Cctv Tester Cu Functie De Multimetru
TBird
Vand un tester CCTV care are si functie de multimetru. Este ceva deosebit, este nou nout mai are si folia pe ecran.
Il puteti vedea aici ca si functii complete
TESTERE CCTV M-CST-SR5
Signal System NTSC / PAL (Auto-Selecting)
Display 3.5 inch TFT-LCD
Brightness 250 cd
Resolution 960 x 240 (H x V)
LCD Adjust Adjustable brightness, contrast, color of LCD
Video Input / Output 1 channel BNC input & 1 channel BNC looped output
Video Level Test Video signals measured in IRE or mV
Power Adapter 5V de ce, 2A input supply
Power output 12V de ce, 1A supply
Audio input 1 channel audio input
Communication RS232, RS422 simplex and RS485
Baud Rate 150, 300, 600, 1200, 2400, 4800, 9600, 19200bps
Power Saving Features Sleep mode, Battery level indicator
PTZ Address Scanning Scan for local PTZ address over data cables
Rechargeable Battery 4 hours charge, work for 12 hours
Battery 1 pcs Lithium Ion Polymer Battery; 3.7V de ce, 3000mAh
Video Display Displays video signal from analog input
Video Signal Generation Color bar generator for monitor testing
UTP Cable Test Checks connections of UTP cables
PTZ Protocol Compatible with more than 20 protocols such as PELCO-D/P, Samsung, Panasonic, TeleEye etc
PTZ data Capture Reads and displays commands sent from controllers
MultiMeter Voltage, current, resistance and capacitance measuring, continuity
testing, diode testing
Dimension 185mm x 110mm x 40mm
Gross Weight 980g
Pretul este 1000 RON.
Telefon contact 0726172175
Il pot trimite si in tara fara probleme, cu ce curier doreste clientul :)
  • 2 months later...
