alienpredator Posted February 20, 2005 Share Posted February 20, 2005 Imi puteti spune pe unde se baga uleiul de la cutia de viteze la Tico,ca numai aia stiu pe unde se scoate. Merci Link to comment
alienpredator Posted February 27, 2005 Author Share Posted February 27, 2005 Ce,nimeni nu stie pe unde se baga uleiul in cutia de viteze????????? Link to comment
aztec Posted February 27, 2005 Share Posted February 27, 2005 sant 2 gauri diferite , pentru a pune ulei in cv in general itzi trebuie o pompa de ulei iar scurgerea se face printr-un orificiu undeva in josul cutiei... vezi si tu in manual mai exact.. cel mai bine o faci in service ca trebuie si rampa.. Link to comment
Shenck Posted February 27, 2005 Share Posted February 27, 2005 In manual nu atrata exact pe unde se umple. E in partea stinga un dop. Merge si cu furtun si pilnie, fara pompa. Totusi urmeaza sfatul si mergi in service. Link to comment
AZH Posted March 24, 2005 Share Posted March 24, 2005 In partea stanga a cutiei de viteza este un surub de 17 si pe acolo se pune ulei pana cand "nu mai intra".Sa stii ca eu nu am mers la service, ci am introdus cu un furtun "conectat" la dopul unui PET, in asa fel incat sa-i dai ceva mai multa presiune la curgere. Mult succes!!!! Link to comment
Dragos82 Posted March 24, 2005 Share Posted March 24, 2005 Parerea mea:du-te in service >- Link to comment
SORAN Posted March 24, 2005 Share Posted March 24, 2005 Da asa merge cu sticla de plastic dar te chinui...nu are rost ! Aia la service au pompa cu tija indoita merge la fix! Link to comment
AZH Posted March 26, 2005 Share Posted March 26, 2005 Revin cu noi informatii.Astazi mi-am reimprospatat experienta si am completat uleiul la cutie.Surbul nu este de 17 asa cum am spus mai devreme, ci de 24 si se desface super ok cu o inelara.In rest, spor la treaba. Daca vrei sa te ajut, iti pot imprumuta un furtun care este "conectat" la un dop de PET. Link to comment
pankrator Posted February 18, 2006 Share Posted February 18, 2006 am schimbat azi burduful de planetara si s-a scurs un pic de ulei cin CV.Problema e ca nu pot sa descfac surubul ala de 24 nicicum.Nu stiti unde se mai poate baga ulei in CV? Link to comment
Senna Posted February 18, 2006 Share Posted February 18, 2006 Nu se poate completa cu ulei prin alta parte, daca daca intorci masina cu rotile in sus. Atunci poti folosi busonul de golire pe post de buson de umplere. Sau, mai avansat, poti racorda da busonul de golire un stut si introduce ulei prin presiune. Stutul trebuie sa fie etans, ca daca nu ai bani de mers in service, cu atat mai putin sa ai de aruncat ulei pe jos Parerea mea serioasa acum: foloseste o cheie INELARA de 24, vezi sa insisti din greseala in sens invers, da si cateva lovituri de ciocan (mai finute) mai intai in dop si apoi in cheia cu care incerci sa-l desfaci. Bafta maxima! Link to comment
vasiledintomis Posted September 28, 2006 Share Posted September 28, 2006 Pe unde si cum se poate verifica cat ulei mai este in cutia de viteze?Tot prin orificiul de umplere cu surub de 24? Link to comment
Mircea Posted September 28, 2006 Share Posted September 28, 2006 De regula nivelul uleiului la cutiile manuale se verifica prin busonul de umplere. Cu masina pe suprafata plana se desface busonul. Daca curge ulei intr-un firicel subtire, nivelul este ok, daca nu curge, trebuie completat. Link to comment
todix Posted November 3, 2012 Share Posted November 3, 2012 Buna seara domnilor. Am schimbat si eu astazi ulei cutie viteza TICO si am folosit cheie de 24.Insa nu am urcat masina pe rampa sau ridicat roata stanga fata sau demontat roata ci mie mi a fost MAI USOR sa dau jos Bateria masinii si Suport Baterie( format din doua parti) si folosit intreadevar Idea cu Furtun si o Sticla . MULTUMESC MULT pt ideile inovatoare pe care voi ceilalti membri le discutati sau prezentati cu poze aici pe Forum. Link to comment
Tricko Posted October 2, 2014 Share Posted October 2, 2014 Ce cantitate de ulei intra in cutie la un schimb? Link to comment
cristache nicu Posted March 22, 2019 Share Posted March 22, 2019 (edited) Buna ziua. Astazi am observat ca curge ulei in fata dreapta. Am inteles ca este de la simeringul de palier spate, (volanta). Imi poate spune cineva daca pot efectua inlocuirea simeringului acasa? Si daca a mai inlocuit cineva cam care ar fi ordinea demontarii. Trebuie data jos cutia de viteze? Multumesc. Edited March 22, 2019 by cristache nicu Link to comment
mirceajo Posted May 8, 2019 Share Posted May 8, 2019 In primul rand asigurate ce curge de acolo, pata ar trebui sa fie pe partea stanga (unde se imbina cutia cu motorul) cum te uiti din masina (asa dai reperele) eventual curata zona aia si urmareste cateva zile. Daca e simeringul de palier, trebuie demontat cutie, ambreiaj si volanta si abia atunci ajungi la el, deci tragi tu concluzia daca o poti face acasa sau nu. Spor! Link to comment
