Everything posted by madkat
In urma upgrade-ului (tot cu IBM) se vinde una bucata IBM Thinkpad T41 - business class, carcasa cauciucata magnesium + titanium, security chip, shock mounted hard drive etc. - cu urmatoarea configuratie •Afisaj: 14.1 inches XGA TFT •Procesor: Intel Centrino Pentium M 1,5 Ghz 2MB L2 cache •Chipset: Intel •Memorie: 768MB DDRAM PC2700 / (512+256) •Maximum memorie: 2GB DDRAM •HDD: Shock Mounted IBM Hitachi Travelstar 40GB 5400RPM 8MB buffer •Accelerometer: hardul este monitorizat de un dispozitiv special (accelerometer) care, in functie de pozitia laptopului si de miscarile sesizate parcheaza capetele pentru a proteja harddiskul si implicit informatia de pe el •Unitate optica: DVD/CDRW Matsushita ultraslim bay hot-swappable - poate fi scoasa chiar si in timpul functionarii pentru intoducerea in ultraslim bay a unei a doua baterii, a unei unitati Floppy Disk, al unui al doilea hard disk etc •LAN: Intel LAN PRO10/100 •WIRELESS LAN Intel 2100 B\G with ultraconnect dual antenna (comuta “on the fly” pe antena cu cea mai buna receptie) •Infrared •Trusted Platform Module 2.0 (TPM) Secure chip •Modem: IBM integrated 56k V92 •Sound: Soundmax Integrated Digital Audio •Boxe stereo •Ultranav dual input: Touchpad + Trackpoint system •2xUSB 2.0 •2xPCMCIA •TVOUT S-Video •Iesire monitor extern - DSUB •Paralel •Headphones/Mic jacks •Microfon incorporat •Docking station port (prin docking se poate adauga si port serial) •Kensington Security Port •Iluminare tastatura Thinklight •Alimentator original IBM •Baterie Li-Ion 6 Cells green contition (healthy) autonomie minim 2 ore cu wireless on •Dimensiuni: 31.1 cm x 25.5 cm x 2.6 cm •Greutate: 2.1Kg In plus fata de configuratia originala - HDD hitachi de T43 (mai economoc si mai silentios), ecran + capac de T43 (mai luminos, si cu unghiuri mai largi - si cu antena BT incorporata), memoria (original 2x256 acum 1x256 + 1x512), cooler de T43 (mai rapid - nu ajunge peste 50grade procesorul nici in multitasking) Este in stare excelelenta - si tehnic si optic, evident fara pixeli morti sau alte defecte Pretul este de 900ron foarte putin negociabil Se poate vedea in Bucuresti - o sa pun si poze reale. contact: 0723 365 781 sau madkatweb@yahoo.com sau mp aici
Deci sa integ si eu - nu de alta dar ma intereseaza si pe mine un rand de distantieri de pana in 10mm Cum ai facut - de unde i-ai luat exact - si dpdv prezonaj vad ca merg pe multe variante - insa diamtrul gaurii din centru cat este? si nu imi dau seama - au umeras de centrare a jantei?
Sunt convins ca e neplacut sa ai masina fara geamuri si fara suspensii.
Un update cu piesele disponibile: ecran T4x 14' complet cu balamale, antene WI-FI si BT, in stare excelenta inclusiv panglica - nici o bucata momentan memorie RAM SODIMM PC2 5300 - 2x512mb - 30ron bucata palmrest cu touchpad R5x (touchpadul compatibil si cu R5x) - 50ron elemente de carcasa de R5x sau T4x cu ecrane de 15' - preturi variaza in functie de piesa dorita elemente principale de carcasa de T4x ecran 14' nu mai am nimic momentan - doar capacele de ram, hdd, grile etc. ansambluri cooler/radiator/heatpipe de Thinkpad T4x - excelente, silentioase - 60ron diverse alte componente - elemente de carcasa, difuzoare, capace de RAM, palmrest-uri, conectori, caddy de HDD, custi pcmcia, toate pentru IBM T4x, R5x sau T30 sau alte modele de laptop oricum intrebati - chiar daca nu gasiti in lista - si ne intelegem poze la cerere
Distanta intre electrozi intr-adevar este foarte importanta - nu este rau numai distanta prea mare ci si prea mica ... verificat pe propria "piele" in cazul al doilea
Bravo! - vezi - motivatie iti trebuia cine stie, poate si ledurile alea pe la butoane ... pana da frigul sa inghete mana pe circuite
Ala e meniul - poti sa setezi doar frecventa pana la care sa coboare difurile masinii si in rest tot felul de prostii in rest - loudness modelul asta NU ARE - vezi pe net si pdf-ul cu manualul de utilizare... are egalizator pe trei benzi si niscai preseturi customizabile - atat...
Se vinde una bucata Mp3 player portabil E-Boda Wygo Capacitate 1Gb, functionare cu o baterie AAA (R03), autonomie aproximativ 6-8 ore Este ca nou, foarte putin folosit (fara nici o urma de uzura) - l-am luat exclusiv pentru a-l folosi cu cassul original al masinii, merge excelent in combinatia asta - doar ca vreau ceva cu memorie mai mare (minim 2 gb). Castile sunt practic neatinse. poza este reala. toate accesoriile - cutie, casti originale, manual de utilizare, cd drivere pentru Win98 sau Mac pret 40ron contact: madkatweb@yahoo.com sau 0723 365 781 sau mp aici
E o prostie 414-le asta... am avut si eu pe cielo - si am renuntat la el in cateva luni - la prima auditie suna bine, dar in timp, lipsa "loudness-ului" m-a facut sa renunt la el. Acel buton este un comutator rotativ "fara sfarsit" - nu stiu exact in romana - dar in engleza se cheama "rotary encoder" cu switch pe axul central pentru on/off - se gaseste chiar si in sony asta - nu e mare filozofie... se gaseste pe la magazinele de componente electronice - sau in vreo fata de casetofon de "dezmembrat"
eu la 20.00 abia eram pe mihaibravu pe linia de tramvai in drum spre intalnire...
In caz ca te razgandesti - mai ai un NU si de la mine pentru leduri... in caz ca lea-i cumparat deja - le poti utiliza ca si lumina la picioare pasager - legata la plafoniera
hai ca sa nu fii singur... incerc si eu pe la un 8 si un pic sa ajung
madkat replied to piese daewoo's topic in Piese si subansambluri auto
ceasul de bord (cel de indica ora) de cielo - este? si la ce bani? multumesc si astept semn cat mai repede -
Ceasul de pe bord (al de indica ora) - este in stare buna? si la ce pret? multumesc si astept raspuns cat mai repede
Probleme cu ştergătoarele
madkat replied to BlueBear's topic in Probleme tehnice Cielo, Nubira, Espero, Leganza
Asteptam cu nerabdare schema - si eu aveam in minte sa fac modificarea asta dar nu are rost sa reinventez apa calda. In legatura cu supapa minune - se gaseste la masinile cu stergator la luneta - dar cu rezervor de lichid coimun cu cel de parbriz - tocmai pentru ca sa nu se goleasca furtunelul de 3-4 metri lungime de la motor la haion asta ca tema de -
Inca un GLE argintiu ... frumos! ce ai avut nevoie sa deschizi capota la Balea? nu de alta dar parca am un deja vu - cand m-a lasat pe mine anul trecut p-acolo pompa de ambreiaj in rest - incalt-o cu niste jante - o sa se schimbe mult masina... nici nu e nevoie sa ii mai faci altceva
posibil cel mai urat pejo ever... interesant conceptul de usi glisante, dar ... in rest, daca iti faci treaba cu ea e ok
am vazut mai multe cazuri de G4 cu ALH-ul de 90 cp cu ambreiajul picat in jur de 80k km... si probleme pe la planetare... sper sa nu fie si cazul tau despre cass - am vazut pe vwforum un beta d-asta ca al tau la sh la un pret destul de ok - asta daca nu crezi ca ar fi momentul sa treci pe un mp3 civilizat - e pacat de boxele masinii sa ramai cu cassul... in rest - simpatic utilajul, mi-a placut mereu G4, e o masina foarte echilibrata - iar dieselul oldschool e un motor excelent - doar sa nu il subturezi
pune te rog niste poze sa vedem culoarea - m-ar interesa niste repere de caroserie daca sunt pe culoarea masinii mele (vezi avatar)
Se cheama deformare controlata astea noi n-au fagurele de sub bara si structura pe care o are cielo - pentru a prelua energia impactului la cielo simti impactul in toata caroseria si ramane intreg cat de cat este ok la impacturi la viteze mici sau mai usoare - pleci cu masina pe roti si destul de "undamaged" - dar la viteze mari este un dezavantaj...
treaba asta cu tabla groasa - e fix ca in topicul asta: http://www.gmclub.ro/forum/index.php?showtopic=29558 scuze de offtopic, dar cam asta e realitatea
Mult succes - la cum te-am vazut, sunt convins ca o sa iasa fain masina usile de ce le schimbi? rugina beyond repair? de trapa te inteleg un pic... este sistemul care se gaseste si la 156, am demontat cu un prieten o singura data - pentru ca ploua in masina, si dupa ce am dat toata magaoaia jos, ne-am dat seama ca era intepat unul din cele 4 furtunele de scurgere a apei (in capetele sinelor) dar pentru vopsire poate ar merita efortul ...
@velican ai imbacsit mecanismul prea mult... cu unsori si alte chestii o sa caut motorasul de antena pe care il am dintr-o d-aia de hypermarchet dezmembrata - si daca il gasesc ti-l fac cadou edit: @dark - a trecut un an de la ultima "maitenance" si antena mea rezista
sticarele si mutzunachii sunt de mare efect. bravo!
G9 este cam la limita dintre sapuniera si bridge... cu toate astea, nu vreau sa intru in polemici, dar n-as da niciodata S3IS-ul meu cu cei 6mp amarati pe un G9...
