Matizel Posted September 11, 2006 Share Posted September 11, 2006 Da pot confirma si eu din surse confidentiale : FERITI-VA DE PETROM !! Ce parere aveti despre Agip Eco Premium pt Matizoi? O fi din grupa benzinelor asa zis Euro? Am pus de 500.000 si parca nu se mai termina. E cam saraca la cifra octanica (la mers subturat parca are motoru tremurat) iar cand pun de la Rompetrol merge ca un vis da se consuma instantaneu Link to comment
Tommy Posted September 11, 2006 Share Posted September 11, 2006 Ia toarna domnule sursele alea confidentiale Ca la mine zboara cu petrom 99! Link to comment
tolin Posted September 11, 2006 Share Posted September 11, 2006 Tu nu mergi subturat (din sursa sigura ce nu doreste sa-si pastreze anonimatul). Link to comment
Zmeul cel rau Posted September 11, 2006 Share Posted September 11, 2006 Ia toarna domnule sursele alea confidentiale Ca la mine zboara cu petrom 99! Subscriu! N-a mers niciodata mai bine cu vreo benzina (nici din tara nici din afara). Poate cu fostul Shell 95+. Link to comment
Esperatul Posted September 11, 2006 Share Posted September 11, 2006 (edited) La mine cand am pus Petrom 99 am zis ca raman in drum, nu stiam ce are pe benzina. Statia de pe Independentei de la Unirii spre Eroilor. Acum cu MOL 95 si-a revenit. Never again Petrom. Edited September 11, 2006 by Esperatul Link to comment
midnight_racer Posted September 12, 2006 Share Posted September 12, 2006 Poate din cauza ca la tine scrie 1,8D in profil si poate trebuia sa treci pe la pompa cu maner negru(diesel)... Link to comment
Englishman Posted September 13, 2006 Share Posted September 13, 2006 (edited) Pai ce va spusei io ? petrom 99+ = OMV super 100 ! Exact aceiasi marfa. ( de obicei, buna..) Edited September 13, 2006 by radux Link to comment
entaro79 Posted September 13, 2006 Share Posted September 13, 2006 Am testat pana acum cam toate benzinele si cred m-am oprit la cea MOL 95 Parerea mea este ca cel putin d.pd.v al benzinei CO95 ,cea de la MOL este cea mai buna alegere,va rog sa le comparati: mol 95 http://www.molromania.ro/ro/produse/carbur...mpo_plus_95_98/ petrom 95 http://www.petrom.ro/romana/produsepdfro/B...5_500%20ppm.pdf rompetrol 95 http://www.rompetrol.ro/oil_gas/products/f...%20Gasoline.pdf sincer mie mi se potriveste perfect mol 95(iar daca pun putini aditivi pentru cifra octanica,nu va fi nici o diferenta fata de cea petrom99+ ...vezi specificatiile) P.S petrom 95 e penala Link to comment
speedygonzales Posted September 15, 2006 Share Posted September 15, 2006 Desi sunt incepator si nu pot sa zic k am reusit sa incerc toate benzinariile dar am si eu o parere. Am bagat benzian de la MOL cel care e la iesirea din bucuresti sper A2. pe autostrada singur la 125 tremura masina k dracu. Asta era acum o luna. Vinerea trecuta am facut acelasi drum. plinul l-am facut la rompetrol ciurel. Pe A2 la 135 nu mai putea si tremura ingrozitor. Duminica m-am si intors si am facut plinul din costanta tot de la rompetrol. Am mers si cu 145 fara sa simt ceva trepidati majore, doar motorul care tragea din greu. Am mers constant 140, mai incetineam cateodata dar oricum am mers multi km cu 140 si am TICO. Am tot citit pe aici si vad k nu sunt singurul care considera benzina din constanta in general fffff buna. >- Link to comment
CristiP Posted September 15, 2006 Share Posted September 15, 2006 Asta vara cand m-am intors de la mare (Constanta) am bagat si eu tot de la Rompetrol, eu sunt client Petromv de pe I.Maniu, am fost foarte multumit, eram 4 persoane in masina, AC pornit in treapta 2 si la 140 doar motorul se auzea. La vreo doua saptamani am bagat tot de la Rompetrol, de la Ghencea, jalnic, pe A1 am mers foarte prost, abia tragea, de atunci doar daca mai ajung la Constanta mai bag de la Rompetrol. Link to comment
dreaQ Posted September 15, 2006 Share Posted September 15, 2006 Am testat pana acum cam toate benzinele si cred m-am oprit la cea MOL 95 Parerea mea este ca cel putin d.pd.v al benzinei CO95 ,cea de la MOL este cea mai buna alegere,va rog sa le comparati: P.S petrom 95 e penala Mai oameni buni tine de la statie la statie. Angajatii de la anumite statii de carburant chiar nu se iau de pe documentele PDF.. )"> In functie de zi baga mai multa sau mai putina apa. Credeti-ma ca asa este. Stiu eu pe cineva dar imi este prieten si nu pot sa spun.. "> Link to comment
tolin Posted September 15, 2006 Share Posted September 15, 2006 Benzina nu se amesteca cu apa. Link to comment
rm.popa Posted September 15, 2006 Share Posted September 15, 2006 (edited) Voi, toţi cei care ştiţi de la prieteni că benzinarii îşi amestecă marfa cu apă, ar trebui ca împreună cu prietenii să luaţi o juma' de benzină, să o turnaţi într-o oală şi apoi să turnaţi şi apă să vedeţi ce (nu) se întâmplă. Aaa... şi să nu uit: oala n-o puneţi pe foc, că tot nu se amestecă! Gândiţi-vă la faptul că petroliştii pompează în punga de petrol apă, care se lasă la fund, pentru a scoate petrolul. Şi mai gândiţi-vă că după accidentele petrolierelor locul se izolează şi se curăţă. Păi, dacă s-ar amesteca petrolul cu apa, credeţi că s-ar mai deranja cineva să facă curăţenie? Sigur, o să ziceţi că petrolul nu e tot aia cu benzina, aşa că las chimiştii să explice ştiinţific problema... Acum, sigur, dacă e unul nebun să pună apă în rezervorul staţiei, nu-l poate împiedica nimeni. Doar că s-ar putea ca prin pompă să curgă doar apă, sau doar benzină, în funcţie de cum vă e norocul să fie poziţionat pe rezervorul staţiei punctul prin care trage pompa. Edited September 15, 2006 by rzvpopa Link to comment
el cid Posted September 15, 2006 Share Posted September 15, 2006 In tancurile din benzinarie exista apa si din cauza condensului. Stiu asta de la cei care curatau periodic aceste tancuri. Mai apar unii intreprinzatori cu galeata de apa ca sa-si justifice litrii " palmati"( la cantitate ma refer). Cat despre amestec apa- benzina , stiu ca afecteaza intr-o mica- mare masura calitatea. Am vazut la viata mea gheata in pompa de benzina. E drept , era dacia dar totusi se poate. Cat despre tico, pot sa va spun ca am patit-o iarna, sa faca dop de gheata pe conducte si sa ajung la destinatie dupa 50-60 de km de dat la automat . De aceea iarna alimentez cu cel mai bun carburant si mai adaug putin "stimulent" 2+2 care se gaseste in benzinarii. Nu vreti sa stiti cum e cand "tuseste" motorul si tu esti in plin camp inghetat, soarele apune, afara sunt -15 si mai ai pana acasa vre-o 60 km. Blestemi benzinarul din 2 in 2 secunde. Si asta sa intamplat doar cand am alimentat de la un anumit Shell din Cluj. Aveam card Shell si am ajuns sa alimentez doar dintr-o anumita pompa fiindca se simtea teribil diferenta de calitate intre aceste benzinarii. Link to comment
adostar Posted September 21, 2006 Share Posted September 21, 2006 Care este cea mai buna benzina pentru tico ? Eu alimentez de la MOL cu ECO Premium 95. Link to comment
dreaQ Posted September 21, 2006 Share Posted September 21, 2006 Eu nu bag numai de la o anumita retea. Bag si de la agip si omv si lukoil. Insa saptamana trecuta am fost la cineva la tara si am alimentat de la o statie de pe soseaua stefanesti la calea ferata. Scria ceva de genul partener, colaborator, cunoscut rompetrol. Cum era singura statie am pus de acolo dupa care au inceput problemele. Se oprea motorul la 2 minute, datea in nas facea ca dreaq. E de evitat statia respectiva. Link to comment
CARABUSU Posted September 22, 2006 Share Posted September 22, 2006 Nu va sfatuiesc sa puneti benzina de la rompetrol sau petrom,cand alimentam de la petrom si rompetrol motorul imi cam facea figuri si consumul crestea si el cam pana la 7% in oras si afara ,ceea ce e destul de mult. Acum obisnuiesc sa alimentez la OMV si merge foarte bine motorul,iar consumul a revenit la normal,adica 5,4%consum mixt. "> Din punctul meu de vedere,benzina de calitate gasiti la OMV,MOL si Lukoil,dar acum fiecare cu parerea sa. Link to comment
tolin Posted September 22, 2006 Share Posted September 22, 2006 Nu confunda producatorul cu vanzatorul. Benzina de CO95 de la OMV e facuta la Petrom si cea de la MOL este facuta la Rompetrol. Schimba statia ! Link to comment
Zmeul cel rau Posted September 22, 2006 Share Posted September 22, 2006 Nici tu nu confunda producatorul. Desi benzina de la defunctul Shell era facuta la Petromidia, ea nu era benzina Rompetrol, Shell avand facilitati inchiriate acolo. Nu stiu cum mai e acum odata cu preluarea de catre Mol a benzinariilor Shell dar se prea poate sa fie la fel. Link to comment
kornelush Posted September 24, 2006 Share Posted September 24, 2006 pentru un galatean ce statii (retele) recomandati? Link to comment
marr Posted September 28, 2006 Share Posted September 28, 2006 Mai nou, benzina de la statiile Petrom V a fost re-botezata, respectiv in loc de Top Premium 99+ este Carrera 100 iar Premium 95 FP a devenit Premium OMV (Carera !?) 95 FB. Stie cineva daca este doar o rebranduire sau chiar este alta benzina decat la statiile Petrom "normale" ? Link to comment
tolin Posted September 28, 2006 Share Posted September 28, 2006 La meme Jannet, altfel coafata (rebranduire). Link to comment
andreib Posted October 6, 2006 Share Posted October 6, 2006 Se pare ca am comis-o si eu, sau mai bine spus mama. Dupa pus benzina numai de la banzinarii de cacao (de la care nu pune nimeni in afara de mama, pt ca toti stiu ca e benzina proasta) ultima a pus capac: la iesirea din Roman spre Iasi, PETROas. Rezultatul este un matiz cu vmax 110km/h care face 30 min 0-100km/h. Acum ce naiba fac, ma apuc de dezmebrat masina sau astept sa se consume si schimb filtrul de benzina? Link to comment
AZH Posted October 6, 2006 Share Posted October 6, 2006 Pune un aditiv si lasa sa se consume, dupa care filtru de benzina.Am patit si eu asa ceva, dar acum am scapat cu benzina si testez GPL. Succes! Link to comment
