ticodriver Posted January 16, 2006 Share Posted January 16, 2006 Pana la urma stie cineva cat au stergatoarele la tico (sofer si pasager) in cm? Link to comment
Florinut Posted January 17, 2006 Share Posted January 17, 2006 Stiu ca stergatoarele de Tico nu au aceeasi lungime unul cu celalalt, sofer -pasager. La un service Daewoo iti vor spune exact. Link to comment
dinoc Posted January 17, 2006 Share Posted January 17, 2006 Am luat Champion,de 48 cm pt Nubira2.Pretul pe masura:47,6 RON la Mol.(2 buc.) Rezultatul :silentioase,merg ca 'unse',nu lasa dare,nu scartaie...deocamdata!! La Nubira 2 cele de 48cm sunt putin mai scurte decat cele originale, cred ca X51E ar fi dimensiunea corecta, nu ? Link to comment
Florinut Posted January 17, 2006 Share Posted January 17, 2006 Eu am pus Champion de 50 cm la N2 si sunt Ok Link to comment
dinoc Posted January 17, 2006 Share Posted January 17, 2006 (edited) Eu 51 Champion la Nubi2 - si sunt tot ok (pe ele scrie Nubira 1999-2002). Edited January 17, 2006 by dinoc Link to comment
Sharpe Posted January 17, 2006 Share Posted January 17, 2006 Cele originale pt Nubira2 au 48cm.Nu stiu de unde ai scos 51cm dimensiunea corecta... Link to comment
dinoc Posted January 17, 2006 Share Posted January 17, 2006 (edited) Pai compara Champion 48 cu cele originale si vezi ca primele sunt un pic mai mici (cel putin asa-i la mine). Champ48 scrie pe ele Nubira 2003 (care in occident (sunt made in Belgia) inseamna Nubira 3, iar Nubira 2 este pana in 2002). Pe Champ X51E scrie Nubira 1997-2002 si sunt de 50 cm (cam cat are stergatorul original la mine). Edited January 17, 2006 by dinoc Link to comment
Pedala Posted January 17, 2006 Share Posted January 17, 2006 La Tico sunt egale, la Matiz sunt inegale Link to comment
Florinut Posted January 18, 2006 Share Posted January 18, 2006 Eu am avut Tico si m-am dus la service Daewoo si am cerut stergatoare pt el. Cand mi-au spus cat costa, am zis ca iau cu juma de pret de la Petrom. Atunci mi-au spus sa cumpar 2 seturi, unul mai lung si unul mai scurt, pt ca cele originale sunt inegale. Si mi-au si aratat, crede-ma te rog! Link to comment
AAdorjan Posted January 18, 2006 Share Posted January 18, 2006 Eu la Tico pe fata am doua de 45cm, deci egale si sunt pana la marginea parbrizului sunt un pic mai lungi decat originalele dar acopera o suprafata mai mare Link to comment
Sharpe Posted January 18, 2006 Share Posted January 18, 2006 OK!Nu are rost sa ne caraim pt niste stergatoare.A mea e din 2000 si are de 48cm, a ta e mai noua si sunt de 50cm.Fiecare le-a inlocuit dupa ce le-a masurat pe cele de pe masina. Link to comment
Vlad Posted January 20, 2006 Share Posted January 20, 2006 si eu la cielo aveam o dimensiune standard( habar nu am care) si am pus mai mari pt. ca alea erau mici Link to comment
Tommy Posted January 20, 2006 Share Posted January 20, 2006 45 la cielo, merg si 2-3 cm mai lungi Link to comment
ticodriver Posted January 21, 2006 Share Posted January 21, 2006 Pana la urma am pus la ticozaur in stanga stergator de matiz stanga (53 cm) si in dreapta pe cel de 40cm - merg la fix - cred ca astea erau dimensiunile si la cele originale. Link to comment
AAdorjan Posted January 21, 2006 Share Posted January 21, 2006 53cm??? Esti sigur? Eu am 45cm la ambele iar varful celui din dreapta ajunge chiar pana la marginea parbrizului. Link to comment
ticodriver Posted January 22, 2006 Share Posted January 22, 2006 (edited) Cel putin asa scrie pe cutia stergatorului (Alca): 21" - 530mm; sincer, nu am stat sa il masor. Cel din dreapta e de 40cm, cel din stanga e de 53. Edited January 22, 2006 by ticodriver Link to comment
ZLI Posted February 14, 2006 Share Posted February 14, 2006 La Tico sunt egale, la Matiz sunt inegale cum să fie egale la tico?? nu sunt egale decât dacă le-a schimbat cineva care nu ştia despre ce e vorba. eu vreau să cumpăr valeo... are cineva vre-o părere? oricum trebuie să mă combin cu un ticolos la două cutii Link to comment
dirman Posted February 14, 2006 Share Posted February 14, 2006 Salutare tuturor!!! cine stie sa-mi spuna si mie ce dimensiuni de lamela de stergatoare sa-mi iau la matiz, pt. ca sunt diferite, si mie mi le-a furat (nu spun cine). eu acu folosesc o pereche de stergatoare cu lamelele egale, si e ca naiba, imi lasa portiuni nesterse, etc. multumesc anticipat pt. ajutor. Link to comment
remix Posted February 14, 2006 Share Posted February 14, 2006 @ZLI - n-am nici o parere dar alea asa zis "originale" cumparate de la magazinul de piese Daewoo de pe Vacaresti sunt destul de slabute. Deja imi scartzaie daca e ploaie sau zapada si nu au nici 1 an. Si nici nu sterg exagerat de bine, imi lasa o portiune destul de insemnata doar frecata, nestearsa, in partea de stanga jos. Parca m-as combina eu cu tine la un set Valeo, acum depinde si de scor. Link to comment
ZLI Posted February 15, 2006 Share Posted February 15, 2006 la fel si la mine le luam impreuna? sau le iau eu si vin cu ele la intalnire? am vazut la un petrom spre A1 Link to comment
Tommy Posted February 15, 2006 Share Posted February 15, 2006 A cumparat un coleg alaltaieri Champion de la Mol Calarasi. Cand sa le monteze... supriza, erau stergatoare romanesti inauntru. Dupa scandalul de rigoare i le-au schimbat, noroc ca pastrase cutia. Link to comment
ticodriver Posted February 15, 2006 Share Posted February 15, 2006 @dirman - la Matiz, ca si la Tico iti trebuie de 53cm (20"), respectiv 40cm (16''). Link to comment
AAdorjan Posted February 15, 2006 Share Posted February 15, 2006 Care e diferenta daca pun stergatoare 53cm / 40cm sau 45cm / 45cm? Ma refer la performanta, portiuni nesterse, suprasolicitarea mecanismului etc. Link to comment
BAD_MF Posted February 15, 2006 Share Posted February 15, 2006 Singura diferenta e lungimea, cu cat e mai lung cu cat sterge o suprafata mai mare din parbriz, in functie de masina este marimea parbrizului si deci si marimea corespunzatoare a stergatoarelor. Modelele de 53 cm sunt imense pentru tico(ies in afara parbrizului), poti sa pui doar cu o idee mai mare decat ce ai original , mai mult nu are rost. Iar motorasul, nu cred ca e solicitat mult mai mult la o marime mai mare. Link to comment
