Salex Posted June 2, 2008 Share Posted June 2, 2008 Lasa codurile cind nu esti constrins. Gasesti Man, Bosch, Purolator si alte filtre bune care, evident, nu o sa iti apara pe cod de GM. Du-te la orice magazin si cere filtru bun de Leganza. Nu ar trebui sa sara de 15 RON Link to comment
chris0500 Posted June 2, 2008 Share Posted June 2, 2008 Am fost la 2 magazine in Militari. Unul nu avea nimic de leganza, trebuia sa astept comanda, altul mi-a zis ceva legat de cod, ca sunt 2 tipuri in fc de sasiu (nu aveam talonul la mine). Pretul era undeva in jur de 30-40 ron. Maine mai caut si la alte magazine. Link to comment
ovi_jer Posted June 2, 2008 Author Share Posted June 2, 2008 Cauta de matiz sau nubira Link to comment
smailmiami Posted June 2, 2008 Share Posted June 2, 2008 De Matiz, dar vezi sa fie din acelea cu cleme. Link to comment
chris0500 Posted June 7, 2008 Share Posted June 7, 2008 Filtru ulei Mann 11 ron Filtru benzina 30 ron Ulei Castrol 5w40 4l 125 ron Pompa apa 110 ron vas expansiune 31 ron Link to comment
Salex Posted July 25, 2008 Share Posted July 25, 2008 Chedere usa stinga fata : 50 + 70 + 35 = 155 RON Burduf antipraf - protectie amortizor = 25 RON Bucsa bara stabilizatoare fata = 5 RON/buc Bucsa bara stabilizatoare spate = 5 RON/buc Parbriz + cheder + montaj = 515 RON, 2 ani garantie, geam Pilkington Suport din cauciuc pentru arc fata = 15 RON/buc Link to comment
Salex Posted July 28, 2008 Share Posted July 28, 2008 Pentru chiper_dan[b/], cu dedicatie : toba mediana : cca 150 RON Bloc contact electric : 30 RON Edit pentru postul anterior : - Protectiile antipraf amortizor au venit la 20 RON/buc - Inel de cauciuc suport arc amortizor fata a venit la 8 RON/buc Link to comment
Miste_R Posted August 7, 2008 Share Posted August 7, 2008 (edited) Set amortizoare Monroe - 600 RON Edited August 7, 2008 by Miste_R Link to comment
iulian.bodo Posted August 9, 2008 Share Posted August 9, 2008 caut bloc motor ptr leganza...sau chiar motor intreg...poate sa imi dea careva ceva informatzii pe unde pot gasi? Link to comment
Salex Posted August 9, 2008 Share Posted August 9, 2008 Pentru Bucuresti, iti pot da eu niste relatii. Daca esti interesat, scrie-mi un PM Link to comment
iulian.bodo Posted August 18, 2008 Share Posted August 18, 2008 Salex said: Pentru Bucuresti, iti pot da eu niste relatii. Daca esti interesat, scrie-mi un PM gata s-a rezolvat ...multzumesc mult ptr informatzii... Link to comment
Salex Posted August 20, 2008 Share Posted August 20, 2008 Sa mai pun si eu niste preturi pentru piese de Leganza : - vas expansiune : 40 lei - articulatii bara stabilizatoare fata (bielete anti-ruliu) : 55 lei/buc - ax cu came admisie/evacuare : 500 lei/buc - simering pompa ulei (palier mic) : 30 lei - simering palier mare : 50 lei - bloc contact electric : 30 lei - cuzineti biela Kolbenschmidt : 100 lei Link to comment
chiper_dan Posted August 26, 2008 Share Posted August 26, 2008 salutate merci mult Salex asadar toba mediana 170 lei ., toba finala - nu stiu firma 400 lei , senzor abs stanga 110 lei , cel pe dreapta ca intre timp a murit si ala , adica e firul intrerupt 120 de lei , arcurile 85 de lei pe fata . Nu stiu firmele .Cumparate cu garantie si schimbate in service , unele inca nu , dar urmeaza !!!! Link to comment
Salex Posted October 21, 2008 Share Posted October 21, 2008 A cumparat cineva recent sau stie cineva un pret de actualitate pentru Traversa suspensie fata A (adica punte/semi-punte fata ) ? Am gasit intr-un singur loc la 750 RON si lipsa de concurenta ridica semne de intrebare ! Link to comment
smailmiami Posted October 21, 2008 Share Posted October 21, 2008 Ala e pretul corect ... Iti dai seama ca nu mai aduce nici dracu asa ceva ... Dar cum s-a intamplat sa ai probleme la puntea fata ? Sau mai bine zis, esti sigur ca ai probleme la acolo ? Link to comment
Salex Posted October 21, 2008 Share Posted October 21, 2008 Puntea e OK insa virsta si drumurile bune si-au spus cuvintul asupra celor 4 bucsi ... Cum astea nu se pot schimba, ergo, treuie sa schimb toata puntea Link to comment
smailmiami Posted October 21, 2008 Share Posted October 21, 2008 Mda, m-am gandir, dar am zis sa intreb totusi. Erau unii prin Craiova care ziceau ca repara asa ceva, dar mira-m-as sa iasa ceva calitativ ... Ce simptome prezinta ? Link to comment
Salex Posted October 21, 2008 Share Posted October 21, 2008 Si daca m-ar costa 100lei reparatia fata de 750, tot pe varianta noua as merge Deocamdata nu are simptome, pur si simplu am desfacut suruburile de la bucse si am observat cauciucul acestora cam crapat si, asa cum ziceai si tu, sint piese din ce in ce mai greu de gasit. Nu as vrea la anul sa dau 1500-2000 lei pe acelasi lucru Link to comment
madkat Posted October 21, 2008 Share Posted October 21, 2008 hai ca aicea am ramas masca... deci trebuie schimbata puntea din cauza unor bucsi??? sau prin semipunte intelegi de fapt o 'bascula" ? stiu ca e oleaca offtopic - dar as vrea sa inteleg sisitemul de supensie... Link to comment
Salex Posted October 21, 2008 Share Posted October 21, 2008 (edited) Pe o bascula ultima data am dat 260 lei. fftopic: Bascula nu e acelasi lucru cu semi-puntea si da, pentru niste bucsi trebuie sa o schimbi . Daca vrei mai multe detalii, scrie-mi un PM. Edited October 21, 2008 by Salex Link to comment
smailmiami Posted October 21, 2008 Share Posted October 21, 2008 Bucsile alea sunt turnate, nu se gasesc separat ... Link to comment
Salex Posted October 31, 2008 Share Posted October 31, 2008 Pina la urma am luat-o pe aia la 750 lei, nu am mai cautat in alta parte. Montajul + geometria au mai fost 400 lei. Link to comment
Dumitru Cristian Posted October 31, 2008 Share Posted October 31, 2008 fftopic: Motanjul si geometria a fost 400 ron??!!!!!!!! Da cu ce strang aia suruburile?! Cu chei dinamometrice din aur?! Link to comment
smailmiami Posted October 31, 2008 Share Posted October 31, 2008 E vorba de montajul semipuntii fata. Link to comment
Engine Posted November 11, 2008 Share Posted November 11, 2008 Curea de distributie Gates PowerGrip = 67 lei. Rola ghidaj = 43 lei. Intinzator curea = 100 lei. Pompa de apa = 93 lei. Pe www.autodaewoo.ro Link to comment
