Octavia Nera
raven84
Yeyyyy, am scapat de check engine si ECL. Se pare ca supapa PCV a rezolvat totul.
Am mai ramas insa cu o vibratie usoara la relanti, tare sunt curios de unde e aia.
Much later update, cu o oarecare dezamagire, schimbarea valvei PCV nu pare sa fi rezolvat mare lucru.
Am in continuare erorile P0301 si P0303 plus ECL daca las suficient de mult masina la relanti cand e rece.
Mai nou bateria s-a dus sub 10V si e oficial moarta. Csf, n-ai csf, am comandat una noua care vine sambata, marca ieftina oarecum dar cu multe review-uri bune pe emag la achizitie verificata.
Dupa ce o montez o sa mai fac o recalibrare a clapetei si sterg toate erorile. Aproape 300 lei dintr-un foc. Meh...
Expand
Pune bani deoparte de una noua ca iute trece anu'.
Cand ziceam ca viata e mai frumosa, m-a mancat sa pun VCDS-ul pe masina
Address 01: Engine (CDA) Labels: 06J-907-115-CDA.clb
Part No SW: 1Z0 907 115 F HW: 1Z0 907 115 F
Component: 1.8l R4/4V TFSI 0020
Revision: AAH03--- Serial number:
Coding: 0203000C18070160
Shop #: WSC 73430 790 00999
VCID: 387FCE6B4BA650DE6C3-806D
3 Faults Found:
001674 - ECM Power Relay Load Circuit: (J271)
P068A - 000 - De-Energized Performance Too Early - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 66.0°C
Temperature: 54.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 8.255 V
000769 - Cylinder 1
P0301 - 000 - Misfire Detected
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 10
Reset counter: 255
Mileage: 202566 km
Time Indication: 0
Date: 2063.14.31
Time: 09:49:27
Freeze Frame:
RPM: 806 /min
Load: 16.9 %
Speed: 0.0 km/h
Temperature: 34.0°C
Temperature: 18.0°C
Voltage: 14.351 V
004874 - Cylinder Disabling
P130A - 000 - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 202566 km
Time Indication: 0
Date: 2063.14.31
Time: 09:50:12
Freeze Frame:
RPM: 768 /min
Load: 19.2 %
Speed: 0.0 km/h
Temperature: 38.0°C
Temperature: 18.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
Readiness: 0000 0000
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 HW: 1K0 937 087
Component: BCM PQ35 H 020 0358
Revision: 00020000
Coding: 40180AB8D00508C040080080710091E4057900AE636D8D605C0440000000
Shop #: WSC 21198 175 91754
VCID: EED3A83339625E6EF6F-80BB
Subsystem 1 - Part No: 1Z1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 29100 22 0601
Coding: 00D7B7
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 041108 05 54 0402
Coding: 0730ED
6 Faults Found:
01503 - Bulb for 3rd Brake Light (M25)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 35
Reset counter: 179
Mileage: 202144 km
Time Indication: 0
Date: 2063.14.31
Time: 12:59:46
Freeze Frame:
Term 15 On
Voltage: 13.70 V
ON
ON
Term 50 Off
OFF
ON
00893 - Switch for Trunk Handle (E234)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 7
Reset counter: 177
Mileage: 202251 km
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 12.35 V
OFF
OFF
Term 50 Off
OFF
OFF
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 12
Reset counter: 166
Mileage: 202251 km
Time Indication: 0
Date: 2063.14.31
Time: 19:45:57
Freeze Frame:
Term 15 On
Voltage: 8.75 V
ON
ON
Term 50 Off
OFF
OFF
00153 - Windshield Wiper Motor; Driver Side (V216)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 166
Mileage: 202251 km
Time Indication: 0
Date: 2063.14.31
Time: 00:00:12
Freeze Frame:
Term 15 Off
Voltage: 9.10 V
OFF
ON
Term 50 Off
OFF
OFF
00154 - Windshield Wiper Motor; Passenger Side (V217)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 166
Mileage: 202251 km
Time Indication: 0
Date: 2063.14.31
Time: 00:00:12
Freeze Frame:
Term 15 Off
Voltage: 9.10 V
OFF
ON
Term 50 Off
OFF
OFF
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 166
Mileage: 202251 km
Time Indication: 0
Date: 2063.14.31
Time: 00:01:37
Freeze Frame:
Term 15 On
Voltage: 9.00 V
ON
ON
Term 50 Off
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q6 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD291H91
Coding: 0020790
VCID: 3D71DF7F648475F6BF5-8068
Subsystem 1 - Serial number: 6332MSME4255072A6
Subsystem 2 - Serial number: 6342MSME42763558C
Subsystem 3 - Serial number: 6351HSME190D6556C
Subsystem 4 - Serial number: 6361HSME1964071C8
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded – Intermittent
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0084
Revision: A1001003 Serial number: 7667303729
Coding: 010000
VCID: 264310135112D62ECEF-8073
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 166
Mileage: 0 km
Time Indication: 0
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 161 F HW: 1Z0 035 161 F
Component: SWING 006 0039
Revision: 0H001001 Serial number: SKZ1Z2H3532019
Coding: 090004000001
VCID: 3169F34F68DC81962BD-8064
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 166
Mileage: 202251 km
Time Indication: 0
Date: 2063.14.31
Time: 19:51:11
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 126
Mileage: 202251 km
Time Indication: 0
Date: 2063.14.31
Time: 19:45:21
Foarte multe erori pe under voltage dar e ciudat
Am sters toate erorile initiale dupa ce am schimbat bateria
Acum apar din nou desi am 12,5 V cu masina oprita si aproape 14 cu masina pornita (la borne)
Sterge-le, mergi un pic si vezi care dintre ele reapar.
Are si alte simptome? Chestia aia P130A  e legata tot de misfires. Cu VCDS-ul poti numara misfires in timp real, ar fi bine de stiut daca chiar sunt atat de multe si daca sunt pe un cilindru sau pe toti.  Ar putea fi de ex bujia/bobina de inductie de pe cilindrul 1
Edited by mr_
Cel mai frustrant e ca la 90 de grade merge impecabil, literalmente auzi la semafor toate masinile in jurul ei. Doar cand se incalzeste o ia razna... Si acum am alte erori decat acum o luna.
@mr_
La prima pornire a zilei, motorul ramane cam un minut, turat intre 1100 si 1000 de turatii, dupa care coboara spre 900. In paralel, se aud 2-3 "puf"-uri usoare din compartimentul motor, ca si cand s-ar acumula presiune si pe urma ar fi eliberata brusc (sorry, nu am alta comparatie)
Cand se intampla asta, masina incepe sa tremure si in mai putin de alte 3 minute, incepe sa clipeasca martorul check engine in bord. Asta este momentul in care cred ca se genereaza codul P0301.
Daca las in continuare motorul la relanti, in maximum 5 minute de la pornire, se va aprinde matorul ECL si masina va incepe sa mearga super nasol, cu tremurat major. Cred ca acum intervine acel 004874 - Cylinder Disabling.
In momentul asta, de obicei tai contactul si repornesc masina. Erorile dispar si motorul isi revine incetisor.
Pe tot parcursul incalzirii motorului din momentul asta si pana la 90 de grade, vor mai exista mici rateuri si tremuraturi dar cand ajunge la 90 de grade si se stabilizeaza acolo, nu mai exista nici o problema. Pot opri la semafor si am senzatia ca am motorul oprit, atat de silentioasa e.
La pornirile ulterioare din cursul zilei, daca motorul incepe sa se raceasta, mai apare acel tremurat dar nu la fel de serios ca la prima pornire si de principiu nu voi mai avea nici o eroare in bord.
Simptomele se manifesta atat pe benzina cat si pe gaz. Iar misfire apare pe cilindrul 1 mereu.
O alta observatie este ca, in perioada de incalzire, pot evita erorile daca tin motorul peste 2000 de ture. Literalmente daca incepe sa clipeasca check engine-ul si ridic motorul peste 2000 RPM, eroarea dispare.
Am inlocuit recent supapa PCV, de vreme ce cea originala data din 2008.
Bujiile au fost inlocuite in decembrie 2019 cu bujii specifice pt masini cu gaz, compatibile cu motorul CDAA (deci acum cca 5000 km)
Bobinele au fost inversate intre ele, initial 1 cu 3 si acum 3 cu 4, deci in linii mari am rulat bobinele intre ele, fara nici un rezultat.
Am analizat ideea de a schimba injectorul 1, insa asta presupune o munca titanica de demontare a intregii galerii de admisie. Insa nu cred ca este de acolo, fiindca simptomele apar si cand trece pe gaz.
Mai ramane clapeta de acceleratie de desfacut si curatat, dar din nou, datorita pozitionarii instalatiei de gaz, este foarte dificil de umblat acolo. Insa asta ar fi urmatorul pas.
Consumul este unul relativ decent dar cam greu de masurat fiindca merge pe un mix de gaz si benzina. As spune ca e undeva la 11-12 in bucuresti si scade la 8,5 in afara.
Masina trage binisor (nu am putut sa o compar cu alt 1.8 tsi inca) si nu ma pot plange aici. Dar este frustrant sa nu stiu ce are.
Depuneri de carbon?  Dacă tot ajungi la dat jos galeria de admisie poate faci și o curățare a supapelor. Metodele cu produse chimice sau hidrogen sunt cam frecție la depunerile serioase, tot curățarea mecanica e baza.
Clapeta de accelerație ar afecta cred toți cilindrii.
Eu pana acum am avut misfires doar atunci când am avut problemele de distribuție, însă erau pe toți cilindrii, nu doar pe unul. Și însoțit de alt cod de eroare deci la tine nu cred că-i asta.
Bujia de pe cil 1 arata dubios dacă o scoți acum?
Inainte sa ne aruncam, bujiile sunt schimbate? fise are? daca da, sunt schimbate? Bobina/bobine?
Motoarele astea mai moderne dau "disable" la injectorul de pe cilindru daca detecteaza multiple missfire-uri pentru a proteja catalizatorul de benzina nearsa.
Bobinele au fost inversate intre ele, initial 1 cu 3 si acum 3 cu 4, deci in linii mari am rulat bobinele intre ele, fara nici un rezultat. Modelul asta nu are fise, ci bobinele, extra lungi, se infig in capul bujiilor.
Expand
Edited by raven84
Bun, eu as verifica cablajul bobinei de pe cilindrul rerspectiv, adica tensiunea in mufa bobinei de pe cilindrul cu probleme cu contact pus, motor oprit si as face o diferenta si cu una din mufele bobinelor functionale.
Dupa as inspecta vizual firele pentru rupturi, crapaturi...etc, pinii la fel pentru urme de oxidare, daca bobina aia isi ia masa de pe prindere as verifica si asta.
Daca totul pare ok as incerca sa inversez 2 injectoare intre ele sa vad daca se muta problema.
Totodata as face un test de compresie sa vad diferente intre cilindrul la si cel alaturat.
Testul de compresie e facut, am undeva la 10-11 bari pe fiecare cilindru, am dus-o pe Nera la Skoda Metrotehnica pt asta.
Cu injectoarele e bubu, ca trebuie desfacuta mai toata admisia sa le schimbi.
Insa imi place ideea cu firele, dar cum iti explici ca e comportament doar la rece. Ma gandesc ca pot fi depozite de carbon pe supapele de admisie, care sa modifice proportia de aer in cilindru dar altfel nu am idei.
Te arunci prea departe, ia-o usor, de la ce e mai ieftin si usor de facut la ce e mai greu. Depozitele de carbon chiar daca sunt nu dau missfire si nici nu ies cu decarbonizare ci cu zeama de cheie 🙂  Si daca sunt, sunt la toti cilindrii nu doar la unul.
Imi explic prin faptul ca firele/contactele se dilata/contracta/flescaiesc la variatii de temperatura, plus ca la rece motorul are nevoie de o cantitate mai mare de benzina, drept urmare de o scanteie bine definita pentru a o aprinde.
Cand e cald e mai usor 😉
Edited by Dj_Dark
Expand
Daca vrei, poti sa mergi la Al Bundy, e tatic pe partea de mecanica si electrica la tot ce tine de grupul VAG.
Edited by pompiliu92
  On 5/27/2020 at 12:28 PM, Dj_Dark said:
Te arunci prea departe, ia-o usor, de la ce e mai ieftin si usor de facut la ce e mai greu. Depozitele de carbon chiar daca sunt nu dau si nici nu ies cu decarbonizare ci cu zeama de cheie 🙂  Si daca sunt, sunt la toti cilindrii nu doar la unul.
Expand
nop! te contrazic, la tot ce inseamna, tsi, tfsi, gdi etc.. probabilitatea este de 85% sa fie depunerile, daca restul de 15% sunt ok, ce este foarte problematic la el este ca are si gaz, asta complica instalatia, iar probabilitatea ca firele deja coapte sa aiba probleme este mare, exact cum ai spus trebuie luat din aproape in aproape dar nu trebuie neglijata problema cu depunerile, pentru ca fix la rece face figuri este plin yt  de masini cu injectie directa fix cu buba lui.
Am o camera endoscopica si daca as avea acces cumva acolo as putea vedea daca sunt depuneri sau nu.
Ma gandeam sa iau la mana cablajul de la bobine, problema e ca minunea nu prea e modulara, firele se duc pana undeva sub baterie, e mult de sapat.
merge cu camera endoscopica doar sa fie una buna, scoti senzorul de temperatura pe admisie si ai cale directa doar sa dai in jos clapetele suplimentare ca sa aiba loc camera.
Pana imi gasesc nervul si timpul sa bag camera in admisie, am reusit sa fac alta chestie pe care o voiam implementata de mult.
Cand am luat masina, aveam coming home/leaving home pe xenoanele de pe faza scurta. Nu neaparat rau, dar chiar nu ma incanta sa uzez becurile alea de 250 lei bucata in mod prematur.
Asa ca acum am pus CH/LH pe proiectoare. Se aprind cand deschid usa dupa ce am taiat contactul sau cand o descui la loc (doar noaptea desigur).
Acum, am incercat sa ii instalez si footwell lights tot din VCDS, mi-a dat coding accepted dar nu a aparut in meniul masinii, poate si pentru ca nu le-am instalat inca. Verific dupa montaj.
Tot azi am dat jos interiorul haionul ca pregatire pentru maine cand o sa ii montez camera de marsarier, am o oglinda cu camera auto si a venit si cu accesoriul asta, asa ca voi profita sa il montez. Nu pare prea complicat si cu ocazia asta voi inspecta cablajul putin fiindca imi da eroare de bec ars pe stopul 3 de frana.
