Castravete
Gold Member
Everything posted by Castravete
  1. ... :"> D8 210 Mounting Front, 4 cylinders in line Capacity 1781 cc Bore 81,00 mm Stroke 86,4 mm Compression Ratio 9,5 : 1 Maximum power 154 kW at 6000 rpm Maximum torque 320 Nm at 4000 rpm Top speed 235 km/h Acceleration 0-100 km/h in 4sec Fuel consumption 8-10 L /100 km Propulsion Rear wheels Gearbox type 5-speed man., close ratio, reinforced Gearbox ratio 3,36:1 (I), 1,81:1 (II), 1,26:1 (III), 1,00:1 (IV), 0,82:1 (V), reverse 3,66:1, final drive 3,62:1 Body Aluminum with composite (carbon/fibreglass) Chassis Steel tubular (‘space frame’) Doors 2 (removable) Seats 2 Suspension Front – Independent by double wishbones, separate anti-roll bar Rear – Independent by double wishbones and trailing arms Springs Coil springs Shock absorbers White Power, adjustable two stroke absorption and Preload (height) adjusters Brakes Hardened, drilled and grooved disk brakes, ventilated in front Steering Rack and pinion, no servo Turns 3,4 lock to lock (2,7 optional) Turning circle 8,0 m Wheels Alloy, 8J x 15” in front and rear (light weight) Tires Front - 205/50 x 15” Rear – 225/50 x 15” DIMENSIONS AND WEIGHT Overall length 3,41 m Overall height 1,10 m Max. load front axle 400 kg Fuel tank capacity 40 L Overall width 1,73 m Tracks front / rear 1,40 m / 1,47 m Max. load rear axle 525 kg Weight 630 kg si este cunoscuta sub numele de Donkervoort .. my luv
  2. 01 S Ovidiu + 02 V VAXXi 03 S satori (+-*/... nu se stie) 04 V andreib +/-1 05 S Lucman + 06 S iuzar + (cu +incert) 07 V mecmar + 08 S hellcat + 09 V NFS + (plusul incert) 10 V Claz + 11 S Emi2009+ 12 V Ticolino+ (inca nu sunt sigur 100%) 13 S afarcas+ 14 S sprite+ 15 S Rapiduletul+ (e voie si cu copil?) 16 S Van Den Plas + 17 S Zalmoxis 19 S Ali fotografu' + (daca iau masina, sigur vin.) - nu ma scoateti inca de pe lista 20 S Castravete 21 S Strumfuadi + (cred ca voi veni la prima ora... ) vin singurel , ca didi are teambuilding .. .. si depind de adi adiiii
  3. 01) Ovidiu + 02) VAXXi 03) satori (+-*/... nu se stie) 04) andreib +/-1 05) Lucman + 06) iuzar + 07) mecmar + 08) hellcat + 09) ct_zdb + (nu este 100%sigur) 10) NFS+ (aproape sigur NFS si sper si +) 11) Claz + 1 12) Leutzu+ 13) Emi2009+ 14) Ticolino+ 15) afarcas 16) sprite 17) Rapiduletul+ (e voie si cu copil?) 18) Van Den Plas + 19) Zalmoxis 20) Totti + 21) Ali fotografu' + (daca iau masina, sigur vin.) - nu ma scoateti inca de pe lista 22) Castravete +
  4. Super fain ... good job ... now me back to work
  5. Cu parere de rau tin sa va anunt ca eu ACUM am venit de la munca .. si ca maine sunt nevoit sa lucrez ... ca incep mentenanta pe servere si e musai . Asa ca , nu mai am cuvinte .. si ceea ce pot sa spun este ca pentru a nustiucata oara .. munca imi incurca socotelile ... Distractie placuta , si sa va ganditi si la mine Hev fan ! :bloodycomputer: :bloodycomputer: :bloodycomputer: :bloodycomputer:
  6. eu de ce sunt la meibi ? ca am zis acum cateva zile ca vin .. mdeci Castravete + 1 astept detalii cu privire la intalnirea de maine .. ce si cum si unde ne intalnim spor imi cer scuze ca nu am avut cum sa vin aseara la intalnire .. dar am fost la ski si am ajuns foarte tarziu home ..
  7. Castravete
    Bancuri
    In tramvai: > > - E cineva acolo fara bilet in fund?? > > - Eu, da'-l bag imediat!!! _____________________________________________________________ Q:- Cum iti dai seama ca o blonda a vrut sa trimita un e-mail? > > A:- Vezi o gramada de plicuri inghesuite in floppy. > _______________________________________________________________ > > Motive pentru care calculatoarele ar fi de sex feminin : > > 1. Au o gramada de date , dar totushi nici o idee ... > > 2. Un model mai bun este tot timpul in ashteptare ... > > 3. Arata frumos si lucesc pana le aduci acasa ... > > 4. Este necesar tot timpul sa ai o 'copie de rezerva' ... > > 5. Fac orice doreshti , daca apeshi 'butoanele potrivite' ... > > 6. Partea cea mai buna in a avea pe oricare din ele sunt jocurile pe > care le poti juca ... > > 7. Luminitzele sunt aprinse, dar nu-i nimeni acasa ... > > 8. Marimea conteaza! > > > _______________________________________________________________ > > > Cica Maria se duce in sat la claca. Toate femeile vorbeau de problemele > de sanatate ale barbatilor lor. Maria sedea intr-un colt si aproape > plangea. La un moment dat, femeile o intreaba. > > - Da' ce ai fa Marie, de esti suparata? > > - Apoi ce sa am, ca Ion are probleme de sanatate... > > - Da' ce probleme, fa? > > - Apoi ma f**e si dimineata si la pranz si seara si intre mese, si nu > mai pot. > > - Apoi dusul-ai la doctor, fa? > > - Da, da, da... > > - Si ce-o zis doctorul? > > - Ca n-are tinere de minte...!!!
  8. am vbit , vin si eu cu DD beware of the cucumber
  9. Castravete
    Bancuri
    Se aduna la Oktoberfest la München toti marii producatori de bere din lume, fiecare in speranta ca isi va promova berea cat mai bine. La sfarsitul festivalului, se face o masa mare la care sunt prezenti toti marii bosi. Domnul Tuborg comanda un Tuborg, domnul Bittburger comanda un Bittburger si tot asa mai departe, doar domnul Guiness comanda o Cola. Intrebat de ce nu a comandat o bere din productia proprie, el a raspuns: - Pai daca nimeni nu vrea sa bea bere, eu nu beau singur...
  10. Din pacate azi am raspunsul ferm si final , irrevocabil . NU AM CUM SA VIN detaliile le aflati joi la intalnire !
  11. Daca e intalnirea sapt viitoatre , am rugamintea sa fiu pus si eu + 1 dar la incerti .. inca .. cand treb sa dau raspuns final ? ca din pacate nu depinde de mine v'am salutat in graba ///.. $%#$%@#$% in ea de munca
  12. alo alo .. nu ma puneti si pe mine la certitudini desi eu as vrea dar nu depinde de mine .. v'am explicat ca am o saptamana mai mult decat expensive ... asa ca nu am cum inca sa ma pronunt , cred ca cel mai sigur o sa incerc sa dau MAINE un raspuns cert . ! :?
  13. eu cred ca ma bag , sincer vbind .. asta daca imi mai raman bani .. ca saptamana asta se aude destul de costisitoare dpdv financiar .. 1 buc masina , 1 buc masina de spalat , poate 1 buc moeciu hai ca vorbim dar nu garantez nimic ... INCA
  14. Castravete
    Bancuri
    Erau in avion vulturul si ursul .. Si cum stateau ei , vulturul apasa pe butonul de servire : Stewardessa – Buna ziua , va putem ajuta cu ceva ? doriti ceva ? Vulturul- Ah , nu , la katerinka Vede ursul , I se pare shmekerie mare si incearca si el .. Stewardessa – Buna ziua, va putem ajuta cu ceva ? doriti ceva ? Ursul - - Ah , nu , la katerinka Vede ca merge treaba asa , mai face de vreo’ 3 ori pana se sesizeaza stewardessa si se duce la pilot , ii povesteste ce se intampla si e indrumata ca la urmatorul apel , sa’I arunce afara din avion .. zis si facut , suna ursul , pac vine stewardessa si ii arunca din avion… In aer … Vulturul : Bah ursule … stii sa zbori ? ? Ursul : NU ! Vulturul : … pai tie’ti arde de katerinka ??!?
  15. .. I noticed that you guys are begining to use .. the "woo" word .. so , I remind you the banner I made for the autostickers ...
  16. but ... but .. you ain't got an english version ... i'll try to improvise
  17. Mdeci vad ca pollul inclina spre mucificator de parbriz .. atunci d'asta sa fie pentru inceput ! , sondajul il mai las o leaca sa vedem ce si cum Acum urmeaza sa vedem ce cantitate ! Enjoy
  18. Hehehe .. nu m'a ghicit din prima .. dar intr'un final .. super fain !
  19. face un surogat al tuicii. .. alcoooool d'ala rafinat de nu stiu de care ..
  20. Ce TESTE mey ? ca aici nu e vba de teste ! e vorba de sponsorizare. Produsele sunt super testate inainte sa iasa pe piata oricum ! ...
  21. Biensur , avem participari la expozitii in toata tara .. si cand o sa mai fie una pe acolo , ne cuplam cumva. Ultima expozitie de profil s'a tinut la Bacau ( destul de aproape de tine ) si am auzit ca o sa mai fie la Piatra Neamt putin mai incolo , asa ca daca e sa se aranjeze cumva , se vor putea distribui "cadouri" si in zona respectiva !
  22. nu e nimic secret .. .. mdeci pe baza statisticilor siteului .. am vorbit cu Bossul , sa ne sponsorizeze .. in seara asta stabilim ce si cum si in ce fel .. si aporturile ambelor parti ..
  23. Astazi am o intrevedere cu BOSSul Chimoparului si am nevoie de niste date exacte , pe care din pacate nu am timp sa le obtin singurel si acum : date tehnice referitoare la lichidul de frana destinat tuturor modelelor daewoo sau chevrolet , datele tehnice ale antigelului folosit , si presupun ca la solutiile de spalat geamuri ( iarna/vara ) nu se poate pune problema de asa ceva - ma refer la specificatii Orice informatie este bine venita , asta daca cu siguranta va intereseaza. Ceea ce va pot spune cu siguranta , si garantez , este ca produsele sunt de buna calitate .. si nu imi bat gura aiurea , sau bravez inutil. Vreau sa pot aduce la intalniri , diverse produse chimopar pentru masini .. Iar din partea forumului , presupun ca un simplu banner cu link ar fi mai mult decat suficient.. oricum pe tema asta vbim apoi si vbim daca e si diseara , astept cu nerabdare datele tehnice ..
  24. Castravete
    Bancuri
    unu se plimba cu un mercedes 190D si face pana fix in fatza unui spital de nebuni. se apuca omul sa schimbe roata, dar dupa ce scoate roata belita si o pune p-aia de rezerva, da cu piciorul peste toate cele 4 shuruburi care ii cad intr-un canal. un nebun agatat de gardul spitalului statea si se uita la om care incerca cu disperare sa scoata suruburile din canal si nu reusea. dupa 15 min nebunul il intreaba: - hombre, poti ajunge cu masina pana la primul service cu rotile prinse in cate 3 suruburi fiecare? - da, cum sa nu, ar fi suficiente. - pai atunci de ce nu scoti cate unul de la fiecare dintre celelalte 3 roti si pune-le la roata asta... - bai, da' destept esti.. cum dracu de te tin astia inchis in spitalul de nebuni... - pai ba, eu sunt nebun, nu tampit!
  25. Uochei redirectionam berea atunci Vedem cum evolueaza lucrurile maine
