wol Posted October 7, 2010 Author Share Posted October 7, 2010 On 10/7/2010 at 5:04 PM, MHM said: Volan, cutie de viteze? La ce pret? volan 30, dar vine cineva sambata sa-l ia, cutia o pasterz pentru mine, am uitat sa scriu asta daca nu ia volanul sambata, te anunt Link to comment
jorky1987 Posted October 8, 2010 Share Posted October 8, 2010 polita spate????????? 1 Link to comment
oviliv79 Posted October 8, 2010 Share Posted October 8, 2010 oare scaunul sofer se potriveste la tico? Link to comment
wol Posted October 8, 2010 Author Share Posted October 8, 2010 On 10/8/2010 at 3:38 PM, jorky1987 said: polita spate????????? imi pare rau nu o mai am, am scris mai sus On 10/8/2010 at 4:54 PM, oviliv79 said: oare scaunul sofer se potriveste la tico? este la un prieten cu tico, imi da raspunsul in 2 zile... nu se potriveste el incearca sa faca niste piese... daca nu reuseste revine la vanzare si daca esti tu mai inventiv atunci se potriveste, dar sa-l iei si sal pui pur si simplu nu se poate Link to comment
mihu4 Posted October 9, 2010 Share Posted October 9, 2010 Mutumesc pentru volan si sistemu de actionare stergatoare. Astept un semn cu intermediara, cand ai timp. Link to comment
sorinuif Posted October 12, 2010 Share Posted October 12, 2010 salut , jantele le mai ai si la ce pret Link to comment
wol Posted October 13, 2010 Author Share Posted October 13, 2010 (edited) On 10/12/2010 at 10:56 PM, sorinuif said: salut , jantele le mai ai si la ce pret doar 2 jante, 50 ron bucata Edited October 13, 2010 by wol Link to comment
nsmoga Posted October 13, 2010 Share Posted October 13, 2010 sal, nu vinzi corpul de sony? Link to comment
wol Posted October 14, 2010 Author Share Posted October 14, 2010 On 10/13/2010 at 6:05 PM, nsmoga said: sal, nu vinzi corpul de sony? am gasit fata la el, daca vrei il vand cu totul 120 ron On 10/13/2010 at 9:30 PM, MHM said: Oglinda stanga este? nu, mai am doar dreapta, cu reglaj interior Link to comment
wol Posted October 16, 2010 Author Share Posted October 16, 2010 > nu mai sunt: motor, usa stanga, usa dr. aripa dr, aripa stanga, alternator, electromotor, bloc sigurante motor, semnal dr si plasticul de sub far dr., capota, etrieri,somda lambda, geam dr fata, scaun sofer,far dr,semnal st,planetara dreapta, fuzeta dr., disc frana dr., luneta > nu am polita portbagaj > rezervate: grila stergatoare, 2 jante,contact+chei+butuci usi+butuc portbagaj, ceasuri bord > donez scaun dreapta afectat de accident (mai precis mecanismul de miscare al spatarului) >au ramas: comutator semnalizare SE (cu proiectoare) 40 far st cu motoras 80 plastic sub far st 10 grila plasctic stergatoare 40, brat stergator fata 15 buc oglinda dr cu reglaj interior 60, parbriz SE ( cu parasolar) 200 bord (fara capac airbag) 180, ceasuri bord 60, coloana directie 60 caseta directie 150 ansamblu filtru aer 70 calorifer 100, tetiere spate 20 bucata, 30 amandoua tetiera scaun dr 20 polite portbagaj, cele pe care se prind boxele, 30 setul, sau 120 cu boxe standard, de fabrica geam lateral st + cheder 60 macarale geam (model E)40 geam triunghiular usa fata + cheder 40 mecanism inchidere usa 20 buc electroventilator 170 calculator 150 catalizator + toba 300 toba finala 100 pompa benzina 150 rezervor benzina 50 usita rezervor 10 pompa frana + servo 100 disc frana putin uzat st. 50 buc ansamblu fuzeta cu rulment si disc stanga 130 buc arc+amortizor fata st si dr 100 buc si multe altele... toate preturile sunt in ron si negociabile tel: 0786980300 Link to comment
cristics Posted October 17, 2010 Share Posted October 17, 2010 Salut. Ofer 60 ron cu tot cu transport pe ceasurile de bord. Astept PM. Link to comment
nsmoga Posted October 20, 2010 Share Posted October 20, 2010 salut, centurile de pe spate, doar partea care iese din bancheta? (daca se potivesc la tico) Link to comment
wol Posted October 21, 2010 Author Share Posted October 21, 2010 On 10/20/2010 at 8:35 PM, nsmoga said: salut, centurile de pe spate, doar partea care iese din bancheta? (daca se potivesc la tico) pai nu pot sa le descomplectez, iti dau tot setul (si ai scapat si de problemele de compatibilitate) 100 ron toate, sunt 3, doua automate in 3 puncte si una reglabila in 2 puncte, cea din mijloc Link to comment
wol Posted October 22, 2010 Author Share Posted October 22, 2010 (edited) On 10/21/2010 at 6:30 AM, wol said: pai nu pot sa le descomplectez, iti dau tot setul (si ai scapat si de problemele de compatibilitate) 100 ron toate, sunt 3, doua automate in 3 puncte si una reglabila in 2 puncte, cea din mijloc am verificat si la centura din st e distrus mecanismul (de la accident), deci pot sa-ti dau centura st si pentru 50 ron Edited October 22, 2010 by wol Link to comment
wol Posted October 24, 2010 Author Share Posted October 24, 2010 On 10/22/2010 at 3:42 PM, wol said: am verificat si la centura din st e distrus mecanismul (de la accident), deci pot sa-ti dau centura st si pentru 50 ron am vrut sa zic: "deci pot sa-ti dau centura stanga si centru pentru 50 ron" Link to comment
wol Posted October 27, 2010 Author Share Posted October 27, 2010 > nu mai sunt: motor, usa stanga, usa dr. aripa dr, aripa stanga, alternator, electromotor, bloc sigurante motor, semnal dr si plasticul de sub far dr., capota, etrieri,somda lambda, geam dr fata, scaun sofer,far dr,semnal st,planetara dreapta, fuzeta dr., disc frana dr., luneta, jante, > nu am polita portbagaj > rezervate: grila stergatoare,contact+chei+butuci usi+butuc portbagaj, ceasuri bord >au ramas: comutator semnalizare SE (cu proiectoare) 40 far st cu plasticul bun, fara urechi rupte cu motoras 80 plastic sub far st 10 grila plasctic stergatoare 40, brat stergator fata 15 buc oglinda dr cu reglaj interior 60, parbriz SE ( cu parasolar) 200 bord (fara capac airbag) 180, ceasuri bord 60, coloana directie 60 caseta directie 150 ansamblu filtru aer 70 calorifer 100, aeroterma 100 tetiere spate 20 bucata, 30 amandoua polite portbagaj, cele pe care se prind boxele, 30 setul, sau 120 cu boxe standard, de fabrica geam lateral st + cheder 60 macarale geam (model E)40 geam triunghiular usa fata + cheder 40 mecanism inchidere usa 20 buc electroventilator 170 calculator 150 catalizator + tot ansamblu toba 300 toba finala 100 pompa benzina 150 rezervor benzina 50 usita rezervor 10 pompa frana + servo 100 disc frana putin uzat st. 50 buc ansamblu fuzeta cu rulment si disc stanga 130 buc arc+amortizor fata st si dr 100 buc punte spate completa 200 si multe altele... toate preturile sunt in ron si negociabile tel: 0786980300 Link to comment
iuli34 Posted October 27, 2010 Share Posted October 27, 2010 On 10/13/2010 at 10:22 AM, wol said: doar 2 jante, 50 ron bucata Salut, mai sunt jantele? Link to comment
wol Posted October 27, 2010 Author Share Posted October 27, 2010 On 10/27/2010 at 4:50 PM, iuli34 said: Salut, mai sunt jantele? nu, imi pare rau, azi am dat ultimele 2 Link to comment
narcais Posted November 4, 2010 Share Posted November 4, 2010 Ma intereseaza suportul de CD(casetofon) din bord. Link to comment
wol Posted November 5, 2010 Author Share Posted November 5, 2010 On 11/4/2010 at 12:27 PM, narcais said: Ma intereseaza suportul de CD(casetofon) din bord. nu avea suportul, CD-ul era "prins" acolo... era facuta o improvizatie Link to comment
Uncle-Sam Posted November 11, 2010 Share Posted November 11, 2010 consola de la schimbator mai este? daca da, la ce pret? merci Link to comment
hmalex87 Posted November 14, 2010 Share Posted November 14, 2010 mai ai aripa stanga fata, ma intereseasu si aripile spate dar din poze ma indoiesc ca mai sunt bune Link to comment
wol Posted November 19, 2010 Author Share Posted November 19, 2010 On 11/11/2010 at 12:36 PM, Uncle-Sam said: consola de la schimbator mai este? daca da, la ce pret? merci da, 50 ron Link to comment
wol Posted November 20, 2010 Author Share Posted November 20, 2010 > nu mai sunt: motor, usa stanga, usa dr. aripa dr, aripa stanga, alternator, electromotor, bloc sigurante motor, semnal dr si plasticul de sub far dr., capota, etrieri,somda lambda, geam dr fata, scaun sofer,far dr,semnal st,planetara dreapta, fuzeta dr., disc frana dr., luneta, jante,contact+chei+butuci usi+butuc portbagaj > nu am polita portbagaj, nu mai am jante > rezervate: grila stergatoare,, ceasuri bord, tetiere spate >au ramas: comutator semnalizare SE (cu proiectoare) 40 far st cu plasticul bun, fara urechi rupte cu motoras 80 plastic sub far st 10 grila plasctic stergatoare 40, brat stergator fata 15 buc oglinda dr cu reglaj interior 60, parbriz SE ( cu parasolar) 200 bord (fara capac airbag) 180, ceasuri bord 60, coloana directie 60 caseta directie 150 ansamblu filtru aer 70 calorifer 100, aeroterma 100 tetiere spate 20 bucata, 30 amandoua polite portbagaj, cele pe care se prind boxele, 30 setul, sau 120 cu boxe standard, de fabrica geam lateral st + cheder 60 macarale geam (model E) 40 geam triunghiular usa fata + cheder 40 mecanism inchidere usa 20 buc electroventilator 170 calculator 150 catalizator + tot ansamblu toba 300 toba finala 100 pompa benzina 150 rezervor benzina 50 usita rezervor 10 pompa frana + servo 100 disc frana putin uzat st. 50 buc ansamblu fuzeta cu rulment si disc stanga 130 buc arc+amortizor fata st si dr 100 buc punte spate completa 200 si multe altele... toate preturile sunt in ron si negociabile tel: 0786980300 Link to comment
