miechomiecho
    Lublin - Poland
    Tico SX
Recent Profile Visitors
560 profile views
miechomiecho's Achievements
  1. I miss the heat shield 14130A78B12-000. I have no catalytic exhaust manifold. Someone had posted: Could this be the solution to my problem? Is the replacement of diodes D3 and D4 can help?
  2. Replacing the resistor R5 to 5.6 ohm unfortunately did not help. Air still does not work on the first and third fan speed. Any suggestions?
  3. Hello! I have installed a new air conditioning in my tico. Unfortunately, I have a problem. Air conditioning only works on the second run. The I and III compressor stops running. Is the replacement resistor R5 5.6 kohm on the PCB will help solve this problem? Do I need to replace something else? The second question - whether you need a heat shield of the exhaust manifold to correct the air conditioning? Unfortunately, rubber hose between the compressor and the condenser heat from the exhaust manifold.
  4. I hope that will help. Is the corner tico I can write in English?
  5. Thank you for your help What is the difference between the condenser? Is that cheaper is not Chinese? This looks more expensive as the original GM. Has anyone leads to another shop and wires?
  6. Hello! I'm from Poland. Unfortunately I can't speak Romanian language. Usually I use online translators to read your posts in Romanian. I couldn't create the main topic in the forum thread, so I'm writing here I would like to ask you about some parts for AC Tico. Unfortunately, in Poland condenser 95311A78B31-000 is not available. I also need a cable no. 20 with a part number 95731A78B32-000, a cable no. 27 with a part number 95732A79B35-000, and a cable no. 30 with a part number 95733A78B30-000. I need also 2 pieces of dryer, no. 22 with a part number 95330A78B31-000. I attached AC installation diagram with numbers. I'm looking for a shop in Romania where you buy these parts. Please for Your help Regards
