anyaddress
Everything posted by anyaddress
  1. hi freindS i have daewoo cielo 1996 automatic dohc 1.6 motor the car was working fine but suddenley a problem happened - when turning the ignition on the car turned on from first time but the voice from exhaust is not normal like ( bo-bo-bo :sound like ther is a cuttoff) now when i driving the car for a while and when the tempertsure is is about 80 and when i push the brake pedal to deaccelrate ,the car is off WHEN RPM IS ON 1000 OR BELOW A LITTLE,some times still on with eratic idle,another thing i noticed is that whenever the car is hot and i turn wheels max to right or left it will off directley any help please things i check: - changed spark plugs with delco orginal ones also changed the wires - i checked for air leak and it was fine - checked / cleaned the IAC (IDLE AIR CONTROL VALVE) -CHECKED TPS (CHANGED WITH ORGINAL DELCO ONE FROM 1 MONTH) -CHECKJED WITH A SCAN TOOL 9NO ERROR CODE AT ALL) I NOTICED THER IS SOME OIL INSIDE THE DISTERBUTOR COVER AND THE GAP WAS DIRTY COULD THIS BE THE PROBLEM THANX AND PLEASE ANY SOLUTION FOR CAR OFF WHEN TURNING WHEEL MAX TO RIGHT OR LEFT ,SOULD A CLOSED INJECTOR CAUSE THIS ,HOW I CAN CHECK THIS THANKS
  2. the car as working fine suddenly and when driving and going to decelerate or stop the car ,the check engine is on and the idle level start play from 0.2 to 1 and then car stops the car don't turn off wherever the rpm is above 1.5 some times the check engine is on and the same thing happen when the car is in park and don't move and when pressing accelerating pedal the motor don't respond and hearing a small blowing sound from exhaust changed sparkplugs,ht cables,coolant sensor any suggestion please could it be from desperator rotating gap or cover or maybe the coil
  3. hi all i was searching on the internet and found a lot of interesting software which can be installed on computer and by building a simple interface it can be used to scan a lot of cars type including daewoo i want to ask if any one uses such software with daewoo cielo 1996 (obd1) thanks
  4. hi i have the same connector you have did you sucssed and find how it coonected if yes how and which software you use
  5. thank you freind i checked this sensor (idle speed) also replaced with another one ,still same problem yes the car has an automatic gear box ,and i didnt check oil level on it (is that cause wrong idling and power!!) anyway 2morrow i check thanks
  6. hi friends please i need your help my car is daewoo cielo 1996 dohc 1.6v the car was working fine but suddenly the car has a big problem the idle level is moving between 0.7 and 1.2 alone (when the car is moving or in park) also the car lost its power so when trying to go with car a little upward road its move hardlyy with a voice from exhaust (blablabla voice ) , and also its completely stopped sometimes (cut off) here what i did: 1- i checked idle speed sensor and its ok (moving upward and downward normally when ignition on and off). 2-i checked the tps sensor and seems ok since when i pull the connector from it when the car is turning on the rpm is moving upwards so the tps is adjusting fine . 3-i changed the spark-plug and spark wires with original one (new). 4-i checked the desperator cover(i mean the part where the 5 spark plug wires is connected,didn't know its name in English changed by a another one i have) also checked the rotating gap inside it and cleaned it 5- i tring to reset ecu by disconnecting negative battery terminal for about 10 min . 6- i make idle speed learning method so please i need your help because all of this didnt solve the problem is it a problem in the motor ,i have told by freind that this could happen by miss firing order,but is it possible the timing built is shifted from it position and cause that hanks you
  7. after checking the car with a scan tools its lead that the problem is in TPS sensor ,after changing it the same problem is still exist!!!!! also i want to ask about tps sensor,the old one in the car its colour is white,the mechanic told me that ther is white and red colour daweoo tps sensor,so he bring a white one which is the same colour to the one in my car,but i noticed that the numbers on the new sensor is different than that on my car (mechanic said this is no problem) is thats right?
  8. no its daewoo cielo with power button on the lever,when i press it it gives a more power to the car and increase the speed of the car in few second,ther is a lamp on the dashborad near tha aba lamp called pwr,normally this lamp is on(orange) when i press power button on the lever,but now it is flasing without i press any button
  9. plz help my car is daewoo cielo 1996(automatic transmition) this thing happen suddenly when i was going to my work PWR lamP is flashing then all dashboard lamps flash for 2sec and car turned off,after that i start the car normally but now when walking for about 1km the PWR lamp is always flashing and i feel the profrmance of the car decreased any idea what is the problem thanxxx
  10. problem solved the alternator has been changed with ecm learning car back to normall
  11. thanx vaxxi i will repair my generator tommorow and i read in the service manual that if the generator produce a high voltage the ecm will work in emergency mode,but i want to ask about brake and battery warning lamp does it do the same with you so that its lit on when i accelrate my rpm,now i will repair my generator and reset my ecm and see thanxxx
  12. plz help daweoo cielo heavy black smoke out with brake and battery warning light on hi nice forum any way my car is daewoo cielo 1996 1.6 dohc with automatic transmittion the car was working fine until i have the following problem: - when i start the car the motor starts shaking when i give more power to the motor (rpm 3 or above) a heavy black smoke going out of the exhaust and after a while i noticed that when the rpm level is above 3 and when i increase it the battery warning lamp lit on with the brake warning lamp steps i do: -i changed the battery to see if any difference the same problem -i reset the ecm by disconnection battery cables(is ther is any other way) -i checked for air leak nothing found -i changed the spark plugs -finally i measured the voltage across the battery when the car is on and i noticed when i increase the motor rotation the voltage increase to 16.8v de ce using digital multimeter is that's normal? any suggestion plz
  13. i mentioned to this problem in pervious topic,and im posting here it again so please help: -the car is working fine ,when moving upward roads like mountains or when the car is on idle speed for some time on traffic the water inside the water bottle start boiling and evaporate later if its on for more time: -thermostat is removed so water is directley circulating through motor and radiator( the returned line from water to bottle is normall and its level increase at high speed so the pump is working fine knowing that i cahnged it also ) -adiator fun is connected directley so its always on with a normal speed. -radiator is brandnew installed -coolant liquide is is used (antifreez) i noticed that when the car motor goes overheat i can hear a sound from the motor (like vlaves strong sound) and a white smoke out from the exhaust,knowing that ther is now water on the oil can be seen also the water level doesnt decrease in water bottle if the car not gone to overheat any help please?its make me crazy?
  14. thanks alx for your reply i want to ask another thing,i noticed also when i press a little on my brake paddle the left rear wheel is directley have maximum brake for 2second then it goes normally,this problem is always happen when i just press a little on my brake paddle also i can hear a strange voice form the rear wheels
  15. my daewoo cielo abs lamp is light on on my dashboard i take the car to three repair center and problem didnt solved and each one say different thing from the other now i will try to do it by myself and your help and i want to ask: -does any one of the following reasons may cause the abs lamp to be on: 1-brake oil is low 2-brake pad is low thickness 3-front abs sensor (how i can test by gigital multimeter) 4-is ther is any rear abs sensor 5-if ther is any air inside brake oil pipes 5-how i can check the elctrecity on abs module (any testing points) and if any ther is any possible reason and i noticed that this problem is happen to a lot of daewoo car and ther is no spesfic solution till now as i read on many forums thanxxxxxxxxx
  16. what is the exact oil grade for my car motor i must used,i dont have a service manual to know,knowing that im from lebanon and our country weather is hot (35 c ) with high humidity levels (85%) also how i can test the level of the automatic transmition oil since ther is no testing tool
  17. WHEN I START MY CAR ,ABS WARNING LAMP IS OFF (NORMALLY),WHEN I START WALKING MY CAR AND AFTER 10 METER OR 15 METER THE ABS WARNING LAMP IS ON ANY HELP PLZ?POSSIBLE CAUSE?I HAVE SERVICE MANUAL BUT ITS IN ROMANIAN LANQUAGE? MY CAR IS DAEWOO CIELO 1996 THANXX
  18. the ground is connected to car chassis and i used a single relay ,with switch on signal taken from water tempertsure senssor
  19. how i can reset my ecm? and where i can execute Idle Learn procedure. thanks
  20. i want to know the exact idle speed for my cielo car (1996) -when i start my car when its cold (cold start) the rpm meter increase to 1.6 (1600rpm) and -after my car is warm the rpm meter decrease to 1.1 (1100 rpm) ans stay fixed as the car is on. -is that good,bcz i think its high,if i want to adjust it from where i can do ,i tried form fuel level screw but couldnt decrease it any more ,is ther is any idle speed adjusting place. thanks
  21. thanks all or your help problem solved i changed my coolant liquide also i put ana extra small fan on radiator ,car working just so fine
  22. 2day im going to change the cooloing liquid with a high quality antifreeze i wish it will work,could ther is a problem in motor?
  23. so i guess that my fun rotation sense is fine,because my main radiator fun located on motor side is suck air toward motor from the front of the car ,any other idea for overheat thanxxx
  24. i want to ask aboout radiator fun direction ,now its coonected so that its suck the air through radiator toward the motor,is thats right or it muct blow the air toward radiator
  25. thanks my freinds i will try this today,also is ther is any manual in english language for my car
