florinellll Posted June 29, 2012 Share Posted June 29, 2012 (edited) Placutele frana fata Leganza si Nubira ll sunt compatibile? Imi dau singur raspuns sunt compatibile . Edited June 29, 2012 by florinellll Link to comment
Salex Posted June 29, 2012 Share Posted June 29, 2012 Da ... Mai vezi: Cielo Executive, Aveo, Lacetti, posibil si altele. Link to comment
olaespero Posted July 10, 2012 Share Posted July 10, 2012 salut stie cineva daca conductele de frana (frina) de la Cielo se potrivesc la Espero? Merci1 Link to comment
florinellll Posted August 24, 2012 Share Posted August 24, 2012 Se poate inlocui pompa de apa Leganza cu ce-a de Espero 1,8 l ? Am vazut ceva de genul 25 dinti vs 21 dinti Link to comment
Salex Posted August 24, 2012 Share Posted August 24, 2012 Si esti in bani, te-ai certat cu distributia ?? Stai cuminte ! Link to comment
florinellll Posted August 25, 2012 Share Posted August 25, 2012 Era la 45lei noua,ma gandeam la chilpir Link to comment
lperisoara Posted August 26, 2012 Share Posted August 26, 2012 Reformulez si aici intrebarea din postul http://www.gmclub.ro...380#entry558585 Credeti ca butoanele de ceata, avarii, etc.(cele ovale) de pe Leganza se potrivesc pe Matiz? Link to comment
Salex Posted August 27, 2012 Share Posted August 27, 2012 Pe vremuri am cautat un buton de avarie pentru Leganza. Cum in magazine nu am gasit pe stoc am incercat sa iau unul de Matiz. Desi au trecut cam 7-8 ani de atunci, imi aduc aminte ca nu se potriveau. Link to comment
doryjan Posted November 25, 2012 Share Posted November 25, 2012 salut,sunt nou pe aici si deasemeni nou posesor al unui cieloGLE 1996.Intrebarea mea si daca stie cineva rog putin ajutor ,,,se potriveste cutia de viteze de la motor 1.5 8 valve la unul cu 16 valve??? Link to comment
alexinno Posted November 26, 2012 Share Posted November 26, 2012 teoretic, e aceeasi, asa apare in manual. uitat-te la suruburile de prindere de la demaror, acolo e posibil sa apara "buba". Link to comment
Viktor Posted November 26, 2012 Share Posted November 26, 2012 De nu ma insel, discul de ambreaj e mai mare la 16V, logic ca si cutia sa fie mai mare. Link to comment
doryjan Posted November 27, 2012 Share Posted November 27, 2012 ms mult de raspunsuri si o sa vad ce se poate face ca la mine imi cam scoate fum si am zis ca ,,decat sa segmentez motorul si sa rectific chilulasa ,mai bine schimb motorul cu totu ca tot pe-acolo ies. Link to comment
Dj_Dark Posted November 27, 2012 Share Posted November 27, 2012 Sa iei motorul cu tot cu disc de ambreiaj si placa, alea sunt diferite, desi fizic merg si astea de 8V se recomanda alea de 16V (disc putin mai mare in diametru). Link to comment
doryjan Posted November 27, 2012 Share Posted November 27, 2012 cu motorul o rezolv si da o sa fac asa cum ati recomandat s-au eventual cu tot cu ,,cutie,si anexe. Eu am roti pe 14 iar pe talon am 13 as vrea sa le schimb dar nu se potrivesc din cauza etrierului acesta fiind mai mare,,intrebarea mea este:Ce trebuie sa schimb pentru a le face pe ntru roti pe 13???va multumesc anticipat. Link to comment
Dj_Dark Posted November 27, 2012 Share Posted November 27, 2012 (edited) Etrierii cu unii de lanos. vedeti topicul de la frane. Atentie, planetarele si butucii difera la 13 vs 14 de fabrica. Daca in cutie merg ambele indiferent de modelul cutiei, la capetele din butuci au numar diferit de zimti si cele de 13 sunt si mai subtiri. Edited November 27, 2012 by Dj_Dark Link to comment
doryjan Posted November 27, 2012 Share Posted November 27, 2012 Sa inteleg ca trebuie schimbat si butucii odata cu discurile???de ce???nu merg discuri de 13 in locul celor pe 14???si etrierii aferenti de 236??scz dar e prea mult de bagat bani daca e asa.Ms de raspuns o seara buna. Link to comment
Dj_Dark Posted November 27, 2012 Share Posted November 27, 2012 Nu, butucii se schimba doar daca se schimba planetarele si invers. Era o informatie utila, in cazul in care se doreste inlocuirea cutiei de viteze ar trebui pastrate planetarele masinii originale. Nu are legatura cu discurile. Link to comment
doryjan Posted November 27, 2012 Share Posted November 27, 2012 AA da scuze,,si ms mult de informatii.Da o sa schimb discurile si etrierii ca nu vreau sa raman fara talon.E mult de umblat sa il vad inapoi. Link to comment
ovidiule Posted December 12, 2012 Share Posted December 12, 2012 Oare acest electromotor se potriveste, pe cielo? http://www.boorze.com/ro/car_part/Daewoo_Leganza_electromotor_1997/12238 Link to comment
SrG Posted January 11, 2013 Share Posted January 11, 2013 Am nevoie sa schimb motorasul pas cu pas la un espero 1.5 Dohc. Am gasit unu care arata la fel numai ca nu are acelasi cod. Intrebarea este...trebuie neaparat sa aiba acelasi cod? Link to comment
Dj_Dark Posted January 14, 2013 Share Posted January 14, 2013 Nu neaparat, insa difera pozitia mufei si va sta cablul ciudat. Depinde de cod. 1 Link to comment
SrG Posted January 16, 2013 Share Posted January 16, 2013 Ok. Multumesc frumos pentru raspuns. Link to comment
gingiskhan2283 Posted February 23, 2013 Share Posted February 23, 2013 am si eu o intrebare, daca ma poate ajuta cineva.de la ce alte masini pot lua un delcou pt cielo 1997?am intrebat le unul,pe altul si imi spuneau ca as avea o problema la delcou sau la modulul din interiorul delcoului.am scanteie de la bobina la delcou,dar de la delcou la fise\bujii nu mai am nici un fel de scanteie Link to comment
Andrei.ss Posted February 24, 2013 Share Posted February 24, 2013 Acelasi delco il mai gasesti doar pe Espero. Link to comment
