executive01 Posted November 17, 2010 Share Posted November 17, 2010 On 11/17/2010 at 6:20 AM, Dj_Dark said: Si nu scrie nimic pe capac in dreptul sigurantei de 30A? PS Sunt mai multe de 30A acolo. Scrie blower engine (high) si horn Link to comment
Dj_Dark Posted November 17, 2010 Share Posted November 17, 2010 Cu motorul rece se simte incinsa la mana? Link to comment
executive01 Posted November 17, 2010 Share Posted November 17, 2010 cam dupa 3 minute ce pornesc masina, incepe siguranta sa se incalzeasca. mai are momente cand se raceste si pe urma iara se incalzeste. Link to comment
Florinel2004 Posted November 17, 2010 Share Posted November 17, 2010 Salut ! Am o problema cu dezaburitorul de pe luneta ! S-a desprins connectorul de pe geam , cu il pot lipi inapoi ? Am atasat si o poza ! Link to comment
florinfl23 Posted November 23, 2010 Share Posted November 23, 2010 am citit cam in tot topicul de aici si nu am gasit rezolvarea in problema mea. totusi daca poate cineva sa ma ajute... ms. http://www.gmclub.ro/forum/index.php?/topic/34657-problema-mare-la-cielo/page__p__504042__fromsearch__1&do=findComment&comment=504042 Link to comment
cristidavid Posted November 23, 2010 Share Posted November 23, 2010 (edited) Florinfl23. Aceeasi problema am avut-o si eu acum 1 an si ceva. La o siguranta (nu mai stiu la care, care le luasem la rand, ma refer la faptul ca nu-i stiu pozitia in cutia de sigurante) piciorusele erau oxidate. Le-am curatat pur si simplu si asta a fost tot. Deci uite-te la picioruse si nu la siguranta daca e arsa sau nu! Edited November 23, 2010 by cristidavid Link to comment
florinfl23 Posted November 23, 2010 Share Posted November 23, 2010 On 11/23/2010 at 10:57 AM, cristidavid said: Florinfl23. Aceeasi problema am avut-o si eu acum 1 an si ceva. ... ms mult, ma duc sa verific. ai avut dreptate cristidavid, era vb de siguranta f18, era arsa. am schimbat-o si acum merg toate. ms mult Link to comment
cristidavid Posted November 23, 2010 Share Posted November 23, 2010 Cu placere si ... fara evenimente! Link to comment
Razvan3486 Posted November 24, 2010 Share Posted November 24, 2010 On 10/9/2010 at 5:56 AM, Alezz said: Stie cineva cum se desface consola centrala de la climatizare?Mi s-a ars un bec in ea acolo la reglajul de cald/rece si nu am idee cum s-o desfac.Am vezut niste cleme pe margini am tras de ele si nimic,iar sa trag de ea sa-i scot mufele din spate nu pot ca nu iese suficient cat sa bag mana,ma tine pe loc cablul de la "butonul" aer cald/aer rece... Trebuie sa desfaci inainte suportul casetofonului . Link to comment
cris06 Posted November 24, 2010 Share Posted November 24, 2010 Nu! Scoti rama ornament, desfaci cablul de comanda al voletului de la picioarele pasagerului, tragi in afara blocul climatizarii si mai dati "search". Link to comment
eugen_pustiu Posted November 26, 2010 Share Posted November 26, 2010 Salutare!Azi mi a facut nubira si prima problema la partea electrica:nu mai merge semnalul.Am verificat sigurantele din masina si nimic ,in schimb la cele de la motor am gasit una de 20A arsa.siguranta dinaia mare.Pe capac scrie "Ignition 1".am pus un fir in loc de sig si nimic,tot nu merge semnalul.Firul l am scos repede mpoate am vreun scurt si sa nu mi arda instalatia.Avaria merge.Releul de semnal unde e pozitionat???Siguranta pentru semnalizare care e?Ce ar mai putea fi??Multumesc . Link to comment
iulian2009 Posted November 27, 2010 Share Posted November 27, 2010 Buna ziua tuturor si sper sa postez unde trebuie. Detin un cielo coreean din `96, model GLE si problema mea ar fi urmatoarea: pun contactul se aprinde bordul, las 4-5 secunde apoi dau sa pornesc, moment in care moare efectiv totul: bord, lumini (bloc lumini), plafoniera si orice de parca nu ar avea bateria pe masina. M-am dat jos din masina am verificat bornele baterieie si sunt ok, "ochiul magic" e verde si din senin isi revine. Pornesc si plec, pana la urmatoarea oprire cand se repeta povestea. Are cineva idee ce anume poate fi? Multumesc anticipat. Link to comment
DGT Posted November 27, 2010 Share Posted November 27, 2010 (edited) Curata bine bornele la baterie si pe interior si ai grija sa fie stranse bine.Daca dupa ce ai facut toate astea, se mai intampla acelasi lucru, pine pe cineva sa dea la automat si masoara voltajul la baterie in acelasi timp.Poate sa aiba "ochiul" verde dar sa nu aiba amperaj.Daca in timp ce dai la automat ,scade voltajul rau inseamna ca este bateria de vina. Edited November 27, 2010 by DGT Link to comment
iulian2009 Posted November 27, 2010 Share Posted November 27, 2010 Masurat deja si e in regula. Bornele sunt in regula, ca si noi, stranse bine. Link to comment
DGT Posted November 27, 2010 Share Posted November 27, 2010 Verifica si borna de minus unde vine prinsa de caroserie sa nu fie oxidata si sa fie prinsa bine.Si daca ai un prieten incearca sa-i dai curent de la alta masina sa vezi ,tot asa face? Link to comment
iulian2009 Posted November 27, 2010 Share Posted November 27, 2010 Ok. Voi verifica si aici. Multumesc mult de sfaturi. E drept ca nu ma pricep dar prind repede si nu fac parte din categoria celor a-tehnici . Eu ma gandeam sa nu am un scurt la electromotor, bucsele duse si sa fie inclinate, in felul acesta raman intr-o anumita pozitie cand opresc (asta in cazul cel mai nefericit deoarece acum, din punct de vedere financiar chiar nu mi-ar pica bine la digestie), sau incercam sa dau vina pe contactul electric de pornire, deoarece am mai auzit astfel de patanii si mie de 2 ori mi-a scos la pornire un firicel alb si subtire de fum din cochilia volanului cand am pornit. Voi reveni cu ce am mai constatat si poate o rezolvare a situatiei. Inca o data multumesc. Link to comment
DGT Posted November 27, 2010 Share Posted November 27, 2010 Ce ti-am recomandat sunt primele si cele mai necostisitoare lucruri. N-am stiut ca ti-a scos fum din contact.Totusi ai grija, daca a scos fum inseamna ca ai contact imperfect acolo si este PERICOL de incendiu.Cel mai bine apeleaza la un electrician auto. Link to comment
eugen_pustiu Posted November 28, 2010 Share Posted November 28, 2010 On 11/26/2010 at 8:28 PM, eugen_pustiu said: Salutare!Azi mi a facut nubira si prima problema la partea electrica:nu mai merge semnalul.Am verificat sigurantele din masina si nimic ,in schimb la cele de la motor am gasit una de 20A arsa.siguranta dinaia mare.Pe capac scrie "Ignition 1".am pus un fir in loc de sig si nimic,tot nu merge semnalul.Firul l am scos repede mpoate am vreun scurt si sa nu mi arda instalatia.Avaria merge.Releul de semnal unde e pozitionat???Siguranta pentru semnalizare care e?Ce ar mai putea fi??Multumesc . Mda...cine mai pateste sa stie ca e din butonul avariei.20 ron si o cola la 2 l si s-a rezolvat.Dupa,am reparat si butonul meu. Link to comment
iulian2009 Posted November 29, 2010 Share Posted November 29, 2010 Problema rezolvata prin schimbarea contactului electric. Multumesc mult pentru sprijinul acordat. Eu unul nu as fi crezut ca se comporta astfel de la acel contact, ma gandeam ca daca se defecteaza raman macar pozitii sau avarii. O zi si o saptamana cat mai frumoasa tuturor. Link to comment
nato99 Posted December 3, 2010 Share Posted December 3, 2010 Buna tuturor Am doua mici nedumeriri: 1 Becu de la butonu de dezaburire, are toane, ba merge ba nu, in timp ce acel bec de pe bord nu merge , nu merge nici dezaburirea(apas pe el de 10000000000 de ori dar nimic,se aude un clic de fiecare data cand apas,pe undeva de prin spatele ceasurilor,dar nu functioneaza dezaburirea),becu e cel mic nu cel ce se aprinde o data cu restu Am crezut ca e dun cauza acelui bec , am inlocuit cu led si tot nimic 2 patru din acele lite nu functioneaza, ce anume pot face sau nu se pot repara doar schimba cu totul Link to comment
kinderu56 Posted December 5, 2010 Share Posted December 5, 2010 verifica releu de dezaburire ala este cel care creaza problememle iar rezistenta de la luneta nu se rapara se inlocuieste luneta am incercat eu sa repar la un prieten si nu a mers Link to comment
Dang Posted December 7, 2010 Share Posted December 7, 2010 Va salut, Am si eu o problema la o nubira 2 sx. Azi dimineata dupa ce am pornit la drum am observat ca nu se mai deschideau geamurile. Am reincercat dar nimic. Apoi am observat ca nici aeroterma si nici dezaburirea nu mai functioneaza. Am schimbat siguranta de la tabloul din interior (cea din al saselea loc de pe partea drapta a tabloului), dar nimic. Poate sa ma ajute cineva cu un sfat? Exista si alta siguranta poate pe la tabloul de la motor? sau vreun releu? Astept cu nerabdare sfaturile voastre pentru ca pe vremea asta se cam aburesc toate geamurile si nu pot sa merg mai mult de 5 minute cu ea. Link to comment
nino Posted December 7, 2010 Share Posted December 7, 2010 (edited) Tot la Nubira II a cumnatului meu a aparut aceeasi problema si defectul a fost un cablaj impuscat, care a fost inlocuit cu totul... Cost... imens... undeva la 900 RON !!! Poti verifica inainte releele si sigurantele din compartimentul motor... Edited December 7, 2010 by nino Link to comment
Dang Posted December 7, 2010 Share Posted December 7, 2010 @nino: tocmai m-ai incurajat, dar cum ai spus o sa verific releele si sigurantele din compartimentul motor. Am descoperit intr-un manual de service ca o legatura cu aceste functii ar avea si un asa numit RELEU APRINDERE 2 (asa este numit in manual), precum si o o siguranta EF7 (20A). O sa ma mai interesez si astept in continuare si alte pareri. multumesc Link to comment
nino Posted December 7, 2010 Share Posted December 7, 2010 Schimba releul "Aprindere 2" cu cel de claxon, de exemplu... (parca sunt identice...) Link to comment
