa l-am avut eu pe Cielo. Se mai pot vedea poze cu el in topicul fostei mele masini. Pretul este absolut fix 100ron. Contact: madkatweb@yahoo.com sau 0723365781 sau mp aici.
Arata bine fetele de usi - dar vorba lui Petrica - mai bine renuntai si la cartoanele din usile spate... Si inca o treaba - de ce ai astupat ventilatiile din usi? Prin ele se face evacuarea aerului din habitaclu - nu e chiar ok sa le obturezi...
Bah tu ai garaj? Ca altfel nu vad prea bine o decapotabila parcata-n strada... Distractie placuta si spor la bricolaj Vad ca ai deja climatronic - sa nu mai desfaci bordul si la asta...
Sa-ti traiasca - si sa te duca multi km! In rest - cu ce nu ma pot obisnui la masina asta - este designul (sau lipasa lui) consolei centrale. Ma mir ca il accepti venind dupa ordinea teutona din passat...
[Vand] Cauciucuri Iarna Firestone Winterhawk Dot2010 4Buc.
madkat replied to madkat's topic in Piese si subansambluri auto
Cauciucurile s-au vandut Raman jantele -
Se vinde un set de cauciucuri de iarna Firestone Winterhawk - DOT 3210 Uzura se vede in poze - sunt practic ca noi. Pretul este 500ron - nu se vand decat toate 4. Mai exista si un set de jante de table 14' - oem Skoda Fabia si similare (Polo etc) 5x100 - pret 400ron contact: madkatweb@yahoo.com sau 0723365781 sau mp aici Pt. cine ghiceste dimensiunile faci reducere?
Se vinde un incarcator pentru acumulatori AA sau AAA marca Philips impreuna cu 2 acumulatori de 2450mah. Pachetul este nou, sigilat - maxim doua luni de la achizitie. http://www.domo.ro/Gadgeturi_&_Acc_electrice/Accesorii_Electrice/Incarcatori_&_Acumulatori/Philips/Incarcator_Philips_SCB1280NBAA_slash_AAA+2_AA_2450mAh# pret (nou, nedesfacut) - 45ron contact: madkatweb@yahoo.com sau 0723365781 sau mp aici
