bella Posted September 5, 2006 Share Posted September 5, 2006 Va multumesc foarte mult pentru ajutor. Va raman dator si o sa va tin la curent cu evolutia problemei. Multumesc. Link to comment
bella Posted September 6, 2006 Share Posted September 6, 2006 Salut, Tocmai m-am intors din Salonic si am gasit rulmentii. Multumesc lui Ovi si D-lui Nicu Barbu fara de care nu as fi reusit sa ii gasesc. Mai exact am gasit cu ajutorul codului OE 1603 193 (Opel) rulmenti facuti de OMCAR(Italia). Codurile sunt urmatoarele: -rulment mic: 00707 11749/10.BE -rulment mare:RWR...BE00709...IT.05. Inca o data va multumesc. Link to comment
master Posted September 12, 2006 Share Posted September 12, 2006 (edited) Am gasit 4 telescope de Cielo la un pret destul de bun. Se potrivesc la Espero? Multumesc! Later edit : Am gasit! Scria mai sus Edited September 12, 2006 by master Link to comment
Mad MAX Posted September 15, 2006 Share Posted September 15, 2006 Punte spate Calibra cu discuri se potriveste la cielo? Link to comment
blue_kid Posted September 17, 2006 Share Posted September 17, 2006 Am si io o intrbare ca, am vazut la cielo, butonu' de la maneta de frana de mana este oarecum rectangular. Stiti cumva ce maneta se potriveste?? Ca vreau s-o schimb cu una de metal si insertie de piele ceva. Idei, adrese? Merci anticipat Link to comment
Englishman Posted November 17, 2006 Share Posted November 17, 2006 bella> dupa ce ai schimbat rulmentii zgomotul a disparut, asa cum era de asteptat? Link to comment
bella Posted November 17, 2006 Share Posted November 17, 2006 Categoric...insa i-am strans asa cum a spus Ovi, nu cum au facut berbecii aia din service Link to comment
vlivius1 Posted November 20, 2006 Share Posted November 20, 2006 Au fost stransi prea tare si nu li s-a schimbat vaselina.Daca mergi usor nu se intampla nimic in afara de faptul ca haraie.Ia legatura cu nicubarbu sa iti zica exact ce sa cauti. Sal Ovi Rulmentii spate la cielo se strang la fel ca la Dacie, adica strangi la maxim dupa care desfaci un sfert de tura? Merci Link to comment
bella Posted November 20, 2006 Share Posted November 20, 2006 (edited) Eu nu am procedat asa cand i-am schimbat in Grecia. Adica i-am strans usor cu mana cat a mers si apoi cred ca am mai strans maxim 1/2 tura. Ca sa iti dai seama exact, daca acum scot siguranta de la piulita si folosesc o laveta mai groasa pot cu putin efort sa desfac piulita cu mana. Verific periodic daca am joc la rulmenti pe spate si pana acum ~3000 Km, nimic. OFF. Din cate am reusit sa imi dau seama, faptul ca rulmentul interior nu intra ca la dacie prin presare ci "se aseaza" pe conul axului, face ca acestia sa nu trebuiasca stransi f tare. Maestre, ai cuvantul daca am deformat cumva realitatea(de la atata strans). Edited November 20, 2006 by bella 1 Link to comment
vlivius1 Posted November 22, 2006 Share Posted November 22, 2006 Ok merci, credeam ca se strang ca la dacie Link to comment
ovi_jer Posted November 23, 2006 Share Posted November 23, 2006 Alternatorul de 12V - 95A nubira-leganza motor 2l DOHC cod reper :96206871 este compatibil cu cel de la modele opel de 14V - 120A cu reperele : BOSCH 0986039240 BOSCH 0123505001 BOSCH 0123510063 DELCO-REMY DRA9240 MAGNETI MARELLI MAR959 OPEL 1204146 OPEL 6204152 OPEL 90443931 VALEO 437213 Sau de 14V - 100A cu reperele : BOSCH 0986043680 BOSCH 0123505002 OPEL 1204145 OPEL 3493824 OPEL 6204000 OPEL 6204002 OPEL 6204151 OPEL 90350887 OPEL 90443929 OPEL 9512800 VALEO 436683 VALEO SG10B012 Singura modificare este la terminalul releului unde cele daewoo au mufa cu 2 pini activi L(light) si IGN(aprindere) iar la opel este decit un terminal D+(M5) pe care vine legat firul L de la mufa veche. Link to comment
VAXXi Posted December 23, 2006 Share Posted December 23, 2006 Mi-am petrecut vreo 20 de minute cu configuratorul auto Bosch, si am luat codurile de produse pentru Espero 1.8: Espero 1.8 1995 Bujii: WR 9 DCX, WR 9 DPX, WR 91 X Cablaj bujii: set cablaj aprindere B 739 Fise: H 70 cilindrul 1, H60 cilindrul 2 Curea de distributie: 9 533, HTDA 1191 9,525M 20 Curea transmisie cu caneluri: 5 PK 1250 Curea transmisie: 13 X 875 Filtru aer: S 3003 Placute frana: 21 190 Stergatoare: 480, 480 S Daca mai face cineva asta pentru masina proprie, poate vedem si ce se mai potriveste de la un model Daewoo la altul. Link to comment
serban_pc Posted December 23, 2006 Share Posted December 23, 2006 Sal, Pe mine ma intereseaza timoneria de la cutia de viteze de la un cielo sohc cu ce se poate inlocui ca am mai schimbat una si mi-a picat dupa 1 luna. Imi intra greu in a-2-a si cateodata in 1-a , dar nu intotdeauna. Daca o scot si bag de cateva ori pina la urma reusesc. Link to comment
ovi_jer Posted December 24, 2006 Share Posted December 24, 2006 Este aceasi la toate modelele daewoo.In mod sigur problema la tine este pozitionarea gresita sau slabirea levierului de restul timoneriei. Link to comment
serban_pc Posted December 24, 2006 Share Posted December 24, 2006 Asa zici tu ca nu este timoneria de fapt? Eu am un mecanic care lucreaza la daewoo de 6 ani, chiar asa sa nu o fi montat el bine de s-a stricat? Ma gandeam la una de opel. Cat o costa intr-un service chestia asta ? Poate fi stricat de fapt altceva ? Link to comment
VAXXi Posted December 24, 2006 Share Posted December 24, 2006 Am patit eu: timoneria noua, montata in service autorizat, dupa 2 saptamani s-a slabit si nu mai aveam treptele 1 si 2. Dupa (re)strangere a fost ok. Link to comment
savimbi Posted December 26, 2006 Share Posted December 26, 2006 Am schimbat fuzetele de pe fata cu tot cu butuc si rulment. S-au potrivit cele de la Opel Vectra tip A, cu exceptia telescoapelor care nu au aceeasi dimensiune la partea de sus, parte care intra in rulmentul din capul telescopului. Link to comment
savimbi Posted March 3, 2007 Share Posted March 3, 2007 Schimbat etrierii cu unii de pe Opel Astra si pompa de frina cu una de Kadet. Frina net superioara si in plus am scapat de trancanitul etrierilor originali. Link to comment
bella Posted March 5, 2007 Share Posted March 5, 2007 Salut, Sper ca nu am gresit topic-ul... Ma intereseaza ce cod au rulmentii SKF pentru Cielo Exe/fata. Ma poate ajuta cineva? Multumesc. Link to comment
AdiD Posted April 12, 2007 Share Posted April 12, 2007 Am citit pe forum ca ar fi mai bune injectoarele de la Espero de 1,8 sau 2. Se potrivesc injectoarele de Opel Astra 1,8 la Nubira I ? Am gasit la dezmenbrari cu 20 lei/buc. E bun pretul? "> Link to comment
ovi_jer Posted April 12, 2007 Share Posted April 12, 2007 Daca sunt de tip bosch si sunt in stare buna da. De obicei insa injectoare folosite si state mult timp au probleme. Link to comment
AdiD Posted April 12, 2007 Share Posted April 12, 2007 Multumesc! Nu stiu daca sunt Bosh - sa intreb sau sa ma uit pe ei daca scrie; si cum se pot verifica daca sunt in stare buna de functionare inainte de ai monta pe masina? "> Link to comment
ovi_jer Posted April 12, 2007 Share Posted April 12, 2007 Proba pe masina sau pe banc. Link to comment
AdiD Posted April 16, 2007 Share Posted April 16, 2007 Nu am mai luat injectoarele - scria pe ele GM si erau cu 2 gauri Link to comment
ast3rixu Posted April 21, 2007 Share Posted April 21, 2007 Stie cineva daca modulul de ABS de pe Leganza are vreo echivalenta la Opel shi daca e vreo echivalentza la discurile de frana de pe fata tot la leganza? Link to comment
