monitor
Gender
Location
Din
Auto
TICO
Model
sx
An
1999
monitor's Achievements
Care sunt pasi pentru a scoate alteranatorul pe jos?
Ce amortizoare recomandati pentru o calatorie mai confortabia?
Kit geamuri electrice + consola cat costa ? 0721891750 cosmote. Incalzire scaune fata a montat cineva ?
Daca postai mai devreme schimbam si distantierul Sper s nu am probleme din cauza asta .
Nu putem comanda din Ungaria ?
Ce spuneti de un Tico offroad ?
KIT rulmenti SKF roata fata :VKBA 3797 KIT rulmenti SKF roata spate :VKBA 1931
Am achizitionat si eu rulmentii spate pentru Ticozaurul meu. Inscriptie rulment mare -SKF EXPLORER 04 13 040H 6205 2RSH/C3 CHINA Inscriptie rulment mic -SKF EXPLORER 04 21 311G 6204 2RSH/C3 CHINA Unde gasesc un service pentru un montaj cu presa si blandete ? Am cautat vaselina adecvata pentru rulmentii de mai sus si am gasit urmatoarele variante : 1 SKF LGMT 2 - for General purpose Generally use if: Speed = M, Temperature = M and Load = M ( mediu , medie ) SKF General Purpose Industrial and Automotive Bearing Grease SKF LGMT 2 is mineral oil based, lithium soap thickened grease with excellent thermal stability within its operating temperature range. This premium quality, general purpose grease is suitable for a wide range of industrial and automotive applications. • Excellent oxidation stability • Good mechanical stability • Excellent water resistance and rust inhibiting properties Typical applications: • Agricultural equipment • Automotive wheel bearings • Conveyors • Small electric motors • Industrial fans 2 SKF LGHP 2 for High temperature Expected bearing temperature continuously > 100 °C / 212 °F SKF High Performance, High Temperature Bearing Grease SKF LGHP 2 is a premium quality mineral oil based grease, using a modern Polyurea (di-urea) thickener. It is suitable for electric motors and similar applications. • Extremely long life at high temperatures • Wide temperature range • Excellent corrosion protection • High thermal and mechanical stability • Good start-up performance at low temperatures • Compatibility with common polyurea and lithium thickened greases • Low noise properties Typical applications: • Electric motors: Small, medium and large • Industrial fans, including high speed fans • Water pumps • Rolling bearings in textile, paper processing and drying machines • Applications with medium and high speed ball (and roller) bearings operating at medium and high temperatures • Clutch release bearings • Vertical shaft applications • Kiln trucks and rollers Nu am cumparat inca vaselina .
Nu se vad pozele Caut si eu un meserias iubitor de ticozaur Rugina,gauri micute ,zgarieturi,terosonare si vopsitorie pe bucatele s totala. Culoarea in talon " rosu-portocaliu " pe masina visiniu metalizat. Multumesc anticipat pentru sfaturi si recomandari de meseriasi.
Cat a costat distractia? Daca am nevoie de ceva garnituri gasesc acolo ? Multumesc. P.S. Maine sunt programat la domnul Costel.
Cat a costat toata operatiunea la domnul Costel? ceva piese schimbate ?
Multumesc pentru sfaturi. Am ticozaurul de pe 17-05-2011
Ce parere aveti de service-ul Daewoo din ferentari zona vadu nou ? Doresc un reglaj de tachetii si carburator . Motorul se aude ca la o masina Diesel si la relantii tremura toata masina (nu merge rotund ) . Bujii schimbate,fise schimbate,delcou schimbat,bobina este buna,pompa este noua. Daca este sarita distributia doar un dinte poate merge motorul ?
se poate copia de pe : http://protest-benzinarii.blogspot.com se gaseste in partea de sus a blogului. protest benzinarii print.doc
PROTEST BENZINARII !!!! Etapa 1 ---Fiti solidari cu noi in zilele de 17, 18 si 19 Ianuarie 2011 NU ALIMENTATI , NU INTRATI IN BENZINARII! Etapa 2 ---Fiti solidari cu noi si incepand cu data de 15 Februarie 2011 NU MAI ALIMENTATI DE LA OMV SI PETROM. „Sa alegem "aleatoriu" un distribuitor de carburant de la care sa nu mai alimentam deloc. Chiar daca ii vom "imbogati" pe ceilalti, macar vom sparge cardasia lor in ceea ce priveste pretul. In ce sens? Pai gandind in aceasta perspectiva si bineinteles daca ideea va prinde la mase, exista sansa de faliment pentru respectivul distribuitor si astfel in cele din urma ar trebuie sa scada pretul ca sa se salveze „ Sursa : M.B.Antena 3 Trimiteti acest mesaj mai departe pentru a-l citi toata tara<Dreamcatcher
