zalmoxis Posted March 16, 2004 Share Posted March 16, 2004 Bey puneti-va Champion la bujii!!! Link to comment
FLEX Posted March 16, 2004 Share Posted March 16, 2004 Da' de ce? tu ai avut Bosch si ai trecut la Champion? detaliaza, te rog ... Link to comment
zalmoxis Posted March 16, 2004 Author Share Posted March 16, 2004 deci am Bosch si ma ceva pe ele ca-mi tremura tot timpul !Odata le-am reglat (aveam 2mm la electrozi) au mers bine un timp acum iar de kko!..Toti mi-au zis Champio sunt bune!!!..Pana mea ca le-as pune sinterom dk ar face alea-s bujii mai !!! Link to comment
sprite Posted March 17, 2004 Share Posted March 17, 2004 ...poate gasiti Bosch super 4 (4 electrozi). Am avut, dar nu pe Matiz, din pacate... Sunt criminale, mergi de te doare-n pix! Nu se regleaza si tin de te plictisesti... Am fost foarte incantat de ele. Link to comment
NFS Posted March 17, 2004 Share Posted March 17, 2004 Extras din manualul de intretinere si reparatii Matiz (ala de la editura KSI): Bujii recomandate pt automobilul Matiz: Producator / Tip bujie Woojin, NGK / BPR6ES Champion / RN9YC AC Delco / CR42CXLS Bosch / WR8DCX Iskra / FE65PRS (normal ca alea coreene sunt primele) La toate aceste tipuri de bujii distanta dintre electrozi trebuie sa fie 1,1 mm Link to comment
lalexis Posted March 17, 2004 Share Posted March 17, 2004 :?: Stiam ca le Matiz sunt Champion RN9YC4 (benzina fara plumb, 1,1 mm). Champion RN9YC sunt pe Tico (benzina cu plumb, 0.8 mm). Care sunt pina la urma pt. Matiz, ca sunt in ceata? De asemenea stiu ca YC4 sunt si la Espero. Link to comment
NFS Posted March 17, 2004 Share Posted March 17, 2004 Nene, eu am redat ce scrie in cartea de Matiz. N-am pus de la mine (decat fraza cu zimbetu ). Nici din auzite. Link to comment
lalexis Posted March 18, 2004 Share Posted March 18, 2004 Ce manual de utilizare ai? La mine in manual scrie de Champion si NKG. Atit!? Link to comment
NFS Posted March 18, 2004 Share Posted March 18, 2004 Quote Ce manual de utilizare ai? La mine in manual scrie de Champion si NKG. Atit!? Vezi aici: http://www.ksi.ro/do/bookdetails?carte_id=1 Manual Matiz Link to comment
strumfuadi Posted March 26, 2004 Share Posted March 26, 2004 Mergeti pe Champion! Eu am avut pe Reno Beru, Bosch, AC Delco... Mergea totul OK, insa cand intra turbina se ducea dreaq totul, dadea nishte trepidatzii de ziceam k se rupe. Am verificat aprinderea electronica, fishe, presostatul de taiere a alimentarii de la turbo , alimentare, tot... nimic.. Pana a zis mandea sa puna bujiile date in manual (Champion N3G - platina). Am dat 520mii per bucata anul trecut in iunie, dar din acel moment am alt motor: trage de rupe pana la 5500rpm unde intra limitarea.. Mentiune 1: toate celelalte bujii erau din cataloagele marcilor respective pentru modelul meu de reno, asha k erau de kko, ce sa mai.. Mentiune 2: puneti ce scrie in manual, nu o sa va dezamageasca (Champion) Numai bine! 1 Link to comment
lalexis Posted April 5, 2004 Share Posted April 5, 2004 Ajutor!!! Sunt in ceata. La mine in manualul de utilizare scrie RN9YC4 si mecanicul zice ca merg mai bine RN9YC. Cea mai misto faza este ca nu am gasit nicaieri in Iasi RN9YC4. Mai misto. M-am dus la magazin si am cerut bujii de Matiz. Mi-au dat RN11YC4. Aveti idee daca merg si astea? Voi ati vazut vreodata RN9YC4? Link to comment
lalexis Posted April 5, 2004 Share Posted April 5, 2004 Mi-a cazut azi in mina cel mai tare catalog Bosch de bujii. E misto de tot. La Matiz da asa: Bosch normale...WR8DCX (1,1 mm) Bosch Super 4 (4 electrozi) 130.000/buc...WR78X Bosch Super Plus (platina)........................................WR8D+X Tot in acest catalod da echivalent pentru Bosch WR8DCX: Champion...RN11YC4 (nu RN9YC4 care apare ca recomandare in cartea Matizului si care corespunde cu WR7DCX de la Bosch) AC Delco...R44XLS-11 Beru...0002330702 NGK...BPR5EY-11 NipponDenso...W16EXR-U13 Link to comment
sprite Posted April 5, 2004 Share Posted April 5, 2004 Quote Mi-a cazut azi in mina cel mai tare catalog Bosch de bujii. E misto de tot. La Matiz da asa: Bosch normale...WR8DCX (1,1 mm) Bosch Super 4 (4 electrozi) 130.000/buc...WR78X Bosch Super Plus (platina)........................................WR8D+X Omu' zii si mie un punct de vanzare pt Bosch super 4, ca pe la Metro, Carrefour & Co nu mai exista... Si pe la benzinarii la fel... Agipu' avea super4, da' demult! Vezi si tu p-acolo ca poate e o adresa, ceva... Mersi! Astept incordat! Link to comment
strumfuadi Posted April 5, 2004 Share Posted April 5, 2004 Alemar (Bosch) 313.11.70 Locatzie: Prima pe dreapta cum treci de piatza Pache Protopopescu venind de la ProTv shi mergand spre Moshilor.. Link to comment
sprite Posted April 5, 2004 Share Posted April 5, 2004 Mersi! Da' sigur ala nu e magazin de bormasini, surubite si polizoare? Link to comment
strumfuadi Posted April 5, 2004 Share Posted April 5, 2004 Ma mai gandesc, poate o fi.. Acuma pe bune, eu doar de acolo am cumparat bosch (filtru benzina) shi mai au shi alte marci (Ferodo, etc...) Sunt dealeri directi ... Link to comment
lalexis Posted April 6, 2004 Share Posted April 6, 2004 Mah, sunteti criminali :!: Ce cautati la Metro si la benzinarii?? Cit e de mare Bucurestiul nu aveti un magazin mare de piese auto? De piese, nu de plastice si televizoare ca Metro :!: Daca nu gasiti va trimit eu de la Iasi. Este un magazin numai de consumabile. Gasesti orice bujie, filtru, etc. Link to comment
sprite Posted April 6, 2004 Share Posted April 6, 2004 Gata! Am comis-o si pe asta! Bosch super4 WR78X, pret 178.000 rol/buc. Adjudecate acu' 5 minute! Pentru consultatii tehnice uitati aici catalogul: http://www.bosch.com.au/productcatalogue/s..._commercial.pdf si... cum sa "cititi" cum va merge motorul dupa aspectul bujiilor: http://www.bosch.com.au/productcatalogue/s...kplug_faces.pdf Link to comment
sprite Posted April 12, 2004 Share Posted April 12, 2004 Baietii! Am montat bujiile. Sunt meseriase! Porneste nitel mai bine (un pic mai repede!), motorul merge mai rotund, te ajuta cand e nitel subturat, iti da senzatia ca e cuplul nitel mai jos, mai ales cand pleci de la stop (n-are cum, da' asta-i senzatia - raspunde foarte misto la acceleratie), pe scurt - motorul e mai vioi. Bujiile vechi (originale) erau, ca si la voi, tot Bosch - aratau bine, distanta era buna... @ Flex: Nu mai imi tremura scaunul din dreapta! Link to comment
danuzz Posted April 13, 2004 Share Posted April 13, 2004 Quote Baietii! Am montat bujiile. Sunt meseriase! Porneste nitel mai bine (un pic mai repede!), motorul merge mai rotund, te ajuta cand e nitel subturat, iti da senzatia ca e cuplul nitel mai jos, mai ales cand pleci de la stop (n-are cum, da' asta-i senzatia - raspunde foarte misto la acceleratie), pe scurt - motorul e mai vioi.Bujiile vechi (originale) erau, ca si la voi, tot Bosch - aratau bine, distanta era buna... @ Flex: Nu mai imi tremura scaunul din dreapta! Bosch super4 WR78X sunt reglate la 1,1 mm? Si mie a inceput sa-mi tremure scaunul din dreapta! :cadelnita: Link to comment
sprite Posted April 13, 2004 Share Posted April 13, 2004 Distanta la electrozi e reglata din fabrica. Nu umbli la ele, le pui asa cum sunt. Link to comment
danuzz Posted April 14, 2004 Share Posted April 14, 2004 Quote Distanta la electrozi e reglata din fabrica. Nu umbli la ele, le pui asa cum sunt. Asta inseamna ca sunt deja reglate la 1,1? si spui ca dupa ce le-ai schimbat merge mai bine si, cel mai important, nu-ti mai vibreaza scaunul din dreapta? Ca daca e asa ma duk sa iau si eu azi 3 bujii. PS dau si la bucata? sau trebuie sa iau un set de 4? Link to comment
strumfuadi Posted April 14, 2004 Share Posted April 14, 2004 fratzilor, putem sa le punem shi kerosen shi gaz de lampa.. tot va trepida.. e motor in 3 cilindri, ce naiba, fara arbori de echilibrare... uitatzi'va in partea stg pe langa roata cum trepideaza motoru' la relanti pe tamponul ala... cred k tamponu ar trebui schimbat la 1-2 ani.. am luat mashinutze cu 3 cil. shi vrem sa le facem sa mearga ca un V12?? rezon.. Link to comment
zalmoxis Posted April 14, 2004 Author Share Posted April 14, 2004 alo o fi in trei cilindri da'e in patrui timpi...nu are voie sa trepideze!!!!!!! Link to comment
strumfuadi Posted April 14, 2004 Share Posted April 14, 2004 ete nah...d'aia au pus marcile serioase pe motoare de 4 cilindrii (in 4 timpi, obviously..) arbori de echilibrare, nu?? in zadar, huh?? Link to comment
