Consum Aveo 5 Usi Motorizare De 1.2
SUNT PE CALE SA ACHIZITIONEZ UN AVEO 5 USI CU MOTOR DE 1,2 DAR AM AUZIT URMATOARELE ZVONURI CA UN OPEL CORSA DE 1.2 CMC, CONSUMA MAI MULT ( 11~12l/100) DECAT UN OPEL CORSA DE 1.4 CMC PE IDEA CA FIIND MOTOR MAI MIC, MUNCESTE MAI GREU . DE CE AM FACUT MENTIUNEA ASTA, PTR CA DE LA REPREZENTANTA MI-A SPUS CA MODELUL ALES DE MINE E DOTAT CU MOTOR DE OPEL CORSA CU 16 VALVE,1.2 CMC, DOUA AXE CU CAME, 85/CP. STIE CINEVA CARE E CONSUMUL REAL URBAN A UNUI CHEVY AVEO 5 USI CU MOTOR DE 1.2CMC ? MA INTERESEAZA INFORMATIILE DOAR DESPRE ACEASTA CAROSERIE(5 USI) SI NU ALTA .PREFERABIL INF. CAT MAI SIGURE NU DE GENUL " am eu o cunostinta care...". N-AS VREA SA SCAP DE UN ESPERO DE 1.5 CARE IMI IA 14,5 L/100 KM URBAN SI SA DAU DE UN AVEO CARE IMI IA 11~ 12 L / 100KM !
SAU ALTFEL PUSA PROBLEMA; AR CONSUMA UN AVEO DE 1.4 CMC 8 VALVE SAU UN AVEO SEDAN DE 1.4 CMC MAI PUTIN DECAT UN AVEO 5 USI DE 1.2 CMC ???
MA INTERSEAZA DOAR CONSUMUL URBAN ATAT !
VA ROG SA IMI RASP. CAT DE REPEDE PUTETI !
MULTUMESC
La mine se poate vorbi doar de un consum mediu, deoarece stau intr-un oras mic si am drumuri dese spre comunele vecine. In medie 7,5-7,9.
Daca te intereseaza consumul, poate cauti ceva diesel.
N-AS RISCA; RAMAN TOTUSI LA BENZINA
LA DIESEL CAND TE-A LASAT POMPA DE MOTORINA TREBUIE SA MAI CUMPERI IN MOMENTUL ALA INCA UN SFERT DE MASINA APROAPE SA O INLOCUIESTI
CA EX. LA ULTIMELE MODELE DE DACIE LE-A PUS MOTOR DIESEL, -MA REFER LA DACIILE VECHI CU CAPOTA DECUPATA CA SA AIBA LOC FILTRTUL DE AER-LA ALEA POMPA E 1500 DE EURO; FA SI TU SOCOTEALA :o
TO BENZINA !!!
MULTAM FAIN DE RASPUNS !
  naicul2006 said:
... AM AUZIT URMATOARELE ZVONURI CA UN OPEL CORSA DE 1.2 CMC, CONSUMA MAI MULT ( 11~12l/100) DECAT UN OPEL CORSA DE 1.4 CMC PE IDEA CA FIIND MOTOR MAI MIC, MUNCESTE MAI GREU ...
La ce dracu sa munceasca mai greu un motor pe un traseu urban, la stopuri ? Nu va uitati la caracteristicile tehnice ale motoarelor pe care le comparati ? Motorul de 1,2L DOHC are varful de cuplu la cea mai mica turatie din gama, 3.800 rpm in comparatie cu 4.200 rpm. Dupa parerea vecinilor, producatorii sunt chiar tampiti sa puna un motor mai slab si mai gurmand pe aceeasi masina. Nu in ultimul rand, unde ai citit ca motorul S-TEC II de pe Aveo este motorul de pe Opel Corsa ?
NU AM CITIT, E ZICERE DE LA DEALER :grumpy:
...SI DA LA PLECAREA DE PE LOC, CA SA INVINGA INERTIA MASINII CONSUMUL E MAI MARE. CUM ITI EXPLICI CA LA DRUM INTINS DECI FARA PORNIRI "DE PE LOC" CONSUMUL SE INJUMATATESTE ? ZIC SI EU !
AM VAZUT LA O MASINA -NU CONTEAZA MARCA, LA COMPUTERUL DE BORD CA AFISA LA PLECAREA DE PE LOC CONSUM PESTE 14 DOAR CATEVA SECUNDE SI APOI REVENEA PE LA 8~ 9 DAR DACA E ASA CUM SPUI TU , N-AM DECAT SA MA BUCUR DOAR CA AS VREA SA IMI EXPLICI SI DE CE.
IMI CER SCUZE DACA NU POT SA IAU O AFIRMATIE DOAR ASA CA E SCRISA UNDEVA
MACAR SA O TREC PRIN BIBILICA MEA PUTIN
MULTUMESC
Ia in consideratie declaratiile producatorului, sunt singurele autorizate. Daca ai cunoaste cum masoara un asa zis Computer de Bord consumul "instantaneu", n-ai mai pune pret pe asa ceva.
Între 8 şi 12. Depinde de condiţiile de trafic, durata medie a deplasărilor (adică dacă apucă motorul să se încălzească), temperatura exterioară, AC ON sau OFF, greutatea tălpii etc. Cel mai adesea, în Bucureşti se încadrează între 9,5 şi 10. Dacă îţi faci un "ţel în viaţă" din consum, poţi scoate şi 8. Aşa cum, dacă eşti mai "nervos", poţi scoate şi 12.
LE: Nu vrei tu să citeşti topicul recomandat de Ciolanus (ai acolo destule informaţii), dar să ştii că tot acolo or să ajungă în cele din urmă şi posturile din topicul ăsta... :)
Edited by rm.popa
  naicul2006 said:
Chiar nu e nimeni cu aveo de 1.2-5d, sa-mi spuna cat ai papa exclusiv urban ??? -ce viata cruda :->
Depinde la ce motor te referi. Cel de 1,2 8V 85 CP s-ar putea sa fie mai economic . Eu am sedan 1,2 8V, care e mai greu ca Hb-ul, si in oras am scos minim 8,7 (fara A/C - cu A/c cam 9) cu el. Iarna, am scos si 9,5. Benzina utilizata a fost MOL 95. Dar asta cred ca are mai putina importanta. In afara am scos cel mai putin 5,5%. Mi se pare ca pe noul aveo HB ca si pe sedan , motoarele sunt de la Opel. Pe sedan au lasat motorul 1,2 8V. Consumul in oras depinde mult de trafic, si oricum Bucurestiul e un oras in care scoti un consum mult mai mare. Se zicea aici pe forum de consumul urban in Bucuresti si consumul urban in alte orase.
Daca te referi la motorul de 1,2-16V, consumul dat de producator este:
-extraurban 4,6 l/100 km
-urban 7,2 l/100 km
-mixt 5,5 l/100 km
Offtopic: si la mine scrie 7,2 urban si imi consuma 9-10 :D Bine, depinde si de fiecare cum merge. Consumurile date de producator sunt relative.. nu o sa poti scoate vreodata exact ca in carte.
  Axel7 said:
... Consumurile date de producator sunt relative.. nu o sa poti scoate vreodata exact ca in carte.
Gresit, consumul dat de catre producator este absolut pentru ca este determinat pe baza unei norme, consumul fiecaruia este relativ, dupa cum conduce fiecare, cu ochii carpiti de somn, in ce localitati, pe ce strazi si la ce ore. Imi place cum confunda unii consumul urban cu mersul bara la bara, cand vin/merg (de) la servici ("ca pestii in plasa"), cu pacurina de la Lukoil si filtre de aer schimbate la 15k km, iar ei zic ca atata consuma masina, ca producatorul minte.
Oricum, imi place ca ati ajuns la concluzia rationala ca un motor de capacitate cilindrica mai mica consuma mai putin, macar cu 1L la suta de km. Macar asa, afla si producatorul de ce face motoare mai mici, ca pana acum nu stia.
Da, m-am exprimat gresit, ai dreptate. Dar filtrele le schimb totusi la 7500 si benzina e intotdeauna aceeasi la fel ca si consumul. Ce-i drept, am scos si 8,5 dar mai rar. Asta e adevarul, la 1-2 L fata de cat da producatorul, asta e consumul.
pai de ce nu o faci pe gpl daca tot te intereseaza consumul...
la diesel nu pica asa usor pompa de inalta presiune si injectoarele. (chestiile astea pica la motoarele common rail)
Edited by rich1974
Acelasi lucru a spus si dealarul de unde am vrut sa iau si eu, ca motoarele de 1.2 modelul 2009, fabricate dupa luna septembrie 2008, sint luate de pe Opel. Si aveau un consum mai mic, decit modelul 2008, diferenta la pret era undeva la 1000 euro.
Consumul pina la urma il faci tu cit de cit constant, dupa ce te obisnuesti cu masina.
Chevrolet spune ca a pus motorul S-TEC II, Opelul se lauda cu motorul ECOTEC Twin Port. Dupa mintea mea sunt doua lucruri diferite, care n-au legatura unul cu celalalt.
Poate că le-au luat de tot şi au pus altceva pe Opel? =))
  naicul2006 said:
am citit toate posturile; dupa asta am senzatia ca am sa optez totusi ptr un aveo 1.4 4d full options "so be it"
Si va multumesc :uff:
Crede-ma, asta ar fi cea mai inspirata alegere. Eu unul, la ce necesitati sunt in ziua de azi in trafic (uneori nevoia de a demara foarte puternic, alteori in depasiri ai nevoie de putere mare, s.a.m.d.), nu as alege motorul de 1.2.
Daca ai fi ferm convins ca vei merge 90% numai in oras, atunci 1.2 in 5 usi ar fi alegerea cea mai inspirata.
Dupa ce se va lasa motorul (3000-4000 km), o sa vezi cum se infige :)
Consumul la Aveo este direct proportional cu talpa in acceleratie pe care i-o dai. Daca mergi frumos cu ea, in 2500-3500 ture, vei obtine un consum de maxim 7.5-8%.
Sa ne zici si noua dupa ce-l cumperi!
