vivaldi90
    CISNADIE
    DAEWOO
    MATIZ
    sb50abv
vivaldi90's Achievements
  1. [Mai apasa odata caps lock. Nu,nu ai tensiune permanent. Firul de + vine intr-adevar de la contact,dar cel de - trece prin delco,de unde e alimentat in impulsuri. (1 impuls= o scanteie) Mersi de informatie, deci cred ca va trebui sa verific si delcoul !
  2. AM SI EU O INTREBARE DACA MA POATE AJUTA CINEVA. LA BORNELE CARE DUC IN BOBINA DE INDUCTIE, ATUNCI CAND SE PUNE CONTACTUL NU AR TREBUI SA AVEM TENSIUNE(CA LA DACIE)? AM PROBLEME CU MATIZUL, MI S-A OPRIT DINTR-O DATA IN MERS SI NU M AI PORNESTE. AM INCERCAT LA POMPA DE BENZINA, FILTRU DE BENZINA SI IN CELE DIN URMA AM OBSERVAT CA NU DA TOT TIMPU SCANTEIE SI ASA AM AJUNS LA CELE 2 FIRE CARE INTRA IN BOBINA D INDUCTIE.DACA PUN CONTACTUL SI IAU UNUL DIN ACESTE 2 FIRE(PLUSUL) SI CU O MASA AM TENSIUNE DAR INTRE CELE 2 FIRE NU ESTE. NU AR TREBUI SA AM TENSIUNE INTRE ACESTE 2 FIRE CARE DUC LA BONINA CAND ESTE PUS CONTACTUL?
