iulianm Posted July 14, 2012 Share Posted July 14, 2012 Salut, Am o nubira 1 din '98 care a inceput sa piarda apa din vasul de expansiune - un litru pe zi - umblu cu apa dupa mine. Am verficat, sub masina nu se vede balta, pe la furtune e uscat, am schimbat si capacul de la vasul de expansiune gandindu-ma ca da pe acolo abur, in zadar. Apa nu se duce in baia de ulei - nivelul baii e constant. Ce as putea verifica? Link to comment
Budan Catalin Posted July 14, 2012 Share Posted July 14, 2012 Pe la pompa de apa ai verificat? Link to comment
barboso Posted July 16, 2012 Share Posted July 16, 2012 Vezi ca daca-i pompa de apa poate fi chiar grav; fiind angrenata de cureaua de distributie, daca se blocheaza poti s-o patesti urat. Link to comment
danutza Posted July 22, 2012 Share Posted July 22, 2012 (edited) Pierde si cu motorul oprit? Sau doar in mers? Cauta pe aici, daca nu gasesti solutia intrebi tot aici http://www.gmclub.ro/forum/index.php/topic/5273-probleme-la-instalatia-de-racire/page__st__320?do=findComment&comment=555474 Edited July 22, 2012 by danutza Link to comment
cris06 Posted July 22, 2012 Share Posted July 22, 2012 Verifica si interiorul: sa nu ai pierderi de la calorifer. Link to comment
DGT Posted July 22, 2012 Share Posted July 22, 2012 Garnitura de chiuloasa. Daca nu se vede apa in compartimentul motor.Nu scoate mai mult fum alb? Link to comment
jambon Posted August 16, 2012 Share Posted August 16, 2012 La consumul asta asa de mare e pompa de apa. Link to comment
