dino Posted June 11, 2006 Share Posted June 11, 2006 Unde am putea gasi filtru de ulei MANN pentru Cielo SOHC 1.5? Si poate intrec masura dar ulei OMV 5W40 se poate cumpara si de suprmarketuri sau numai de la benzinarii? Va multumesc pentru intelegere. Link to comment
VAXXi Posted June 11, 2006 Share Posted June 11, 2006 http://www.autototal.ro/ Benzinariile OMV. Link to comment
dino Posted June 11, 2006 Share Posted June 11, 2006 (edited) Am inteles. Acum daca tot ati fost deosebit de amabil imi mai puteti spune si ce model de filtru trebuie sa cer sau spun la magazin ce model de masina si ce motor si stiu ei ce sa imi dea? Este cumva W712/22 potrivit catalogului Mann-Hummel? Edited June 11, 2006 by dino Link to comment
VAXXi Posted June 11, 2006 Share Posted June 11, 2006 http://www.mann-hummel.com/mf_prodkata_eur...eys=23.1.0.21.1 Pentru Daewoo Cielo Aer: Mann C 2598 Ulei: W 712/22 Benzina: WK 612/2 Link to comment
Dan98 Posted June 20, 2006 Share Posted June 20, 2006 cat costa o aripa fata Cielo an fabr 96 sedan ? un pret mai recent daca se poate Link to comment
ovi_jer Posted June 20, 2006 Share Posted June 20, 2006 Daca citesti topicul acesta o sa vezi destule link-uri catre cateva magazine care au preturile afisate. Link to comment
Jobyn Posted June 21, 2006 Share Posted June 21, 2006 placute fata - 450 mii lei (germania) discuri fata - 1.050.000 filtru + ulei Mobil1 900mii lei dak ma poate ajuta cineva cu o masca de oglinda visinie, rabatabila pe partea stanga v-as fi recunoscator! deoarece mi`a agatat-o un tir si doar masca a crepat-o! astept raspunsuri... Link to comment
dino Posted June 27, 2006 Share Posted June 27, 2006 (edited) Filtru ulei MANN W712/22 - 9,2 RON Filtru aer MANN C2598 - 25 RON Filtru benzina MANN WK 612/2 - 45 RON Magazin AUTOTOTAL Calea Plevnei colt cu Mircea Vulcanescu (fostul Stefan Furtuna) Tel: 021/316.41.29 Edited June 27, 2006 by dino Link to comment
Gee01 Posted June 27, 2006 Share Posted June 27, 2006 Cateva preturi de piese pt Cielo cumparate de la Radacini Gara de N : Termostat - 32.50 Vas Expansiune - 48.50 Lichid Frana Bosh DOT4 - 8.5 1l parca Ceas Temperatura+Benzina - 35 Garnitura Capac Tacheti - 22.50 Garnitura Baie Ulei - 23 Ulei Valvoline Full Sintetic 5W40 4l - 123 Senzor Temperatura - 20 Preturi in RON cu tot cu TVA Link to comment
exode Posted July 5, 2006 Share Posted July 5, 2006 Am fost sa-mi fac geometria si, dupa constatare, trebuie sa schimb urmatoarele: - pivot stanga - 40 RON Koreea; tot 40 RON Bilstein, de Opel (scria pe cutie si Daewoo) - cap de bara dreapta - 45 RON Koreea; 40 RON Bilstein fftopic: Nu le-am cumparat inca, dar eu as inclina sa le cumpar pe alea koreene Separat, doar partea telescopica a antenei electrice: 28,5 RON. Nu stiu ce sa zic despre preturile pivotului si al capului de bara. O fi bine... n-o fi? (preturile sunt din Constanta) Link to comment
sorin77 Posted July 5, 2006 Share Posted July 5, 2006 Ieri am cumparat 2 jenti de tabla, noi originale de Cielo, de la Nina Sibiu cu 600.000 lei vechi/bucata -culoare neagra. Asta in conditiile in care la mai multe puncte de vanzare de piese second hand in Sibiu am gasit jeanta tabla de Opel Kadet gata ruginita pe care se cerea 500.000 lei vechi. Inchipuiti-va cata nesimtire pe dealerii de SH, si culmea ca se tineau la pret ...normal ca am luat lucru nou! Link to comment
EXE Posted July 6, 2006 Share Posted July 6, 2006 (edited) Eu am luat (alaltaieri) o janta de tabla de cielo pe 14" neagra, din BV (Melania), cu 1,1 mil. Edited July 6, 2006 by EXE Link to comment
sorin77 Posted July 6, 2006 Share Posted July 6, 2006 mda se pare ca Melania BV chiar aplica comisioane nu gluma .. Tot de la Nina in SB am luat si un maner usa complet pt usa dreapta fata si a costat 225.000 lei vechi. Trebuie sa il mai vopsesc si il pun sus. La manerul vechi mi s-a rupt un arc care il tragea inapoi si numai arcul ala separat nu se vinde. Link to comment
mcrusu Posted July 6, 2006 Share Posted July 6, 2006 Care ar fi pretul corect pentru un radiator de clima,pentu cielo an 99? Link to comment
exode Posted July 8, 2006 Share Posted July 8, 2006 Bujii NGK BPR6ES - 40 RON Filtru aer Koreea - 17 RON Ulei OMV 5W40 - 103 RON Filtru ulei GM Koreea - 9 RON Motor flush 2+2 - 17 RON Lichid frana OMV dot 5.1 2 x 250 ml - 23 RON Manopera - 80 RON (cele de mai sus + schimbat pivot stanga si cap de bara dreapta) In plus geometria - 50 RON (10 RON constatarea + 40 RON reglajul) Link to comment
Jobyn Posted July 16, 2006 Share Posted July 16, 2006 sorin77 said: Ieri am cumparat 2 jenti de tabla, noi originale de Cielo, de la Nina Sibiu cu 600.000 lei vechi/bucata -culoare neagra.Asta in conditiile in care la mai multe puncte de vanzare de piese second hand in Sibiu am gasit jeanta tabla de Opel Kadet gata ruginita pe care se cerea 500.000 lei vechi. Inchipuiti-va cata nesimtire pe dealerii de SH, si culmea ca se tineau la pret ...normal ca am luat lucru nou! Eu am dat intr-o bordura cu janta si s-a indoit destul de rau...am mers la vulcanizare unde a zis ca nu mai poate fi dezdoita si mi-au vandut ei una cu 100 mii lei vechi vreu sa spun ca arata foarte bine si nu am probleme...data viitoare te sfatuiesc sa cauti si pe la vulcanizari Link to comment
dobrescucris Posted August 3, 2006 Share Posted August 3, 2006 Cap bara stanga (rotula bieleta) - 65 RON Manopera - 25 RON (+spray pe pedale, ca scartaiau urat) Link to comment
Alezz Posted August 3, 2006 Share Posted August 3, 2006 Cap de bara Cielo la magazinul de pe sebastian undeva intre 13-15 RON... Link to comment
dobrescucris Posted August 3, 2006 Share Posted August 3, 2006 (edited) E luat de la un magazin (ca toate celelalte) de langa service (aproape de mall Vitan). Scrie pe cutie ca e distribuit de GM, made in koreea si are o holograma pe care scrie Genuine.. sau ceva de genu. Si eu cred ca e putin mai scump decat in alte parti, dar sunt sigur ca nu e 15 RON un cap de bara exact ca asta.. (sper sa nu fie ) O sa ma mai uit si in alta parte, macar sa stiu sa nu mai iau de la magazinul ala Edit: Am mai vazut 2 posturi: unul cu 67, unul cu 100 RON .. Edited August 3, 2006 by dobrescucris Link to comment
AAdorjan Posted August 3, 2006 Share Posted August 3, 2006 Pe autodaewoo.ro sunt pretul este 30ron-37ron. Link to comment
dobrescucris Posted August 3, 2006 Share Posted August 3, 2006 (edited) Am vazut inainte sa ma duc la service Dar mai e si transportul, plus ca comanda minima e de 100 RON, plus ca mai dura ceva pana ajunge. Important e ca mi-am rezolvat problema, si sper sa tina PS: O sa tin cont de magazinul din Sebastian, sa caut prin posturi exact unde e.. Edited August 3, 2006 by dobrescucris Link to comment
classalexx Posted August 4, 2006 Share Posted August 4, 2006 Aveti idee cat costa un alternator bun,la mana a doua? Link to comment
ovi_jer Posted August 4, 2006 Share Posted August 4, 2006 Nu mai cita mesajele anterioare si foloseste functia daca de citit nu citesti ce s-a discutat pe aici. 200 ron aici : http://www.autodaewoo.ro/dezmembrari.php Link to comment
classalexx Posted August 7, 2006 Share Posted August 7, 2006 (edited) Ce nemernici,acum cateva zile,am fost la un service,si mi-au diagnosticat alternator stricat,care nu incarca,si pret de schimbare,,intre 6 milioane si 9.Am spus ca revin,si am verificat bateria,care era super incarcata.la Am fost la electrician cu ea,si alternatorul nu avea nimik,mi-a schimbat starterul din electromotor,si merge brici.1mil1suta starteru,si 5sute manopera.Adresa este Baicului nr 116,i-i recomand cu caldura.Oare ce merita jepcarii astia,care daca vad ca nu te pricepi,iti fura efectiv banii din buzunar.? Edited August 7, 2006 by ovi_jer Link to comment
