Apocalips Posted April 30, 2008 Share Posted April 30, 2008 si nu-mi explic de ce Iti explic eu de ce: 1. probabil nu a folosit trepied 2. asa face 18-55-u pe care imi vine si mie sa-l dau de pamant cateodata Link to comment
guru Posted April 30, 2008 Share Posted April 30, 2008 Da, camera nu stie mai putin de iso 200. Neclaritate... nu stiu, poate pentru ca sunt cropuite? Link to comment
Lucian M Posted April 30, 2008 Share Posted April 30, 2008 (edited) @mike: Depinde de cum ai setat monitorul. Fata de camerele compacte- d40 mi se pare ca are niste culori excelente. Cu setare "Entertainment" de la monitorul meu Philips ai impresia ca poti "atinge" peisajul. Imaginile mi se par destul de clare. Edited April 30, 2008 by Lucian M Link to comment
mike.omega Posted April 30, 2008 Share Posted April 30, 2008 @Lucian M: nu la culori ma refeream, Guru a avut dreptate, probabil ca e de la Crop @Apocalips: tind sa cred ca nu e nevoie de trepied la acest gen de poze/fotografii, asta binenteles daca nu cumva lumina lipseste cu desavarsire Link to comment
Apocalips Posted April 30, 2008 Share Posted April 30, 2008 (edited) tind sa cred ca nu e nevoie de trepied la acest gen de poze/fotografii - Get yourself a good tripod: No need to even think about landscape photography if you don?t have a tripod. A good sturdy tripod1 would be ideal, but if you are not sure yet about how serious you are about landscape photography you can always start with any tripod, but you need one. - The reason for using a tripod might seem obvious on the surface. For me using a tripod goes beyond reducing camera shake and taking photographs at slower shutter speeds. -However! And a big however. One piece of equipment is so critical to success in landscape photography that it is worth a mention here. I feel obliged to tell every one of my fellow landscape photographers (yes you) that landscape photography without a tripod is doomed for failure. Hopefully, you will say "I know this you monkey!", but I just have to be sure... It is a mission carrying your tripod around, yes. Especially if you don't have money for that fancy aluminium one after buying a $4,000 lens. Taking it along is worth the sweat in more ways than this website can illustrate. Take your tripod with every time. Period. PS: eu mi-am luat recent un trepied bunicel, cand am ocazia o sa fac si un review la el. M-am hotarat acum sa bag prima parte de "review" la trepied. Primu trepied care l-am avut la fuji a fost de 48cm inaltime maxima. Mai mult de atata nu am avut nevoie pt ca avea ecranul rabatabil si fuji-ul era usor. Cand am trecut la dslr si am incercat sa folosesc trepiedul ma durea spatele la cum trebuia sa ma aplec si sa ma chiorasc. Apoi, aparatu cu 70-300 pe el are 2 kile, deci trebuia ceva care sa suporte cele 2 kile. Asa ca mi-am luat un trepied care suporta 4 kile (ca sa fie camera stabila trepiedul trebuie sa suporte de doua ori greutatea camerei). Asta are 1.40m iar viewfinder-ul ajunge pe undeva pe la 1.50 (deci e destul de inalt). Pe langa asta e si greu (are 2.5 kile) si e facut din aluminiu. 2.5 kile poate pentru unii inseamna mult si greu de carat... si este, e cam greu, dar cand este extins, e foarte bine echilibrat si nu mai este asa de greu de mutat/manervrat. Fata de un trepied normal si simplu, asta e destept si stie multe. 1. Se pot monta diferite capete de trepied pe el. Panoramic, cu bila, etc etc 2. se adapteaza mai usor la mediu si la nevoie fotografului. Problema este la macro. Sunt trepiede la care poti pune coloana centrala pe orizontala ca sa bagi doar aparatu in tufis si trepiedul sta langa tufis. Dar daca e nevoie de apropiere, se poata adapta altfel. Se scoate capacelu de la coloana centrala si se introduce invers . Unele trepiede au in loc de coloana centrala un monopied... deci cand trebuie sa folosesti monopiedul scoti coloana centrala (care este telescopica) si o folosesti ca pe un monopied. La pozatul din mana a obiectelor care sunt apropiate nu e problema mare cu claritatea. Chiar daca tremura mana putin, miscarea nu e vizibila in poza. Dar cand ai seubiectul la 1km miscarea aia mica la distanta asta se observa. E ca si cand ai poza cu un tele de 300mm la focala maxima si chiar daca tu misti putin, la acea focala se observa mai usor camera shake-u. Edited April 30, 2008 by Apocalips Link to comment
Lucian M Posted May 1, 2008 Share Posted May 1, 2008 (edited) Dom'le, pasiunea e pasiune, daca nu pentru fotografie, macar pentru... supravietuire . Eu n-am fost in locatii deosebite, ci undeva pe langa Manastirea Neamtului. Edited May 1, 2008 by Lucian M Link to comment
puchi Posted May 2, 2008 Share Posted May 2, 2008 Fiecare cu damblaua lui .De 1 mai . Link to comment
Apocalips Posted May 2, 2008 Share Posted May 2, 2008 Eu iar m-am jucat cu focul... dar de data asta am luat masurile de siguranta. Adica eram cu siringa cu apa langa mine Si dupa cum slab se observa in poza de mai jos, apare si un strop, dar deja ma intind si cer prea mult de la obiectiv - trebe unu de macro Si altele: Si duminica imi vine filtru infra rosu Link to comment
Apocalips Posted May 4, 2008 Share Posted May 4, 2008 (edited) Sa va arat ce am invatat sa fac mai nou... e vorba de panorama sferica. Ca sa o puteti vedea trebuie sa intrati aici http://www.devalvr.com/ si sa downloadati acel plugin. Dupa ce l-ati downloadat intrati AICI si puteti vizualiza panorama sferica. E prima mea panorama de acest gen deci mai apar erori de genul crengi rupte si trepiedul care apare in cadru. Aceste erori se datoreaza in mare parte capului panoramic pe care il am si a fost facut de mine (cel mai ieftin e pe la 150e) si nu este asa de precis ca unu facut de oameni destepti care stiu ce fac S-ar putea sa trebuiasca sa reporniti firefoxu dupa ce instalati acel plugin c sa mearga panorama. Dupa ce se incarca, dati click, tineti apasat si miscati de mouse, oricum mai aveti niste instructiuni jos (full screen-u se face din click drepta) Enjoy PS: n-am mai cerut de mult timp comentarii, dar acum sunt binevenite. Mda, am dat paste la acelasi link in loc sa-l pun pe cel cu panorama... ASTA E CEL BUN (si l-am inlocuit si pe cel gresit de mai sus) Edited May 4, 2008 by Apocalips Link to comment
mike.omega Posted May 5, 2008 Share Posted May 5, 2008 Inca o serie de poze. Iar din multe poze au rezultat putine prea putine de aratat la lume )"> Album Foto Link to comment
Apocalips Posted May 6, 2008 Share Posted May 6, 2008 Vad ca de panorama n-a zis nimeni, deci nu va incanta ideea de panorama sferica. Cei care nu au avut chef sa ia acel plugin nestiind la ce sa se astepte, va spun ce e panorama sferica. Este o sfera pe a carei suprafata (in interior) sunt poze. In momentul in care deschizi panorama sferica te poti plimba prin acea sfera. Merge si cu quicktime Ieri am facut niste poze cu filtru IR. Dupa ce l-am luat am citit despre acesta si pe D80 nu se poate folosi numa cu timpi de expunere mari fata de D70 la care se poate poza si din mana. Asta este, la D80 protectia de IR este mai mare. Sunt doar teste... ca nu prea am avut timp sa experimentez cu diafragma si timpi de expunere si WB. Si cateva portrete de strada. Link to comment
banzay Posted May 6, 2008 Share Posted May 6, 2008 Zic eu, zic eu ... Super tare. Imi place. Nu ma pricep daca e ceva de criticat dar in ochii mei arata bine. Mi-ar face si mie placere sa am la indemana o camera ok si sa invat/ma pricep un pic... oricum mi se pare marfa sa stii sa te joci cu camera, dar eu nu stiu daca am si rabdarea necesara. Spor la treaba si mai asteptam Link to comment
el cid Posted May 6, 2008 Share Posted May 6, 2008 Bravo pentru "chibrite". Si (pentru toti ) mai lasati macro-ul si efectele. Mergeti pe culoare normala si compozitie! Link to comment
paul_marines Posted May 7, 2008 Share Posted May 7, 2008 Vad ca de panorama n-a zis nimeni, deci nu va incanta ideea de panorama sferica. Ce spui de Panorama Maker? Un soft foarte bun pentru aranjarea pozelor si compunerea imaginii panoramice. La fel de bun este si view-erul. Cateva tentative panoramice anterioare. Link to comment
Apocalips Posted May 7, 2008 Share Posted May 7, 2008 Daca vrei un soft care sa faca tot felu de panorame, inclusiv cea sferica, cilindrica sau ca faci 8 poze la o cladire, incearca hugin. E gratuit si il poti lua de aici http://hugin.sourceforge.net/download/ Acolo pe site sunt si tutoriale cam pt orice panorama. Exista totusi o problema pe care am avut-o eu la versiunea cea noua. Daca urmezi acest tutorial http://hugin.sourceforge.net/tutorials/multi-row/en.shtml si dupa ce incarci imaginile iti da o eroare inseamna ca ai aceeasi problema ca la mine. Eu am avut noroc cu cineva care a avut hugin-ul vechi (cel scos cu vre-o 2 luni inainte) si cu ala nu mi-a dat eroare. Il am si sunt dispus sa-l distribui doritorulor care intampina acea eroare si vor sa faca panorame de tot felul. Ca sa va puteti plimba prin panorama se poate downlaoda programul Pano2QTVR care si el este moca si se poate lua de aici: http://www.photo-freeware.net/pano2qtvr.php Eu panorame din alea intinse de la stanga la dreapta nu am facut ca nu prea ma incanta ideea de a avea o poza in forma de fasie si am dat de hugin pt ca am vrut sa incerc panorame sferice. Daca sunt doritori care vor sa faca panorame sferice, incerc sa explic cum se fac, dar trebuie cap panoramic, altfel apar probleme cu paralaxa. Link to comment
CARABUSU Posted May 10, 2008 Share Posted May 10, 2008 (edited) Mai pun si eu niste foto d-ale juniorului Astept pareri siimpresii Edited May 10, 2008 by CARABUSU Link to comment
Apocalips Posted May 10, 2008 Share Posted May 10, 2008 Eu as avea cateva pareri... 1. sa fie mai atent la incadrare, sa nu mai injumatateasca poza (la prima poza de exemplu) 2. Sa nu pozeze cand are chef sau se nimereste ci sa pozeze cand e lumina. Daca n-are lumina, ies muntii intunecati. deci sa fie atent si la ora la care pozeaza, sa bata soarele pe subiect. Se poate poza si cand nu bate soarepe pe subiect dar deja trebuie HDR sa iasa si muntele si cerul expus bine. 3. Uite un site ajutator. http://www.dcmag.co.uk/The_rule_of_thirds...fcRo39cnPg.html Am mai facut si eu niste poze cu filtru IR Trebe sa incerc la cladiri, in locuri aglomerate... cred ca dispar oamenii pt ca trebuie timp mai lung de expunere si oricine se plimba pe-acolo nu apare in poza. Link to comment
Satori Posted May 12, 2008 Share Posted May 12, 2008 Sincer, fa ceva cu culoarea aia. Ma dor ochii. Sau poate am eu vreo problema cu ea Link to comment
Apocalips Posted May 12, 2008 Share Posted May 12, 2008 Sincer, fa ceva cu culoarea aia Care? Rosu ala sau culoarea pomilor? Mai am o serie facuta ieri Si altele de ieri, mai naturale. Link to comment
robert_11 Posted May 12, 2008 Share Posted May 12, 2008 Poze facute Sambata la Predeal cu un Sony H7. Le consider printre cele mai frumoase poze facute de mine. Link to comment
NFS Posted May 13, 2008 Share Posted May 13, 2008 (edited) Si altele de ieri, mai naturale. Vezi ca cica nu e voie sa pozezi copii fara acordul parintilor (ai lor, nu ai tai). Altfel, foarte reusite. Imi place mai ales compozitia si momentul ales. Edited May 13, 2008 by NFS Link to comment
Apocalips Posted May 13, 2008 Share Posted May 13, 2008 Stiu, si nici alte persoane fara acordul lor. Numa daca sunt 4 persoane in poza e ok, ca se considera ca nu-i mai invadezi intimitatea. Momentan pe mine nu ma prea vede lumea cand fac pozele ca le fac rapid si de la distanta. 90% din ele sunt facute la 300mm. Legea la noi oricum e cam aiurea, ai foarte putine locuri in care ai voie sa pozezi... si pe spatiul public nu ma despagubeste nimeni daca X s-a bagat in fata aparatului si mi-a stricat poza dar pot fi dat in judecata daca l-am pozat pe nush care sugandu-si degetu... sau altceva. Link to comment
bella Posted May 14, 2008 Share Posted May 14, 2008 Scuze pentru incadrarea "fortata" in acest topic a problemei mele... Am niste poze de vacanta pe care vreau sa le integrez intr-un slide-show cu anumite melodii in bacground si as vrea sa imi recomandati un software. Merci. P.S. Nu va abtineti sa recomandati soft-uri ce necesita licenta Link to comment
Lucian M Posted May 14, 2008 Share Posted May 14, 2008 Cu nero 6.6 sau 7 (la 6.6 iti trebuie Nero vision express). Simplu si eficient. Link to comment
