stevelarsc
Everything posted by stevelarsc
  1. This error indicates that the Exhaust Gas Temp Too High. If you check online auto repair forums, the P2428 trouble code signifies that the PCM has detected a problem in the exhaust gas temperature sensor circuit in bank or it can be a faulty exhaust gas temperature sensor. An excessive fuel burn in cylinder can rise the temperature of exhaust. SO high speed may also cause this issue. Sometimes replacing the oxygen sensor can solve this issue. Failure to repair a P2428 trouble code can lead to issues with the ignition timing or air/fuel ratio in an attempt by the PCM to protect the catalytic converter from the high temperatures produced. A good mechanic can help you fix this issue, by replacing the exhaust gas temperature sensor. If you are looking for brakes and rotors, filter engine oil and brake pads, standard brakes, performance brake rotor, brake accessories, brake shoes, brake rotors, brake pads, brake drums, brake kit you can be in touch with Brake Time USA. BRAKETIMEUSA, braketimeusa.com takes pride in supplying AMERICA with the best AMERICAN Automotive Parts. Whether those parts are for Economy reasons or Performance reasons is totally up to our customers. This company is the leading retailer in the US market, with over 50 years of automotive brake knowledge & experience. You can reach them on 8184452389 Or info@braketimeusa.com"
