Daewoo Espero From Croatia
ViperZG
Hi, my name is Vedran , I am from Croatia and I drive a 97' Daewoo Espero
So here it is..
it was like this before I got my hands on it
I bought some new rims, from factory 185/65/14 I went to 215/35/18 :drinkers:
I had to put some track spacers on the rear axle , 2cm on each side
but then it was normaly very high :wallbanger: , it looked like a monster truck
so , I ordered Eibach springs -30mm for it, but by mistake they gave me -30mm for Nexia , and it lowered the front about 70mm and the rear about 40mm , I was very pleased :thumbl:
that was it for a while..
then the project started > :)
because of the big rims, the rear brakes looked silly , so I got the rear axle from a Vectra 2.0
first I dissasembeled it..because it was rusty and didn't work ..
By ViperZG
I got rid of all the rust and painted it in mat black
By ViperZG
the callipers were repaired , fitted with new parts..
By ViperZG
old vs. new discs
By ViperZG
new discs painted in mat black
By ViperZG
all new parts fitted and assembeled
By ViperZG
old vs. new axle
By ViperZG
after a while driving and parking , I scratched a rim , so I decided to repair them and paint them
painted the inside in mat black
By ViperZG
very carefully I had to tape the rim to be painted
By ViperZG
the rims repaired and painted
By ViperZG
on the car with the new disc :mrgreen:
By ViperZG
then it was the cars turn, so I started do take it apart
By ViperZG
By ViperZG
By ViperZG
and ready for some bodywork
By ViperZG
By ViperZG
By ViperZG
progress
all the signes are removed from the car, the frot is given a bad look , the rear is changed , rust is fixed , fenders are pulled out etc.
By ViperZG
By ViperZG
and the new rear spacers, 3cm per side
By ViperZG
By ViperZG
  • Replies 62
the front bad look
By ViperZG
By ViperZG
By ViperZG
By ViperZG
By ViperZG
and finally ready for a little trip
By ViperZG
By ViperZG
The car was then driven 100km like that
The custom front and rear bumper are being made at the moment , as well as the custom sideskirts and rear wing, I expect it to be finished and painted by the end of the week, so till the next report ...
ViperZG
First of all, i'm glad to be the first to tell you welcome. It is quite a pleasure viewing a man so decided to improve a Daewoo car. I think you have gone far more than the other members of this forum, regarding a modified Espero. Keep up the good work and i'm lookink forward to see your car finalized.
Welcome and congratulations on a hard and well done job!!
I am really impresed to see what amount of work you had with this car. I like it that you've done everything so clean and nicely worked.
Be sure to keep us posted on every progress you make, don't abandon this forum, ok?
Cheers! ;)
Welcome to our forum!
Your hard work on this car is indeed impressive! I'm curious about how the rear will look, once it's painted. The rims are insane :)
well the bad look had to be like that because of the front bumper..
here is a preview pic..
By ViperZG
and for the engine, when the car is finished on the outside I plan to swap a Opet 2.0 16V , also known as C20XE ..
Edited by ViperZG
The eyelids need a little "touch". They are not simetrical isn't it? I expect the paint for further comments (or a brighter picture) . Until then, keep it up.
Edited by Dj_Dark
WOW! an ESPERO to admire.
Works like this continue to inspire me on my Espero.
got answers to my questiions. i have been wondering ever since if there is an Eibach for Espero (can you help me on the model name/number?).
and also the long wheel stud/screws. i have been planning to use wheel spacers but my problem was if i will be able to find a long stud to compensate for the spacers. Now i know that there exists one. I just need to know how/where to get them (help again pls :) )
Here's my Espero. appreciate your comments. MY ESPERO
Many thanks!
Many thanks!
Hi , and thanks..
I saw your espero a long time ago on cardomain I think..its very good..
I dont know the code number for the spring, I just ordered for Espero, and the springs for nexia came..it just fell a little more..
if you cant find it you can also take the springs of an opel kadett..
and the weell spacers..there are bolts for 2cm spacers..I have 3 cm spacers and i have 8 bolts per wheel , 4 fasten the spacer to the hub, and the other four then fasten the wheel to the spacer ..
@Gamerul,
Thanks for the info! finally i got the part no. :D I just hope it would be available at our local distributor.
@Viper,
Thanks also. just please keep us posted on your espero project. can't wait for the final result :)
meanwhile, i'll think of more questions to consult to you. :D
@Gamerul,
@Viper,
@King_3
I do really admire the pics of the espero its great, king can i ask you where did you get the spare parts of your espero since i know that you are in the philippines, im from laguna and i hard time to look for spare parts for my espero, m looking forward that you can help me, here is my email add jonathanalvarez7@gmail.com hope you can share too the english version of service manual. thanks
@King_3
sent you a PM. Let's not hijack Vipers thread :)
The butt looks ... big :) hope you'll manage to pull something similar to Acura TSX's behind, which is big, but very good looking. Otherwise, I must understand your roads are in very good condition, since you're lowering the car so much.
no , the roads are very bad actually :mrgreen: , but I dont mind..its not so low , the front is 12 cm and the rear 15 cm ..plenty of roam..
the car is going to be in pearl white , and the diffuser on the back is going to be painted in mat black.. i still have to mount an exhaust pipe in the midlle..
I really hope you will add an engine to fit the "angry" exterior. Well done ! I can't say I'm a big fan of the new front and back bumpers but I do appreciate the work and money invested in this car. Keep it up !
Here are some new pics
They were taken 5 minutes after I brought it home, so please dont tell me that the parts "dont fit" because I know..they were onli put on the car for the photos, I will assemble it tommorow..
By ViperZG
By ViperZG
By ViperZG
and the exhaust
By ViperZG
By ViperZG
the diffuser will be paintet in mat black on tuesday , or wednesday, and then I will put the exhaust on drunk.gif
Edited by ViperZG
The boot lid doesn't fit :) ) just joking.
The pearl white paint looks great, in my opinion. You're going to paint black the whole diffuser, or just the "contoured" area ?
