tc0fh Posted October 18, 2007 Share Posted October 18, 2007 Salutare! Exista un soft pentru conectare la ECM-ul din Matiz-ul Euro 2 sau Hyundai Coupe 2000 (Fenix 5)? Din cate am citit pe forumuri, atat Matiz-ul cat si Hyundai-ul Coupe 2000 fabricat pentru Romania folosesc acelasi ECM. la http://monitor.missme.ro/hyundai gasiti poze cu ecm-ul si cu un schemele electrice pentru ECM-ul de la Elantra 96. Veti vedea ca sunt foarte asemanatoare cu cele de la Matiz. A reusit cineva? Link to comment
lucay Posted January 6, 2008 Share Posted January 6, 2008 salut! sunt foarte interesat si eu de conectarea la ECM, din pacate pentru Matiz E2 vad ca nu sunt variante pana acum Link to comment
three6t Posted November 14, 2008 Share Posted November 14, 2008 Please Keep on posting What is protocol of Matiz Euro 2 (Fenix 5 MR)? Link to comment
udrescu ion Posted December 1, 2008 Share Posted December 1, 2008 Matiz - Manual Service EN DATA LINK CONNECTOR DIAGNOSIS Circuit Description The provision for communicating with the Engine Control Module (ECM) is the Data Link Connector (DLC). It is located under the instrument panel. The DLC is used to connect the scan tool. Battery power and ground is supplied for the scan tool through the DLC. The Keyword 2000 serial data circuit to the DLC allows the ECM to communicate with the scan tool. A Universal Asynchronous Receiver Transmitter (UART) serial data line is used to communicate with the other modules such as the Electronic Brake Control Module (EBCM), the Supplemental Inflatable Restraint (SIR) system. and the Instrument Panel Cluster. Link to comment
tolin Posted December 1, 2008 Share Posted December 1, 2008 three6t said: ... What is protocol of Matiz Euro 2 (Fenix 5 MR)? Read the question, before ! Link to comment
