Muratu Posted October 8, 2011 Share Posted October 8, 2011 Am nevoie de 2 mufe de becuri h4 (mufele care se conecteaza la becurile farurilor) 0 siguranta de 15a si una de 20A. Link to comment
wol Posted October 8, 2011 Author Share Posted October 8, 2011 On 10/8/2011 at 2:31 PM, Muratu said: Am nevoie de 2 mufe de becuri h4 (mufele care se conecteaza la becurile farurilor) 0 siguranta de 15a si una de 20A. 20 ron toate. Suna-ma luni. Link to comment
FootDeRoop Posted October 15, 2011 Share Posted October 15, 2011 un set de jante pt matiz/spark la ce pret? Link to comment
wol Posted October 16, 2011 Author Share Posted October 16, 2011 On 10/15/2011 at 12:30 PM, FootDeRoop said: un set de jante pt matiz/spark la ce pret? nu, imi pare rau nu mai am jante Link to comment
lusian Posted October 17, 2011 Share Posted October 17, 2011 tablou de bord matiz 2004 ( tot ansamblul kilometraj, indicator benzina, temperatura ulei).Aveti? la ce pret? Link to comment
wol Posted October 17, 2011 Author Share Posted October 17, 2011 On 10/17/2011 at 11:29 AM, lusian said: tablou de bord matiz 2004 ( tot ansamblul kilometraj, indicator benzina, temperatura ulei).Aveti? la ce pret? da, 50 ron, e lista mai sus cu majoritatea pieselor, binenteles mai am si altele Link to comment
wol Posted October 28, 2011 Author Share Posted October 28, 2011 > nu am polita portbagaj, nu mai am jante >au ramas si se mai adauga de la un matiz 2002 si unul 2005: tripla st 60 ron bucata ansamblu stransmisie miscare de la motor la stergatoare, fata 30 ron motor stergatoare fata 50 ron vas spalator parbriz SE 2 gauri 40 ron vas expansiune 20 ron usa spate dr 150 ron cablu + mecanism deschidere capota 20 ron parasolar st + dr 10 ron scaun sofer 80 ron scaun pasager 80 ron bancheta spate 100ron centuri fata 25 ron bucata ceasuri bord 50 ron consola centrala 35 ron plafoniera 15 ron calorifer 100 ron tetiere spate 40 ron ambele plastic sub far dr 10 ron buc brat stergator fata 15 buc oglinda dr cu reglaj interior 60, oglinda st geam crapat 20 oglinda exteriora st si dr 40 ron buc bord SE 100 ron bord decolorat 50 ron ansamblu directionare aer 50 tubulatura aer (cea din bord) 50 coloana directie 60 aeroterma 80 polite portbagaj, cele pe care se prind boxele, 30 setul, sau 100 cu boxe standard, de fabrica macarale geam doar fata (model E) 30 buc geam usa st si dr fata cu cheder 50 ron buc geam usa spate st+dr cu cheder 50 geam triunghiular usa fata + cheder 30 mecanism inchidere usa 20 buc ansamblu schimbator 30 ron electroventilator 100 calculator 150 rezervor benzina 40 gura umplere rezervor 25 ron usita rezervor 10 pompa frana + servo 100 fuzeta + disc+rulment 70 ron etrieri 150 ron (ambi) bascula 40 ron planetara 100 ron arc+amortizor fata st+dr 100 buc electromotor 150 ansamblu pedalier 100 ron orice piesa de la injectie bara stabilizatoare 50 bobina inductie Euro2 30ron cablu ambreiaj 20ron cabluri schimb viteze 50 ron cablu vitezometru 20ron comutator stergatoare 20 ron comutator semnalizare 20 ron bloc comanda climatizare cel cu butoane 80ron retrovizoare interioara 20ron senzor acceleratie 50 ron parbriz SE cu parasolar inclus 200 ron haion albastru cu luneta si un pic de rugina si 2 grile de dezaburire intrerupte 300 ron capota albastra 130 ron set geamuri cu tenta verde (originale) 250 ron sau 50 si geamuri normale la schimb IAC 50 ron bloc motor complet 400 cutie de viteze 400 ron si multe altele... tel: 0786980300 Link to comment
bebe2000 Posted October 31, 2011 Share Posted October 31, 2011 Motor geam stânga pt Matiz? Link to comment
wol Posted October 31, 2011 Author Share Posted October 31, 2011 On 10/31/2011 at 10:29 AM, bebe2000 said: Motor geam stânga pt Matiz? nu am nimic de SE Link to comment
Fisman Posted November 3, 2011 Share Posted November 3, 2011 Salut. O bara fata pentru Matiz din 2006 ai? Ce culoare si la ce pret se da? La fel si pentru semnalizatorul stanga fata (din bara). Exista posibilitatea de trimitere in Constanta? Multumesc. Link to comment
wol Posted November 3, 2011 Author Share Posted November 3, 2011 On 11/3/2011 at 8:29 AM, Fisman said: Salut. O bara fata pentru Matiz din 2006 ai? Ce culoare si la ce pret se da? La fel si pentru semnalizatorul stanga fata (din bara). Exista posibilitatea de trimitere in Constanta? Multumesc. din pacate am doar posibilitate de trimitere in Constanta (am un priten care vine acolo o data pe sapt), dar bara nu am decat crapate, iar semnal nu am imi pare rau.. Link to comment
Fisman Posted November 3, 2011 Share Posted November 3, 2011 Multumesc pentru raspunsul prompt. Link to comment
wol Posted November 12, 2011 Author Share Posted November 12, 2011 > nu am polita portbagaj, nu mai am jante >au ramas si se mai adauga de la un matiz 2002 si unul 2005: ansamblu stransmisie miscare de la motor la stergatoare, fata 30 ron motor stergatoare fata 50 ron vas spalator parbriz SE 2 gauri 40 ron vas expansiune 20 ron usa spate dr 150 ron cablu + mecanism deschidere capota 20 ron parasolar st + dr 10 ron scaun sofer 80 ron scaun pasager 80 ron bancheta spate 100ron centuri fata 25 ron bucata ceasuri bord 50 ron consola centrala 35 ron plafoniera 15 ron calorifer 100 ron tetiere spate 40 ron ambele plastic sub far dr 10 ron buc brat stergator fata 15 buc oglinda dr cu reglaj interior 60, oglinda st geam crapat 20 oglinda exteriora st si dr 40 ron buc bord SE 100 ron bord decolorat 50 ron ansamblu directionare aer 50 tubulatura aer (cea din bord) 50 coloana directie 60 aeroterma 80 polite portbagaj, cele pe care se prind boxele, 30 setul, sau 100 cu boxe standard, de fabrica macarale geam doar fata (model E) 30 buc geam usa st si dr fata cu cheder 50 ron buc geam usa spate st+dr cu cheder 50 geam triunghiular usa fata + cheder 30 mecanism inchidere usa 20 buc ansamblu schimbator 30 ron electroventilator 100 calculator 150 rezervor benzina 40 gura umplere rezervor 25 ron usita rezervor 10 pompa frana + servo 100 fuzeta + disc+rulment 70 ron etrieri 150 ron (ambi) bascula 40 ron planetara 100 ron arc+amortizor fata st+dr 100 buc electromotor 150 ansamblu pedalier 100 ron orice piesa de la injectie bara stabilizatoare 50 bobina inductie Euro2 30ron cablu ambreiaj 20ron cabluri schimb viteze 50 ron cablu vitezometru 20ron comutator stergatoare 20 ron comutator semnalizare 20 ron bloc comanda climatizare cel cu butoane 80ron retrovizoare interioara 20ron senzor acceleratie 50 ron parbriz SE cu parasolar inclus 150 ron haion albastru cu luneta si un pic de rugina si 2 grile de dezaburire intrerupte 300 ron set geamuri cu tenta verde (originale) 250 ron sau 50 si geamuri normale la schimb IAC 50 ron pompa benzina 200ron bloc motor 200ron cutie de viteze 400 ron si multe altele... tel: 0786980300 Link to comment
palform1 Posted December 3, 2011 Share Posted December 3, 2011 salut!as vrea din lista de mai sus blocul comanda semnalizare la 20 ron insa as mai avea nevoie de: -aripa dr fata -far dr fata -bara fata -semnalizatorul din bara dr. spune-mi daca mai ai ceva din cele enumerate.merci! Link to comment
sergiu2010 Posted December 3, 2011 Share Posted December 3, 2011 Salut! ! Ai cumva bara spate neagra? Link to comment
wol Posted December 4, 2011 Author Share Posted December 4, 2011 On 12/3/2011 at 5:51 PM, sergiu2010 said: Salut! ! Ai cumva bara spate neagra? da, 80 ron, dar trebuie sa verific starea ei, nu mai stiu daca e fara craparuri, te anunt luni dupaamiaza Link to comment
adrian05 Posted December 4, 2011 Share Posted December 4, 2011 salut buton/comutator lampa ceata matiz? pret? Link to comment
wol Posted December 5, 2011 Author Share Posted December 5, 2011 (edited) On 12/4/2011 at 4:02 PM, calinjack said: da ceas ,ai ceas? am unul de nubira, dar nu l-am testat, vroiam sa-l pun la damas dar nu prea-i gasesc locul, daca te intereseaza vorbim... On 12/4/2011 at 2:51 PM, adrian05 said: salut buton/comutator lampa ceata matiz? pret? da 15 ron Edited December 5, 2011 by wol Link to comment
umbra Posted December 5, 2011 Share Posted December 5, 2011 Salut, furtunul de benzina il ai? E ceva din plastic, are niste articulatii, face legatura dintre rezervor si locul pe unde alimentezi cu benzina. Link to comment
wol Posted December 6, 2011 Author Share Posted December 6, 2011 On 12/5/2011 at 1:30 PM, umbra said: Salut, furtunul de benzina il ai? E ceva din plastic, are niste articulatii, face legatura dintre rezervor si locul pe unde alimentezi cu benzina. trebuie sa verific, iti spun joi sera daca nu e pera tarziu Link to comment
jupinul Posted December 8, 2011 Share Posted December 8, 2011 far dreapta pt matiz dar fara sticla matuita ai? Link to comment
wol Posted December 9, 2011 Author Share Posted December 9, 2011 se adauga piese matiz euro 3 2005 motor E3, 66 000km, e pe masina se poate proba -1500 ron discutabil cutie de viteze E3, 500 ron bobina inductie E3 200 ron modul cip + cheie + butuc contact + butuci usi si haion 200 ron sonda lambda E3 150 ecu E3 300 instalatie AC completa, cu radiatorul indoit dar inca etans, se poate proba 800 ron si multe altele, din pacate nu pot vinde nimic din ce afecteaza functionarea motorului pana nu vand motorul (pentru proba) Link to comment
sergiu2010 Posted December 18, 2011 Share Posted December 18, 2011 Sal ma mai intereseaza daca ai cumva si polita din spate de la portbagaj cea care vine prinsa de haion si fete usi model SE Link to comment
wol Posted December 18, 2011 Author Share Posted December 18, 2011 imi pare rau, nu am polita Link to comment
