sorinnn2006 Posted March 1, 2009 Share Posted March 1, 2009 Modelul este Kenwood KRC-378r.Ieri cand sa pornesc cass.nu mai mergea,nu se auzea nimic in boxe si pe afisaj apare mesajul "CALL".M-am uitat pe cartea lui tehnica de pe net dar nu gasesc nimic legat de acest cod(mesaj).A mai patit cineva asa ceva cu vreun model de Kenwood?Cass este legat corect prin mufa iso deci prolema la fiere nu este. "prolema la fiere nu este". A SE CITI FIRE---scuze din repezeala. KRC_478_378R.pdf Link to comment
martiz Posted March 1, 2009 Share Posted March 1, 2009 Ai citit manualul atasat? Asa cam pe la pagina 8...! Spor la lectura. Link to comment
TBird Posted March 2, 2009 Share Posted March 2, 2009 Uite mai asa mura`n gura When the telephone rings: When a call is received, "CALL" is displayed and all the unit functions are temporarily interrupted. Restoring Original Unit Source During Phone Call: Press the SRC button. "CALL" disappears from the display, and the volume of the original source is restored gradually. Turning TEL Mute Function Off After Phone Call: Hang the phone up. "CALL" disappears from the display. The original source (i.e., the one used before the phone call) is returned to automatically, and the volume restored gradually. Link to comment
madkat Posted March 2, 2009 Share Posted March 2, 2009 adica si mai mura-n gura firu' de telephone mute s-a atins de vreo masa ceva... oricum din ec imi aduc aminte - kenwood-urile (ca majoritatea sculelor cu mufe iso) au acle fir separat de cele doua mufe - deci se poate atinge/prinde sub o tabla... Link to comment
sorinnn2006 Posted March 3, 2009 Author Share Posted March 3, 2009 ""firu' de telephone mute s-a atins de vreo masa ceva..."" da eu n-am nici o treaba cu telefonul.Si am facut ceea ce scrie in carte (scuze acolo nu am citit) ci doar la "Troubleshooting Guide" de la sf. manualului, si nimic imi apre volumul dar nu se aude nimic in boxe.L-am si resetat dar la fel nimic Cauta postul il gasete si cand dau la vol. imi apare CALL.Mufele alea din spate pt telefon sunt acoperite cu niste protectii ,deci nu avea cum sa se atinga de table Link to comment
madkat Posted March 3, 2009 Share Posted March 3, 2009 (edited) stii ca au fost izolate la montaj sau ai scos cass-ul si ai verificat firul de tel. mute? si sa inteleg - apesi SRC si afisajul nu mai arata CALL, pare ca revine la normal si totusi tace? pe preout-uri poti incerca sa vezi daca se aude ceva? Edited March 3, 2009 by madkat Link to comment
sorinnn2006 Posted March 3, 2009 Author Share Posted March 3, 2009 am scos cass si am verificat mufele.Au peste ele niste capacele deci ...nu este de acolo Link to comment
Dj_Dark Posted March 3, 2009 Share Posted March 3, 2009 Sa nu ai vre-o boxa in scurtcircuit. La unele nu porneste amplificatorul in cazul acesta. Link to comment
sorinnn2006 Posted March 3, 2009 Author Share Posted March 3, 2009 am verificat si asta .la fel ...CALL nu se aude nici un fasait,zgomot nimic... Link to comment
madkat Posted March 3, 2009 Share Posted March 3, 2009 Dj_Dark zice bine - si asta e posibil - de la un scurt pe o boxa (fir sau chiar dif ars) intra finalul in protectie... ia la verificat pinii din mufele masinii si vezi daca vreun dif are rezistenta 0 oameni in loc de 4-5 Link to comment
