SiLee
Everything posted by SiLee
  1. salut. mai, cred ca m-as-i baga si eu...
  2. apropos, ai cumva idee daca pot sa imi transform nubira 2 (e din august 2004) in noua nubira 2 euro 3, si cam ce implica asta?
  3. SAlutare. intr-un final are careva idee unde gasesc si io jantele alea de 15 speciale pt nubira 2 sa le pot cumpara? apropo, uite ce frumos e prezentat interiorul la nubira pe afara... : COMFORT AND CONVENIENCE 1.6 litre 2.0 litre Air conditioning with pollen filter S S Central locking S S Power windows front and rear S S Power steering S S Tilt adjustable steering S S Body coloured heated power mirrors S S Variable speed wipers (front only) S S Rear wiper / washer S S Rear window defroster S S Passenger side vanity mirror S S Sliding tray with two cup holders S S Luggage security cover S S Height adjustable drivers seat S S Lumbar support drivers seat S S Reclining 60/40 split fold rear seat S S SAFETY AND SECURITY Driver airbag S S Passenger airbag and ABS braking package O O Side impact protection S S Front and rear crumple zones S S Height adjustable front seat belts S S Rear centre head rest S S Front and rear adjustable head restraints S S Child seat tether anchorage provision (x3) S S AUDIO EQUIPMENT CD player and AM/FM Radio S S 6 speakers front and rear S S EXTERIOR FEATURES Body side moulds S S Colour coded bumpers and door handles S S Twin roof rails S S THE POWER BEHIND THE NUBIRA 2.0 litre 4 cylinder DOHC engine 1998 cc displacement Maximum power of 98 kW @ 5400 rpm Maximum torque of 185 Nm @ 4400 rpm 62 litres fuel capacity 1.6 litre 4 cylinder DOHC engine 1598cc displacement Maximum power of 78 kW @ 5800 rpm Maximum torque of 145 Nm @ 3800 rpm 62 litres fuel capacity 600 kg towing capacity without trailer brakes S S 1200 kg towing capacity with trailer brakes S S YOU CHOOSE 5-speed manual transmission (with overdrive) S S 4-speed automatic transmission (with overdrive) S - ALL THE SPACE YOU NEED 1.6 litre 2.0 litre Overall exterior length (mm) 4550 Overall exterior width (mm) 1720 Overall exterior height (mm) 1470 Wheelbase (mm) 2570 Front track (mm) 1464 Rear track (mm) 1454 Headroom Front (mm) 900 Headroom Rear (mm) 1004 Shoulder room Front (mm) 1396 Shoulder room Rear (mm) 1380 Leg room Front (mm) 1067 Leg room Rear (mm) 882 STAYING IN CONTROL Front brakes are ventilated discs with power assistance S S Rear brakes are drums with power assistance S - Rear brakes are solid discs with power assistance - S Front Suspension has an independent McPherson strut S S Rear Suspension has an independent dual link with stabiliser bar S S 14 x 5.5 steel wheels S - 14 x 5.5 alloy wheels - S 185/65 R14 tyres - S 197/55 R15 tyres S - YOU CAN BE SURE 3 year or 100,000-kilometre warranty S S 24/7 Assist Plus roadside service for 3 years S S
  4. Pai si unde gasesc tote astea ca asti nu au decat pt orice alt model de masina numa' pt nubira 2 nu! am vreo 15000. dar de ce e asa de important nr de km? apropo, e vreo prb daca ii pun jante pe 15 si cauciuc mai subtire (atat cat sa nu modific diametru rotii)?
