gore1979 Posted December 13, 2007 Author Share Posted December 13, 2007 Am schimbat Camshaft Position Senzor(pret 80 ron) , si a disparut eroarea 342. Acum masina porneste la cheie. Link to comment
perfidus Posted December 13, 2007 Share Posted December 13, 2007 Am schimbat senzorul lichid racire(ECT), si au mai ramas doar 3 erori:dP0141-HO2S Heater Circuit Bank 1 Senzor 2(?) P0342-Camshaft Position Senzor Circuit Low Voltage(?) P1661-Led-ul Check Engine Ars Si cu asta mai aveti inca doua... si tot asa, va apuca Craciunul. Cu sonda lambda defecta poate porneste dar va consuma ca la balamuc. Link to comment
gore1979 Posted December 13, 2007 Author Share Posted December 13, 2007 A consumat 5.5 la drum lung. Sambata sper sa fac rost de o sonda de la un user de pe acest forum si sa rezolv problema. Link to comment
gore1979 Posted December 14, 2007 Author Share Posted December 14, 2007 In incercarea mea de a mai repara ceva, de unul singur, am cumparat o supapa purjare matiz euro 3, P0444 EVAP PURGE CONTROL CIRCUIT NO SIGNAL , am schimbat-o dar nu am rezolvat nimic, eroare ramane. Ce nu inteleg la scannerul asta mic si galben, ce vrea sa zica 3 pending error(444/404/1661), nehotarat/in suspensie/nedecis? Multumesc. Link to comment
tolin Posted December 14, 2007 Share Posted December 14, 2007 Scoate siguranta de la ECM, apoi scoate conectorul de la ECM, apoi il pui la loc si la sfarsit pui la loc siguranta de la ECM. Vezi ce-ti spune scanerul dupa asta. Link to comment
gore1979 Posted December 31, 2007 Author Share Posted December 31, 2007 Am schimbat Sonda Lamda, no2, cea de pe mijlocul masinii, si eroarea P0141 Rear Heated Oxygen Sensor Heater Malfunction, Nu a disparut. Ar putea fi de la catalizator...? Stiu, ar trebui sa ma duc la un service autorizat Multumesc. Link to comment
tolin Posted December 31, 2007 Share Posted December 31, 2007 (edited) Poate fi afectat cablul (este foarte expus acolo), trebuie verificat de catre cineva cu oarece cunostiinte electrice. Ti-am dat un sfat in postul anterior, simplu de urmat. Ai prea multe erori, poate a umblat cineva la conectorul general al ECM-ului si nu l-a pus bine la loc ! Edited December 31, 2007 by tolin Link to comment
gore1979 Posted January 10, 2008 Author Share Posted January 10, 2008 Multumesc tolin, pentru suport. Se pare ca am Valva EEGR blocata pe deschis, si as vrea sa o scot de acolo sa o curat putin. Daca a mai curatat cineva valva, imi poate spune si mie cum se scoate cel mai usor, din pacate ma impiedica conductele de la vasul cu lichid de frana, si altele pe acolo. Am atasat poze. Link to comment
perfidus Posted January 10, 2008 Share Posted January 10, 2008 Ce nu inteleg la scannerul asta mic si galben, ce vrea sa zica 3 pending error(444/404/1661), nehotarat/in suspensie/nedecis?Multumesc. Pending = in desfasurare/ in curs Si eu cred ca sunt in continuare probleme la cablaj. Aveti idee daca masina a fost lovita? PS: 5,5% consum iarna la drum intins e cam mult dar nu exagerat de mult. Link to comment
gore1979 Posted January 10, 2008 Author Share Posted January 10, 2008 (edited) Categoric a fost lovita. Am sa cumpar alta valva(aproximativ 290 ron), dar vroiam sa o scot pe cea de pe masina, sa o curat putin, poate se rezolva ceva. Din cate am observat conductele de la vasul cu lichid de frana sunt deranjate, si nu prea am acces acolo... se potriveste o cheie de 12" M-ar ajuta o poza de la un matiz euro 3, cu zona in pricina daca se poate. Multumesc. Edited January 10, 2008 by gore1979 Link to comment
scorpion Posted January 10, 2008 Share Posted January 10, 2008 Nu incerca sa umbli la conductele de frina singur . Cu o cheie fixa nu reusesti decit sa strici hexagonul piulitei conductei de frina , iar daca totusi reusesti sa o desfaci ( ceea ce nu cred ) , trebuie aerisit circuitul de franare . Link to comment
gore1979 Posted January 10, 2008 Author Share Posted January 10, 2008 Pe mine ma interesa doar cum sunt aranjate, am observat ca le poti indoi cat de cat cu mana.Ma interesa o poza, ca sa vad exact cum sunt puse, pentru ca se pare ca masina a fost reparata in repezeala, fara simt de raspundere. Link to comment
gore1979 Posted March 21, 2010 Author Share Posted March 21, 2010 imi poate trimite cineva manual, in engleza, cel care contine si codurile de eroare!!! linkul nu mai este bun merci Link to comment
gore1979 Posted March 22, 2010 Author Share Posted March 22, 2010 am gasit, exact ce cautam, cine are nevoie sa imi spuna Link to comment
