ilovat
About ilovat
  • Birthday 02/15/1976
  • Yahoo
    ion.hirsovescu
    Tirgu Jiu
    cielo
    GJ-05-HHH
ilovat's Achievements
  1. am fost astazi la reprezentanta iar un super mecanic mi-a rezolvat problema:mufele de la calculator cocsasera,a dat cu un spray de contact si totul a mers ca uns!!!!!!!!!!!!!!!
  2. BUNA,AM SI EU O PROBLEMA GRAVA.AM UN CIELO GLE DIN 1995,IL AM DE 4 ANI,NU AM AVUT PROBLEME CU EL PANA IERI!IN URMA CU 3 ZILE AM FOST LA PESTE PE O PLOAIE TORENTIALA,AM TRECUT PRIN NISTE BALTI CU EL SI DINTR-O DATA AM SIMTIT CA CEVA NU ESTE IN REGULA,AM TRAS PE DREAPTA IAR CAND AM SCOS DIN VITEZA AM VAZUT CA MASINA ERA TURATA IN 2100 DE TURE SI MI SE APRINSESE UN BEC GALBEN SUB FORMA DE POMPA.M-AM UITAT SA NU FIE SARIT VRE-UN FURTUNAS DAR TOTUL ERA LA LOCUL LUI.CAND AM INTRAT IN MASINA AM CONSTATAT CA APARUSE UN TACANIT LA TABLOUL ELECTRIC.AM MERS ASA PANA IN ORAS,AM OPRIT-O SI PORNIT-O DE 4 ORI ,AM AJUNS ACASA NU SE MAI AUZEA NIMIC!MERSUL PRIN ORAS A FOST CAM 1 ORA,TOT CU TUROMETRUL IN 2100!ACASA AM OPRIT-O SI PORNIT-O DE 2 ORI,TOTUL MI S-A PARUT IN REGULA.IERI INSA CAND AM INCERCAT SA PORNESC,NIMIC,NICI MACAR O TENTATIVA,MOTORUL SE INVARTE DAR NU PORNESTE.AZI AM INCERCAT DIN NOU,AM DESFACUT IN FATA LA RAMPA ALIMENTAREA,POMPA MERGE,ARE DEBIT DAR MASINA TOT NU PORNESTE.AM INCERCAT SI IMPINSA,DA SA O IA DAR MOARE.VA ROG DACA POATE CINEVA SA MA AJUTE,AZI TREBUIA SA I-MI SCOT FIICA LA HERCULANE SI NU AM CU CE SA AJUNG! azi am adus un mecanic,a testat fisele,bobina,cureaua,pompa de benzina,electromotorul invarte dar nu ajunge benzina la bujii!pompa a testato si scoate peste 2 litri.vreo idee,vreun sfat? am uitat sa spun ca bujiiile sunt in regula ,dau scanteie.el a zis sa chem un electrician ca nu ajunge curent la injectori.
  3. salut,am si eu o problema.am un cielo95 monocama pe care il detin de 4 ani.in urma cu trei zile am oprit-o in parcare normal.dimineata nu a mai vrut sa porneasca!am verificat bujiile,delcoul,pompa de benzina,toate par in regula!de trei zile ma chinui si nu ii dau de cap.am adus si un specialist astazi ,a verificat si mi-a spus ca nu deschid injectorii,nu ajunge curent la ei!are cineva vreo sugestie?a,si tot el mi-a spus ca pun degeaba testerul ca la mine nu indica nimic.are cineva vreo sugestie?
