Dj_Dark Posted January 26, 2019 Share Posted January 26, 2019 😄 Mi s-a mai zis ca am talentul asta. Eu nu il consider "cobe" doar vad chestii pe care altii nu le vad 😛 Sa-l consideram defect profesional 🙂 Link to comment
Viktor Posted January 27, 2019 Author Share Posted January 27, 2019 Amu, concentreaza-te nitel si zi-mi de pot obtine un aviz sa ma dau cu el montat pe ulita. Voluntariat in folosul comunitatii, desigur, daca tot ne deplasam din punctul A in B si C macar sa facem carare pe unde trecem. 😉 Facem rost si de un ni-no-ni-no . Ori mergem pe un model de ultima generatie. Link to comment
Dj_Dark Posted January 29, 2019 Share Posted January 29, 2019 Merge doar la rele talentul 😛 Link to comment
Viktor Posted February 2, 2019 Author Share Posted February 2, 2019 Inchiriez ghidusie deszapezire . Dotari : - directie > coarne tip harley davidson - caucioace extra dure all-season - lama metalica cu reglaj in 3 pozitii (stinga - dreapta) - propulsor ardere interna (zero noxe) - 2x2 individulal (si-un patruped putere) - consum minim (doua chifle si-o buca' de slana) - racire aerodinamica - timp de lucru > nelimitat - si partea frumossa > fara restrictie de videza Dotari extra : - minere cauciuc pe coarne - suport termos cafea 1 1 Link to comment
ches Posted February 8, 2019 Share Posted February 8, 2019 Pe cand un film cu masinaria in actiune? Link to comment
Viktor Posted February 8, 2019 Author Share Posted February 8, 2019 Daca ai sti cit de mult astept sa ninga iar ... Mi-s cu ochii pe astia de la meteo ca pe butelie. Macar o juma de santima acolo sa-mi fac damblaua chit ca-i in toiu noptii si nu inchid un ochi asteptind cu esapamentu' incins, da' ... tot ii fac un test macar. Trebuie sa-i dau si o mina de vopsea, asta dupa ce ma asigur ca nu necesita vreo modificare. Link to comment
Viktor Posted February 8, 2019 Author Share Posted February 8, 2019 Mecanicosu' inrait . 1 Link to comment
Viktor Posted April 20, 2019 Author Share Posted April 20, 2019 Din ciclu "de nu faci foc nu iese fum". Da' dupa cum noi facem foc, avem de furca si cu cenusa. Avind prostul obicei de a curata periodic si intregime caile fumigene (si nu doar) a incalzirii, extrasul cenusei mi-a dat mereu batai de cap, asadar i-am venut de hac ! Am pus osu la treaba si am confectionat un colector - decantor intermediar intre aspirator si coana cenusa. Dupa un prim test, ma declar super multumit de eficienta ghidusiei, 99% din impuritati ramin in decantor iar ramasita de 1% sub forma de praf usor se aseaza in colectorul aspiratorului. Da', lasam pozele sa vorbeasca ... 1 Link to comment
Viktor Posted May 17, 2019 Author Share Posted May 17, 2019 Se pare ca ma ocoleste norocul la menghine, pina in prezent am rupt 3 bucati. Iar dupa cum la mesterit fara de menghina bati pasul pe loc, mi-am pus in gind sa caut un SH si ieftin de se poate . Slabe sanse a ma lipi de vreo una, si ieftina si buna asa ca, m-am pus pe treaba si am confectionat una (din fiare vechi) zdravana de vreo 15 kile si su mult mai mare decit cea anterioara. Material : - profil "U" 80x45mm - surub 355x20 mm - material plat si brut 10 mm Si in final : lungime totala 355 mm, latime 100 mm respectiv 210mm (la baza) , cu inaltime 170 mm si deschidere totala pe 180 mm. 1 Link to comment
Dj_Dark Posted May 18, 2019 Share Posted May 18, 2019 Pai daca strangi cu teava ce sa-ti fac 😛 Sigur e mai rezistenta decat aia rupta? Ca mie nu-mi pare 😄 Link to comment
Viktor Posted May 18, 2019 Author Share Posted May 18, 2019 Ii cu mult mai mare decit cealalta si suficient de solida zic eu incit sa nu ceara teava, altfel mai primeste ceva material si intariri, o incarc de nu se vede. Avantajul e ca poate fi consolidata pecind cea din fonta, nu. Alea mari adevarate is destul de scumpe si s-ar merita pina la urma in cazul in care as sta calare pe ea cel putin la doua zile, dar asa ... cind ma apuca damblaua de-o mestereala sa-mi pot face treaba. Oricum, n-o vind, asa ca nu incercati cu care da mai mult ... 😉 1 Link to comment
Viktor Posted July 24, 2019 Author Share Posted July 24, 2019 Si-un upgrade la anti-canicula. 12V home AC. O incarcare si vreo ~5 ore baga racoare. Link to comment
mr_ Posted July 25, 2019 Share Posted July 25, 2019 daca solutia o incarci de la fridigerul care e tot in casa mare lucru nu rezolvi 🙂 Ar ajuta poate sa ai un frigider undeva afara... Link to comment
Viktor Posted July 25, 2019 Author Share Posted July 25, 2019 Aia in flacoane ii apa chioara congelata. Care ar fi avantajul daca frigiderul/congelatorul ar fi afara ? Link to comment
mr_ Posted July 25, 2019 Share Posted July 25, 2019 Frigiderul produce căldură ca să răcească sticlele 🙂 Link to comment
Dj_Dark Posted July 25, 2019 Share Posted July 25, 2019 Pai le raceste noaptea cand e mai racoare si ziua foloseste ghidusia 😛 Link to comment
Viktor Posted July 25, 2019 Author Share Posted July 25, 2019 Cele doua nu se intinlesc, is total separat. Pe canicula asta de ~ 28- 30° sau cit or fi fost ieri, inregistram 21 cu ghidusia in sarcina. Cu sau fara, ii o diferenta de ~5° fara sa exagerez. Imi place c-o tine lunga, dupa vreo 5 ore de functionare inca se inregistrau 13° in botul aerisitoarelor. Cam asa ceva, Dj'u. Avem la schimb. Hai ca-mi trag o toala c-o sa crap de frig, nu alta ... 😀 1 Link to comment
Dj_Dark Posted July 25, 2019 Share Posted July 25, 2019 Chiar ma gandeam ca nu am mai vazut o ghidusie de mult timp 😛 Link to comment
Viktor Posted July 26, 2019 Author Share Posted July 26, 2019 (edited) Mda. Mai nou ma gindeam in a confectiona o farfurie zburatoare ca ceva haluminiu s-ar gasi p-aici, da' nu-mi bat capu ca-i prea simplu. 😜 Si nici sa-i fac pe ufosi invidiosi n-as vrea. Edited July 26, 2019 by Viktor 1 Link to comment
mr_ Posted July 26, 2019 Share Posted July 26, 2019 Si pe la mine s-au batut recorduri de temperatura, ieri erau spre 40 grade... Cea mai eficienta ghidusie de "racit" s-a dovedit niste folie din aia din polistiren cu aluminiu (care se pune in spatele caloriferelor) lipita pe exteriorul geamurilor expuse la soare. Parasolar exterior improvizat. Plus noaptea cand temperatura scade sub 26 (aka spre dupa 12 noaptea) deschis totul si facut curent, iar de pe la 8 jumate cand deja s-a incalzit afara inchis tot "ermetic". Link to comment
Viktor Posted July 26, 2019 Author Share Posted July 26, 2019 La temperaturile alea ma lasam lipsit de haluminiu si-o taiam in Siberia. 🙂 Link to comment
mr_ Posted July 29, 2019 Share Posted July 29, 2019 Am reusit ca in casa sa nu sar de 29 grade... respirabil cat de cat. Noroc ca nu a tinut mult. ca altfel treptat temperaturile inauntru ar fi urcat si mai mult. Link to comment
Dj_Dark Posted July 29, 2019 Share Posted July 29, 2019 Cica vine si la noi de miercuri/joi Link to comment
Viktor Posted July 29, 2019 Author Share Posted July 29, 2019 Is multiple metode anti-canicula fara de AC performant si insuportabil in cazul multora. Metoda similara o practic de ani de zile si da randament nu doar reclama. Absoarbe caldura intr-un mod spectaculos, in special pe seara cind e ceva mai racoare afara si improspatezi interiorul. Un motor de 12V si-un adapter din 220 ai rezolvat-o pe bani marunti. Link to comment
mr_ Posted August 1, 2019 Share Posted August 1, 2019 Sagetile alea cu "cool air in" nu prea au sens cand afara sunt 40 grade iar in casa sunt sa zicem 27. Chestia aia ar trebui sa functioneze eventual doar noaptea cand temperatura de afara devine mai scazuta decat aia din casa. La mine e suficient sa deschid mai multe geamuri pe parti opuse si se ventileaza "natural". Link to comment
