Mircea Posted August 18, 2006 Author Share Posted August 18, 2006 Pai si ce naiba, apa aia zboara?? E un furtun rupt ceva, n-ai apa sub masina? Link to comment
mari.d Posted August 18, 2006 Share Posted August 18, 2006 Nup, nici macar un strop,asta am patit aseara cand ma intorceam de la forum, cand am parcat masina a venit un miros ca ars si un zgomot ciudat rau, am ridicat capota, ieseau aburi si motoru frigea Link to comment
Mircea Posted August 18, 2006 Author Share Posted August 18, 2006 Tu vrei sa-mi spui ca ai mers pana cand a mirosit a parlit si nu te-ai uitat la indicatorul de temperatura a motorului? Pai ala cred ca era in slavi! Basca checkul care se aprinde imediat ce motorul iese din parametrii (temperatura ridicata, lipsa ungere, lipsa racire etc). Mergi si vorbeste cu un mecanic. Link to comment
mari.d Posted August 18, 2006 Share Posted August 18, 2006 E vb de matizul sorinei, tipa care a mers fara apa o buna bucata de vreme, eu aseara am mers cu ea, dar culmea, indicatorul de motor arata ok, am sa-i spun, mercic pt tot Link to comment
Mircea Posted August 18, 2006 Author Share Posted August 18, 2006 Aha... si fum alb in spate da? Link to comment
mari.d Posted August 18, 2006 Share Posted August 18, 2006 (edited) Nu am sesizat, posibil, oricum am inteles ca se duce Alezz cu ea la mecanic sau ceva in genu. Edited August 18, 2006 by Mircea Link to comment
Mircea Posted August 18, 2006 Author Share Posted August 18, 2006 Posibil garnitura de chiuloasa arsa daca a mers fara apa, caz in care apa ajunge in pistoane si este scoasa pe esapament. Motorul ala ar trebui sa mearga ca dracu, iar in spate ar trebui sa fie masina de ceata PS Nu vazusi si tu ca editez la posturile tale de 30 de minute incoace? Link to comment
Alezz Posted August 18, 2006 Share Posted August 18, 2006 O sa ma duc eu pe la 1 sa vad masina...puii mei sper s-o scot la capat... Link to comment
mari.d Posted August 18, 2006 Share Posted August 18, 2006 PS Nu vazusi si tu ca editez la posturile tale de 30 de minute incoace? Cand editam ultimul meu post m-a sunat, scuze ca ti-ai irosit timpul, dar a fost de ajutor, cel putin pentru mine Link to comment
Mircea Posted August 18, 2006 Author Share Posted August 18, 2006 Nu mi-am irosit timpul deloc OFF Topic dar ON Forum: Ma refeream la citarea repetata a mesajului anterior si la scrierea fara majuscule la inceput de fraza/propozitie. Link to comment
Alezz Posted August 18, 2006 Share Posted August 18, 2006 Curge apa din motor...luni o sa vad pe unde(chiulasa e putin probabil ca nu are apa in ulei sau cel mai probabil pompa de apa)... Link to comment
adi_1579 Posted August 18, 2006 Share Posted August 18, 2006 Va rog mult sa-mi spuneti si mie linkul unde gasesc instructiuni despre reset ecm si idle learn! Am tot cautat pe forum dar nu am gasit exact ce trebuie sa fac si nu mai stiu ca sa ii mai fac caci variaza foarte mult turatia la relanti!A inceput sa faca asa de cand am curatat tot ce am putut si eu printre care si ecm.Era plin de ulei intarit deja de cand nu a fost curatat! Va multumesc mult! Link to comment
Mircea Posted August 18, 2006 Author Share Posted August 18, 2006 Adi, ce ECM curatasi tu? PS vezi la sectiunea Tutoriale, Tips & Tricks curatare IAC si Idle learn si Reset ECM Link to comment
adi_1579 Posted August 19, 2006 Share Posted August 19, 2006 Pai am curatat "cuiul" sau ce o fii chestia aia care dozeaza debitul de aer pentru mentinerea relantiului in functie de temperetura motorului! Nu stiu exact cum se cheama eu stiam ca ii zice motoras pas cu pas! Acum merg cu mufa scoasa din el caci daca il conectez i-mi variaza rau de tot relantiul iar daca am noroc sa se stabilizeze o face undeva la 2000 rot/min ceea ce numai relantiu nu mai e! Ca sa merg asa fara actiunea lui l-am desfacut si l-am destins manual la maxim,astfel am un relanti ok dar cand va venii frigul nu o sa se mai poata mentine ca acum cand e cald! Daca aveti ceva sfaturi pt mine le primesc cu cea mai mare placere si le astept! Va multumesc! Link to comment
Mircea Posted August 19, 2006 Author Share Posted August 19, 2006 Chestia aia se cheama IAC. Daca ai facut ce zici ca ai facut, poti sa te duci frumusel la magazin si sa-ti iei altul, ca ala nu mai e bun de nimic. Daca cautai pe forum, ai fi aflat cum se curata IAC-ul (carpa moale de bumbac, fara sa umbli la reglajele lui) si cum se face initializarea lui astfel incat sa invete parametrii optimi. Asta e... omul din greseli invata. Sfatul meu este ca, in cazul in care nu aveti veleitati tehnice, mai bine platiti un mecanic sa faca treaba respectiva, decat sa stricati ceva. In cazul tau, ai castigat 20 ron si ai pierdut vreo 300, cat este costul aproximativ al unui IAC nou Cum ziceam, omul din greseli invata. Link to comment
tolin Posted August 19, 2006 Share Posted August 19, 2006 @adi > pozitioneaza varful "cuiului" la 28 mm fata de baza, pune conectorul la loc, da un reset la ECM si fa apoi o procedura de IDLE LEARN. Informatiile le gasesti pe forum. Link to comment
Alezz Posted August 21, 2006 Share Posted August 21, 2006 Curge apa din motor...luni o sa vad pe unde(chiulasa e putin probabil ca nu are apa in ulei sau cel mai probabil pompa de apa)... Pana la urma fu pompa de apa...misiune indeplinita . Link to comment
baszu' Posted August 24, 2006 Share Posted August 24, 2006 (edited) 300 lei un IAC nou? . Mai frate dar scumpe piesele astea. Parca ar fi vw sau oooo. Edited August 24, 2006 by baszu' Link to comment
SMS Posted August 26, 2006 Share Posted August 26, 2006 Azi dimineata mi s-a oprit motorul la semafor (cauze "naturale", nu din cauza ambreiajului uitat ridicat). Ma chinui sa pornesc... ceva se auzea ca se invarte sau ca se chinuie sa... traga ceva... pana la urma apas acceleratia si o ia. Sun la service... ajung acolo... Se uita la masina... desi i-am zis ca bujiile sunt bune ala s-a apucat sa le scoata, apoi nu mai stia sa bage cablurile inapoi... dupa aia vroia sa scoata (nu mai stiu cum ii zice) chestia aia care regleaza acceleratia CARE ERA IN MOD EVIDENT EXTREM DE CURATA fata de restul motorului si i-am zis sa o lase asa ca e curatata... unge ala cureaua de la alternator... zice ca nu are nimic. Coduri de eroare nu are... Bine ca nu mi-a luat bani... si plec. Cum fac stanga spre carrefour (eram pe plevnei) se aude ca un fel de scurtcircuit electric (ATENTIE: DOAR SUNETUL, adica pocnea ceva...) si se opreste iar motorul. O las sa curga pana la fabria de tigari ca sa nu stau in drum (eram in fata la bricostore) si stau putin. Sub masina nu a curs nici un fel de lichid... Dau sa plec iar... iar nu pornea... accelerez si o ia apna la urma... Cuncluzie: am programare la autonet militari saptamana viitoare. Intrebare: are cineva idee ce se poate intampla? headscratch.gif probabil nu are benzina in momentul pornirii DUPA ce in prealabil ori accelerez eu prea tare, ori fac fara sa vreau frana de motor... ca in service au pornit-o si oprit-o aia de 50 de ori si mereu a mers perfect. [este acelasi text ca aici: http://www.daewooclub.ro/forum/index.php?s...mp;#entry202312 , doar ca acolo mi-am spus si parerea. Aici e problema...] Link to comment
baszu' Posted August 26, 2006 Share Posted August 26, 2006 I-a vezi matale daca martorul de baterie este aprins chiar si slab. Eu am avut probleme la alternator (puntea arsa), si imi murea motorul la semafor. Verifica daca incarca BINE (de incarcat, incarca dar nu la valoarea normala) si dai si un reset cu idle learn dupa. Link to comment
Mircea Posted August 26, 2006 Author Share Posted August 26, 2006 SMS, verifica fisele de la bujii si cat de bine sunt stranse cablurile de la baterie (atat la baterie cat si la electromotor/masa) Baszu, nu crezi ca ar fi ramas fara baterie si n-ar mai fi putut sa porneasca? Link to comment
SMS Posted August 27, 2006 Share Posted August 27, 2006 (edited) Si... gataaaa (ca in reclama cu marmotele). Acum se aude in mod constant un pacanit, direct proportional cu viteza motorului (rpm). CU cat il accelerez mai tare, cu atat se aude mai des acel sunet. Lasat in viteza, 50-80 kmh, fara acceleratie se opreste. Accelerat = ramane motorul pornit, dar nu ia viteza prea usor. Sunetul care s-a auzit inaintea primei opriri era ca si cum o foaie de hjartie era supta pe acolo... sau caun scurt din ala de prin filme... cu scantei si tot tacamul. Mergeam constant cu 100kmh FIX si de vreo 10 km cand s-a intamplat asta acum de dimineata. Edited August 27, 2006 by SMS Link to comment
Mircea Posted August 27, 2006 Author Share Posted August 27, 2006 Ai verificat fisele? Link to comment
Mircea Posted August 27, 2006 Author Share Posted August 27, 2006 Scoate pe rand fiecare fisa si vezi in primul rand daca ramai cu ea in mana... adica daca se rupe. Apoi verifica daca vreuna din bujii este innegrita pe izolator (partea alba care se vede fara a demonta bujia). Daca este innegrita, acolo este fiza cu probleme. Verifica de asemenea sa fie infipte bine fisele, atat in bujii cat si in modulul de aprindere. O alta verificare ai putea s-o faci noaptea, cand, turand motorul cu capota ridicata pe intuneric, la fisa cu probleme se vad scantei. Link to comment
