alex2150 Posted July 15, 2011 Author Share Posted July 15, 2011 s-au vandut:delcou 16v, caseta directie ,kilometraj,jamba stg ,rezervor benzina si catalizator Link to comment
alex2150 Posted August 1, 2011 Author Share Posted August 1, 2011 se adauga urmatoarele piese de la alta masina: faruri 2x - 100lei buc capota colantata negreu - 170lei semnazliari stg+dr - 60lei setu semnalizari aripi alungite - 30lei setu oglinzi - 60lei buc aripi stg+dr - 60lei buc bara fata - 150lei proiectoare - 30lei buc macarale+motorase gemuri fata - 70lei buc motor 16v (148.000km) - 600lei cutie viteze - 300lei grila radiator - 45lei carcasa filtru aer - 45lei tub filtru aer - 15lei rezonator - 15lei raditor apa - 110lei radiator caldura - 70lei radiator ac - 110lei alternator - 170lei electromotor- 170lei bobina aprindere - 60lei delcou 16v - 60lei electroventilator - 50lei ventilator auxiliar ac - 50lei ceas bord - 20lei motoras geam electric dr - 50lei bazin antigel - 20lei pompa frana cu servo - 70lei scuturi aparatoare - 20lei buc pompa ambreiaj - 40lei cilindru ambreiaj - 40lei bazin lichid stergatoare+motoras - 30lei caseta directie - 110lei jambe+fuzete 14 stg+dr - 60lei buc discuri+etrieri14 +placute - 200lei ansamblu stergatoare - 50lei motoras stergatoare - 50lei ventilator interior - 50lei timonerie - 40lei ceasuri bord(turometru+km+apa benziana) - 100lei coaja bord - 50lei torpedou - 25lei consola climatizare - 50lei bacgehta spate hackback - 30lei ceas bord - 20lei lampa lumina interior - 15lei cric+cheie roti - 50lei bloc lumini - 20lei panou sigurante - 100lei yale +contact - 80lei contact electric - 20lei punte spate - 100lei toba centrala - 60lei toba catalizator - 50lei sonda lambda - 40lei toba finala hackback - 30lei jante 14"+cauciucuri vara 5xbuc - 300lei capace daewoo 14" - 70lei scrumiere spate - 10lei buc pistonas inchidere sofer - 30lei pistonas inchidere secundar - 25lei actuator portbagaj - 20lei lampi spate hackback (apropae noi) - 30lei consola deschidere portbagaj+rezervor - 15lei rezervor - 40lei injectori 4x - 200lei bara torsiune - 35lei bascule stg+dr - 40lei buc broaste usi - 30lei buc brate stergatoare - 25lei setu suporti portbagaj plafon - 30lei setu arcuri fata - 70lei arcuri spate - 70lei amortizoare fata - 70lei amortizoare spate - 70lei pompa benzina - 80lei +alte piese Link to comment
webcath0s Posted August 2, 2011 Share Posted August 2, 2011 Contact alunecator?E plasticul acela care vine imediat sub volan in forma de cerc cu niste picioruse!!! Link to comment
bella Posted August 2, 2011 Share Posted August 2, 2011 Salut, Sonda Lambda este de pe motor DOHC/16 valve? Daca da, stii sa aiba probleme? Sunt interesat. Link to comment
alex2150 Posted August 7, 2011 Author Share Posted August 7, 2011 update piese: far dr - 90lei far stg ureche lipita - 30lei capota colantata negreu - 170lei capota cu chit pe ea - 50lei semnazliari stg+dr - 50lei setu semnalizari aripi alungite - 25lei setu oglinzi - 60lei buc aripi stg+dr - 60lei buc bara fata - 150lei armatura bara fata +fagure - 50lei armatura bara spate+fagure - 40lei proiectoare - 30lei buc luneta spate berlina - 100lei motoras gem electric dr - 60lei buc motor 16v nexia 90cp(148.000km) - 600lei cutie viteze - 300lei grila radiator - 45lei carcasa filtru aer - 45lei tub filtru aer - 15lei rezonator - 15lei raditor apa - 110lei radiator caldura - 70lei radiator ac - 110lei sonda temperatura radiator apa - 15lei alternator - 160lei electromotor- 160lei bobina aprindere - 60lei sonda benzina nivel - 20lei senzor vacum - 50lei cablu acceleratie - 15lei delcou 16v - 60lei electroventilator - 50lei ventilator auxiliar ac - 50lei ceas bord - 20lei bazin antigel - 15lei pompa frana cu servo - 70lei pompa frana - 40lei servo frana - 35lei scaune sofer modelul ro - 60lei scaun pasager fata modelul ro - 60lei inchidere centralizata originala daewoo - 100lei scuturi aparatoare - 20lei buc pompa ambreiaj - 40lei cilindru ambreiaj - 40lei bazin lichid stergatoare+motoras - 30lei caseta directie - 110lei jambe+fuzete 14 stg+dr - 60lei buc discuri+etrieri14 +placute - 200lei ansamblu stergatoare - 50lei motoras stergatoare - 50lei ventilator interior climatizare - 50lei timonerie - 40lei ceasuri bord(turometru+km+apa benziana) - 100lei coaja bord - 50lei torpedou - 25lei consola climatizare - 50lei bacneta spate berlina modelul ro - 30lei bancheta spate hackback plus nexia - 30lei lampa lumina interior - 10lei cric+cheie roti - 50lei bloc lumini - 20lei maneta stergatoare - 10lei panou sigurante - 100lei yale +contact berlina 2chei - 90lei yale +contact hackback 2chei - 80lei broasca capota - 10lei cablu deschis capota cu tot cu maner - 15lei contact electric - 20lei solenoid portbagaj - 25lei fulie pompa servo - 15lei fulie arbore - 15lei pinion - 20lei axe cu came 16v - 80lei ambele tacheti 16v - 50lei toti pompa ulei - 50lei baie ulei - 30lei bieleta directie stg+dr - 20lei buc punte spate - 90lei toba centrala - 60lei toba catalizator - 50lei sonda lambda - 40lei toba finala hackback - 30lei fuzeta 13" - 40lei guzete spate - 30lei buc jante 14"+cauciucuri vara 5xbuc - 250lei capace daewoo 14" - 70lei scrumiera spate - 10lei pistonas inchidere sofer - 30lei pistonas inchidere secundar - 25lei actuator portbagaj - 20lei lampi spate hackback (apropae noi) - 30lei consola deschidere portbagaj+rezervor - 15lei rezervor - 40lei injectori 4x - 200lei bara torsiune - 35lei bascule stg+dr - 40lei buc broaste usi - 30lei buc brate stergatoare - 25lei setu suporti portbagaj plafon - 30lei setu arcuri fata - 70lei arcuri spate - 70lei amortizoare fata - 70lei amortizoare spate - 70lei pompa benzina - 80lei mocheta spate portbagaj hachback - 20lei suport cric +cheie roata rezerva hackback - 15lei tampon motor stg+dr+centru - 20lei buc buzer - 20lei tija capota motor - 10lei cilindru frana spate - 15lei scrumiera compelta - 15lei centura stg+dr fata - 15lei buc centura stg+dr spate - 10lei buc cablu frana de mana - 25lei geamuri laterale spate berlina - 25lei buc geamuri usi stg+dr fata spate - 30lei buc geamuri usi spate mici - 25lei buc coaja spate boxe berlina - 20lei mocheta interior - 30lei fir antena lung - 15lei rama avari, stergatoare, ceata , ... - 10lei butoane: avari, temporizator stergatoare, ceata, dezaburire - 10lei buc parasolar stg+dr - 10lei tetirea scaun - 10lei burduf filtru aer - 10lei tub filtru aer - 10lei manere interior - 5lei buc mufa casetofon-cd europa - 10lei calculator airbag - 10lei tamburi spate - 30lei ambi tub alimentare rezervor - 10lei geamuri spate hackback - 10lei buc haion cu tot cu geam - 80lei geam haion - 30lei amortizaore haion - 20lei set geam oglinda dr - 15lei oglinda interior - 10lei actuator gura umplere - 20lei releu centrala inchidere cielo espero - 10lei frana de mana cu tot cu senzor - 10lei furtun etrier - 10lei buson rezervor - 10lei rezistor - 10lei calxon original - 15lei usa rezervor - 10lei suport casetofon+tavita - 15lei calculator abs - 30lei aparatoare stergatoare stg+dr - 20lei partea de clapete cu vacum pt incalzire , aer , recirculare - 25lei +alte piese preturile sunt negociabile tel:0766285062 / 0735800867 Link to comment
Englishman Posted August 7, 2011 Share Posted August 7, 2011 Un cric in stare foarte buna? neindoit/ sudat, etc. Link to comment
alex2150 Posted August 9, 2011 Author Share Posted August 9, 2011 s-au vandut capota colantat , far dr, aripa stg, semnalizare stg, bara fata Link to comment
chucki1703 Posted August 11, 2011 Share Posted August 11, 2011 Buna ziua. Pompa de benzina este buna ? functioneaza? se potriveste la un cielo din 96 motor 1500cm? ultimul pret? Link to comment
alex2150 Posted August 11, 2011 Author Share Posted August 11, 2011 s-a vandut pompa de benzina Link to comment
alex2150 Posted August 29, 2011 Author Share Posted August 29, 2011 se adauga: compresor ac - 200lei condesor ac conducte ac radiator ac - 100lei radiator apa - 100lei radiator caldura - 70lei planetara lunga 13" - 140lei planetara scurta 13" - 110lei jamba 13 completa stg+dr - 100lei etrieri 13"+placute - 100lei discuri ventilate 13"- 100lei cutie viteze 8v - 300lei motor 8v - 600lei( se da si pe bucati) calculator 8v - 80lei disc ambreiaj+placa+rulment - 120lei volanta ambreiaj - 50lei gpl cielo - 250lei delcou 8v -100lei instalatie electrica panoua sigurnate 8v - 100lei punte spate 13" completa - 120lei lampi spate stg+dr - 50lei buc semnazlizare stg - 25lei faruri stg+dr - 100lei buc bara fata cu amratura - 200lei bara spate cu armatura - 150lei usi - 100lei buc fete de usi - 30lei buc comanda geamuri electrice sofer - 70lei comanda geamuri electrice pasageri - 20lei macara geam+motoras geam electric - 80lei buc capota verde cantebury - 160lei consola climatizare - 45lei rampa injectori 8v - 200lei pompa benzina - 80lei cric - 40lei +multe alte piese Link to comment
alex2150 Posted October 9, 2011 Author Share Posted October 9, 2011 update piese disponibile : compresor ac - 170lei radiator interior ac - 70lei conducte ac radiator caldura - 70lei tacheti+culbutori 8v - 50lei pompa servo - 100lei bloc motor - 90lei arbore - 90lei planetara lunga 13" - 130lei planetara scurta 13" - 100lei jamba 13 completa stg+dr(rulment+fuzeta+aparatoare) - 90lei discuri ventilate 13"- 100lei cutie viteze - 250lei calculator 8v - 60lei oglinda stg - 50lei disc ambreiaj+placa+rulment - 90lei volanta ambreiaj - 45lei gpl cielo - 150lei volan - 30lei instalatie electrica panoua sigurnate 8v - 100lei punte spate 13" completa - 110lei lampi spate stg+dr - 40lei buc semnazlizare stg - 20lei bara fata putin crapata - 40lei bara spate cu armatura - 150lei usi 4x - 100lei buc fete de usi - 25lei buc comanda geamuri electrice pasageri - 20lei macara geam+motoras geam electric - 70lei buc consola climatizare - 45lei rampa injectori 8v - 200lei pompa benzina - 80lei armatura bara spate+fagure - 40lei luneta spate berlina - 80lei motor 16v nexia 90cp(148.000km) - 450lei grila radiator - 40lei carcasa filtru aer - 40lei tub filtru aer - 15lei rezonator - 15lei sonda temperatura radiator apa - 15lei alternator - 150lei electromotor- 150lei clapeta acceleratie 8v - 50lei capota cu chit pe ea - 50lei semnalizari aripi alungite - 20lei setu bobina aprindere - 50lei sonda benzina nivel - 20lei senzor vacum - 40lei cablu acceleratie - 15lei delcou 16v - 60lei ceas bord - 20lei bazin antigel - 15lei pompa frana cu servo - 70lei pompa frana - 40lei servo frana - 35lei senzor acceleratie - 30lei supapa comanda aer (yac) - 70lei scaun pasager fata modelul ro - 50lei inchidere centralizata originala daewoo - 100lei scuturi aparatoare - 20lei buc pompa ambreiaj - 30lei cilindru ambreiaj - 30lei bazin lichid stergatoare+motoras - 25lei caseta directie - 110lei discuri+etrieri14 +placute - 200lei ansamblu stergatoare - 50lei motoras stergatoare - 40lei ventilator interior climatizare - 40lei timonerie - 35lei ceasuri bord(turometru+km+apa benziana) - 90lei coaja bord - 40lei torpedou - 20lei bancheta spate berlina modelul ro - 25lei bancheta spate hackback plus nexia - 25lei lampa lumina interior - 10lei maneta stergatoare - 10lei panou sigurante - 100lei yale +contact berlina - 70lei broasca capota - 10lei cablu deschis capota cu tot cu maner - 15lei contact electric - 20lei solenoid portbagaj - 20lei fulie pompa servo - 15lei fulie arbore - 15lei pinion - 20lei axe cu came 16v - 50lei ambele tacheti 16v - 40lei toti pompa ulei - 50lei baie ulei - 30lei bieleta directie stg+dr - 20lei buc punte spate - 80lei sonda lambda - 35lei fuzeta 13" - 40lei fuzete spate - 30lei buc capace daewoo 14" - 70lei scrumiera spate - 10lei pistonas inchidere sofer - 30lei pistonas inchidere secundar - 25lei lampi spate hackback (apropae noi) - 20lei consola deschidere portbagaj+rezervor - 10lei rezervor - 40lei bara torsiune - 30lei bascule stg+dr - 30lei buc broaste usi - 25lei buc brate stergatoare - 20lei setu suporti portbagaj plafon - 30lei setu arcuri fata - 60lei amortizoare fata - 60lei amortizoare spate - 60lei pompa benzina - 80lei tampon motor stg+dr+centru - 20lei buc buzer - 15lei tija capota motor - 10lei cilindru frana spate - 15lei scrumiera compelta - 15lei centura stg+dr fata - 15lei buc centura stg+dr spate - 10lei buc cablu frana de mana - 25lei geamuri laterale spate berlina - 25lei buc geamuri usi stg+dr fata spate - 30lei buc geamuri usi spate mici - 25lei buc coaja spate boxe berlina - 20lei mocheta interior - 30lei fir antena lung - 15lei rama avari, stergatoare, ceata , ... - 10lei butoane: avari, temporizator stergatoare, ceata, dezaburire - 10lei buc parasolar stg+dr - 10lei tetirea scaun - 10lei burduf filtru aer - 10lei tub filtru aer - 10lei manere interior - 5lei buc mufa casetofon-cd europa - 10lei calculator airbag - 10lei tamburi spate - 30lei ambi tub alimentare rezervor - 10lei geamuri spate hackback - 10lei buc haion cu tot cu geam - 80lei geam haion - 30lei amortizaore haion - 20lei set oglinda interior - 10lei actuator gura umplere - 20lei releu centrala inchidere cielo espero - 10lei frana de mana cu tot cu senzor - 10lei furtun etrier - 10lei buson rezervor - 10lei rezistor - 10lei calxon original - 15lei usa rezervor - 10lei suport casetofon+tavita - 15lei calculator abs - 30lei aparatoare stergatoare stg+dr - 20lei partea de clapete cu vacuum pt incalzire , aer , recirculare - 25lei pompa abs nexia espero - 70lei calculator abs nexia - 25lei +alte piese preturile sunt negociabile tel:0766285062 / 0735800867 Link to comment
maresmo Posted October 9, 2011 Share Posted October 9, 2011 Salut! Rotile le mai ai? Stima! Link to comment
alex2150 Posted October 9, 2011 Author Share Posted October 9, 2011 On 10/9/2011 at 12:18 PM, maresmo said: Salut! Rotile le mai ai? Stima! sal , nu le mai am . Link to comment
Englishman Posted October 23, 2011 Share Posted October 23, 2011 Lampa semnalizare dreapta? Link to comment
IONUT 23 Posted November 12, 2011 Share Posted November 12, 2011 salut!zi-mi,te rog,avertizorul (clopotelu) pentru lumini aprinse,usi deschise,centuri,etc...il ai?da-mi si un pret Link to comment
IONUT 23 Posted November 13, 2011 Share Posted November 13, 2011 si acum o rugaminte...il potii trimite prin posta,cu plata ramburs?-id yahoo: ionik_e4 Link to comment
alex2150 Posted November 14, 2011 Author Share Posted November 14, 2011 (edited) se mai adauga o masina update lista +alte componente faruri - 80lei buc radiator apa - 100lei electroventilator - 50lei bara fata cu fagure - 20lei capota - 180lei aripi - 60lei buc parbriz - 120lei caroserie compelta partea fata motor 16v 37.000km - 500lei ramapa injectoare - 200lei alternator - 150lei electromotor - 150lei jante 14" - 50lei buc jante 13"- 40lei buc etrieri+discuri 14"+placute - 140lei compresor ac - 150lei radiator interior ac - 50lei tacheti 8v - 50lei tot culbutori 8v - 30lei toti conducte ac radiator caldura - 70lei tacheti+culbutori 8v - 50lei pompa servo - 100lei bloc motor - 80lei arbore - 80lei trapa nexia in 2xpozitii - 100lei planetara luna 14" - 120lei planetara scurta 14" - 100lei planetara lunga 13" - 120lei planetara scurta 13" - 100lei jamba 14 compelta stg+dr(rulment+fuzeta+aparatoare) - 90lei jamba 13 completa stg+dr(rulment+fuzeta+aparatoare) - 90lei discuri ventilate 13"- 100lei cutie viteze - 250lei calculator 8v - 50lei disc ambreiaj+placa+rulment - 90lei volanta ambreiaj - 35lei volan - 30lei coloana volan completa - 50lei instalatie electrica panoua sigurnate 8v - 100lei punte spate 13" completa - 110lei lampi spate stg+dr - 30lei buc semnazlizare stg - 20lei bara fata putin crapata - 40lei bara spate cu armatura - 150lei usi 4x - 100lei buc fete de usi - 25lei buc comanda geamuri electrice pasageri - 20lei macara geam+motoras geam electric - 65lei buc consola climatizare - 45lei rampa injectori 8v - 200lei armatura bara spate+fagure - 40lei luneta spate berlina - 80lei grila radiator - 40lei carcasa filtru aer - 40lei tub filtru aer - 15lei rezonator - 15lei sonda temperatura radiator apa - 15lei alternator - 150lei electromotor- 150lei clapeta acceleratie 8v - 50lei semnalizari aripi alungite - 20lei setu bobina aprindere - 50lei sonda benzina nivel - 20lei senzor vacum - 35lei cablu acceleratie - 15lei delcou 16v - 50lei ceas bord - 20lei bazin antigel - 15lei pompa frana cu servo - 70lei pompa frana - 40lei servo frana - 35lei senzor acceleratie - 30lei supapa comanda aer (yac) - 70lei scaun pasager fata modelul ro - 50lei inchidere centralizata originala daewoo - 100lei scuturi aparatoare - 20lei buc pompa ambreiaj - 30lei cilindru ambreiaj - 30lei bazin lichid stergatoare+motoras - 25lei caseta directie - 110lei ansamblu stergatoare - 50lei motoras stergatoare - 40lei ventilator interior climatizare - 40lei timonerie - 35lei ceasuri bord(turometru+km+apa benziana+carcasa) - 90lei ceasuri bord(turometru+apa benzina+carcasa)-50lei coaja bord - 40lei torpedou - 20lei bancheta spate berlina modelul ro - 25lei bancheta spate hackback plus nexia - 25lei lampa lumina interior - 10lei maneta stergatoare - 10lei panou sigurante - 100lei yale +contact berlina - 70lei broasca capota - 10lei cablu deschis capota cu tot cu maner - 15lei contact electric - 20lei solenoid portbagaj - 20lei fulie pompa servo - 15lei fulie arbore - 15lei pinion - 20lei axe cu came 16v - 50lei ambele tacheti 16v - 40lei toti pompa ulei - 40lei baie ulei - 30lei bieleta directie stg+dr - 20lei buc punte spate - 80lei fuzeta 13" - 40lei fuzete spate - 30lei buc capace daewoo 14" - 70lei scrumiera spate - 10lei pistonas inchidere sofer - 30lei pistonas inchidere secundar - 25lei lampi spate hackback dr (apropae noi) - 20lei consola deschidere portbagaj+rezervor - 10lei rezervor - 40lei bara torsiune - 30lei bascule stg+dr - 30lei buc broaste usi - 25lei buc brate stergatoare - 20lei setu suporti portbagaj plafon - 30lei setu arcuri fata - 60lei amortizoare fata - 60lei tampon motor stg+dr+centru - 20lei buc buzer - 15lei tija capota motor - 10lei cilindru frana spate - 15lei scrumiera compelta - 15lei centura stg+dr fata - 15lei buc centura stg+dr spate - 10lei buc cablu frana de mana - 25lei geamuri laterale spate berlina - 25lei buc geamuri usi stg+dr fata spate - 30lei buc geamuri usi spate mici - 25lei buc coaja spate boxe berlina - 20lei mocheta interior - 30lei fir antena lung - 15lei bara spate hackback cu armatura - 35lei rama avari, stergatoare, ceata , ... - 10lei butoane: avari, temporizator stergatoare, ceata, dezaburire - 10lei buc parasolar stg+dr - 10lei tetirea scaun - 10lei burduf filtru aer - 10lei tub filtru aer - 10lei manere interior - 5lei buc mufa casetofon-cd europa - 10lei calculator airbag - 10lei tamburi spate - 30lei ambi tub alimentare rezervor - 10lei geamuri spate hackback - 10lei buc haion cu tot cu geam - 80lei geam haion - 30lei amortizaore haion - 20lei set oglinda interior - 10lei actuator gura umplere - 20lei releu centrala inchidere cielo espero - 10lei frana de mana cu tot cu senzor - 10lei furtun etrier - 10lei buson rezervor - 10lei rezistor - 10lei calxon original - 15lei usa rezervor - 10lei suport casetofon+tavita - 15lei calculator abs - 30lei aparatoare stergatoare stg+dr - 20lei partea de clapete cu vacuum pt incalzire , aer , recirculare - 25lei pompa abs nexia espero - 70lei calculator abs nexia - 25lei preturile sunt negociabile tel:0766285062 / 0735800867 Edited November 14, 2011 by alex2150 Link to comment
big2shae Posted November 14, 2011 Share Posted November 14, 2011 Ce culoare sunt aripile faţă de cielo? Link to comment
alex2150 Posted November 14, 2011 Author Share Posted November 14, 2011 (edited) albastre Edited November 14, 2011 by alex2150 Link to comment
hhhlamax Posted November 16, 2011 Share Posted November 16, 2011 salut ma intereseaza pentru cielo etrieri cu discuri pe 13 si oglinzile. Link to comment
