leeveeu Posted March 25, 2008 Share Posted March 25, 2008 Salut, am un Kalos hatchback 1.4 16v 94 CP, cu 30.000 km pe el. Am urmatoarea problema: Din cand in cand (nu mereu si nu am reusit sa imi dau seama cand si cum), cand dau in marsalier (cu ambreiajul ridicat, apasand usor pe acceleratie) se aude un sunet metalic strident, ca si cum s-ar freca doua piese metalice. Frecventa este cam 10% din toate datile cand folosesc marsalierul. Am fost de 2 ori la service pentru asta si mi-au spus ca totul e ok (bineinteles ca atunci cand am fost la service zgomotul nu s-a auzit). Aveti idee de la ce ar putea fi? Multumesc! Link to comment
closchkutza Posted March 25, 2008 Share Posted March 25, 2008 (edited) Cel mai probabil nu se "pupa" bine rotile dintate in cutie. Edited March 25, 2008 by closchkutza Link to comment
leeveeu Posted March 25, 2008 Author Share Posted March 25, 2008 Da, dar zgomotul nu se aude cand schimb in marsalier, ci cand merg pur si simplu in marsalier... Link to comment
closchkutza Posted March 25, 2008 Share Posted March 25, 2008 Se aude atunci cand pui masina in miscare, in marsalier? Link to comment
magnet Posted March 25, 2008 Share Posted March 25, 2008 Asigura-te ca impingi pana la capat schimbatorul. Probabil ca ramane blocat undeva la intrare si zgomotul provine de la cutie. Link to comment
leeveeu Posted March 25, 2008 Author Share Posted March 25, 2008 closchkutza said: Se aude atunci cand pui masina in miscare, in marsalier? Si cand o pun in miscare, si cand merge efectiv se aude. magnet said: Asigura-te ca impingi pana la capat schimbatorul. Probabil ca ramane blocat undeva la intrare si zgomotul provine de la cutie. Hmmm e o idee. Am sa incerc. Mersi de raspuns. Link to comment
closchkutza Posted March 25, 2008 Share Posted March 25, 2008 (edited) Asta incercam si eu sa-ti sugerez, ca nu cupleaza complet, in cutie si de acolo haraitul. Si mie mi s-a intamplat de vreo 2 ori, tot la marsalier. Daca nu cupleaza din prima complet(simti la mana ca nu "scapa") nu forta; scoate pe liber, elibereaza ambreiajul, calca-l din nou si mai fa o incercare. Merge de fiecare data, garantat, totul este sa ai rabdare . Edited March 25, 2008 by closchkutza Link to comment
leeveeu Posted March 25, 2008 Author Share Posted March 25, 2008 Multumesc pentru raspunsuri. Un forum fain! Link to comment
perfidus Posted March 25, 2008 Share Posted March 25, 2008 Eu as miza si pe zgomotul modulatorului ABS-ului, cand isi face testul. Poate cand pornesti in fata cu a I-a il treci cu vederea si l-ai sesizat doar la marsarier. La mine face la fel si cand pornesc cu fata si cand plec cu spatele. Si face tot timpul la prima plecare dupa ce ai pus contactul. Bafta "> ! Link to comment
