three6t Posted February 20, 2009 Share Posted February 20, 2009 (edited) Coldstart idle issue The problem is that when the car is parked esp outside in cold( rather not so cold also) for a long period then the car wont simply start. the initial ignition is immediate but after one or two revs it pick up like its very weak (lets say at 20% power), it starts shaking everything, the dashboard, the engine compartment all gets punched the rpm reading is also very low (about 600) . when i depress the pedal the car stalls immdediately. Then when i give it a crank, crank after cranks, it just wont start. and if it does start the same symptoms. but sometimes if a press the pedal very very carefully , it picks up speed but with jerky way and the problem fades away. now when the engine is warm. There is absolutely no issue. Initially i suspected IAC valve as it seemed broken and stuck, i replaced with a brand new orinal one. then i felt the same problem for the first start. i then did ecm reset and idle lean procedure, then it felt like the engine is very happy and every thing was ok. i wAS INITIALLY HAPPY that the prob is gone. But now after a long period i started the car and it has the same prob, the same problem repeated. I have tried to explain in detail so as to get expert advice from u guys regards Edited February 20, 2009 by three6t Link to comment
nastasaflorin Posted February 20, 2009 Share Posted February 20, 2009 The spark plugs are ok?If one is defective you have problems.Also verify the electric generator (alternator), the level of oil and PCV valve. Link to comment
tolin Posted February 20, 2009 Share Posted February 20, 2009 Idle Learn is the solution. Link to comment
tomis Posted February 20, 2009 Share Posted February 20, 2009 Also verify the electric generator, the level of oil and PCV valve. Mamma mia !!! Omul ne zice parca de o boala veche, ca nu-i pleaca in frig (nu stiu la vara), cand pleaca ( greu ) abia sufla si incepe sa trepideze nebun, parca-parca simte nitel pedala, ca i-a facut Idle Learn cu IAC nou si a mers, dar masina a stat ceva timp si s-a prostit la loc. Daca trepideaza, nu-i mere niste cilindri... Link to comment
Belbody Posted February 21, 2009 Share Posted February 21, 2009 Try to replace the spark plugs wires. Link to comment
three6t Posted February 22, 2009 Author Share Posted February 22, 2009 I have ,no start, rough idle, low idle rpm when engine is cold problem (esp if i start after overnight parking) i have installed a new IAC valve+ECM RESET+IDLE LEAN but problem is not solved the car runs like breeze when engine is warm, no problems i now suspect PCV valve, if i remove it while engine is running rpm gets to quiet high and then oscillate if i install it i get a very low rough idle, my car wont start in cold i have removed it and if i blow air one way its blocked (which i think it should do so) other way its seems to pass about 10-20% of air, is it normal? should i replace it? Link to comment
