VAXXi Posted February 2, 2007 Share Posted February 2, 2007 http://www.jetway.com.tw/evisn/download/ Vezi jos daca se potriveste vreun model. Link to comment
NFS Posted February 2, 2007 Share Posted February 2, 2007 Vezi daca gasesti ceva pe aici: http://download.jetway.com.tw/tvindex2.asp Link to comment
R19/16v Posted February 2, 2007 Share Posted February 2, 2007 http://66.98.130.69/mirror0/getfile.php/V2...2201_060209.rar Link to comment
NFS Posted February 2, 2007 Share Posted February 2, 2007 Sau vezi aici, "citeva" linkuri in primul post Link to comment
hawkeye Posted February 2, 2007 Share Posted February 2, 2007 Care stie a-mi explica cum se face cu RSS-ul? Asa, un tutorial exemplificativ ar fi perfect... Pai sunt 2 lucruri care trebuie sa le ai: 1. RSS Client Reader - exista o multime (mac/linux/windows/etc) 2. RSS Server - care introduci path-ul in client si iti apar news-uri sau ce anume trimit ei prin RSS-uri. Din cate stiu eu (si nu m-am documentat mult) e continut dinamic si se actualizeaza permanent (de fapt in functie de cum il actualizeaza proprietarii). Poate fi folosit pentru stiri de orice fel sau pentru trackere de torrente (bineinteles, astea-s unele dintre cele mai folosite care imi vin in minte). Link to comment
Lucian79 Posted February 2, 2007 Share Posted February 2, 2007 (edited) http://66.98.130.69/mirror0/getfile.php/V2...2201_060209.rar Sunt ptr acest tip de tv tunner ? Aici in Iasi unde stau, n-am tv-eu dar, am tuneru asta si mor de nu-l fac sa mearga Edited February 2, 2007 by Lucian79 Link to comment
Zmeul cel rau Posted February 3, 2007 Share Posted February 3, 2007 Se dau un desktop cu un tv tuner si un laptop legate intre ele printr-o retea, partial lan, partial wireless. Cum fac sa am parte de facilitatile tv tunerului pe laptop? Controlez desktopul prin vnc, dar am incercat zilele astea sa pun un film pe desktop si vnc-ul nu il transmitea. Ramanea fereastra neagra. Idei? Link to comment
Zmeul cel rau Posted February 4, 2007 Share Posted February 4, 2007 Nu as avea nevoie. Codecurile trebuie sa fie pe desktop ca acolo se decodeaza filmul. De fapt cred ca sunt in unei solutii pentru retransmiterea in retea a imaginilor de la tuner. As fi vrut cu un program de tip vnc ca e mai simplu sa am numai unul, dar daca nu se poate asta e, voi folosi doua. A mai incercat cineva? Care e solutia optima? Link to comment
Lucian M Posted February 4, 2007 Share Posted February 4, 2007 La un Compaq pIII 866 mhz apare "NTDRL IS MISSING"- ce sa fac ca nu reinstalez os-ul? OS e winxp sp1. Link to comment
Tommy Posted February 4, 2007 Share Posted February 4, 2007 Windows XP users 1. Insert the Windows XP bootable CD into the computer. 2. When prompted to press any key to boot from the CD, press any key. 3. Once in the Windows XP setup menu press the "R" key to repair Windows. 4. Log into your Windows installation by pressing the "1" key and pressing enter. 5. You will then be prompted for your administrator password, enter that password. 6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter "E". This letter may be different on your computer. copy e:\i386\ntldr c:\ copy e:\i386\ntdetect.com c:\ 7. Once both of these files have been successfully copied, remove the CD from the computer and reboot. Link to comment
hawkeye Posted February 4, 2007 Share Posted February 4, 2007 Trebuie setat player-ul sa nu faca overlay. Nu va mai aparea fereastra neagra. Ref. la tv-tuner nu stiu ce sa zic, ideal ar fi sa redirectionezi stream-ul catre un socket si de pe laptop cu un soft sa te conectezi la socket-ul respectiv. In practica, nu am nici cea mai vaga idee cum ai putea sa faci asta. -- NTLDR is missing poate aparea din 2 cauze 1. chiar a disparut acel fisier si simpla lui copiere acolo rezolva problema (destul de improbabil) 2. MBR-ul este corect insa filesystem-ul s-a dus. Oricum, un boot de pe un cd de xp si varianta repair ar trebui sa ajute. Link to comment
Zmeul cel rau Posted February 4, 2007 Share Posted February 4, 2007 Pai cam asta stiam si eu. Acum mai am o problema. Problema numarul 2: Am cumparat pentru desktop o placa de retea Allied Telesyn AT-2501TX (de fapt are acelasi chip realtek ca mai toate stifturile de 12 RON) cu Wake on Lan. Am montat si firul intre placa de retea si conectorul wake on lan de pe placa de baza (Jetway VIA v266b) si cum apare ceva pe retea imi porneste calculatorul. Practic eu ii dau comanda sa se inchida si el se inchide dar porneste imediat dupa. Am incercat sa pun cuplez firul si pe conectorul wake on ring si la fel face. Ce sa ii fac sa nu mai porneasca asa? Nu vreau sa renunt la wake on lan. Later edit: Am rezolvat problema numarul 2: am scos cablul dintre placa de retea si placa de baza si am activat wake on APM din bios ca trezirea sa se faca prin busul PCI. Link to comment
MethodRO Posted February 4, 2007 Share Posted February 4, 2007 Zmeule dezactiveaza wake on lan din bios si nu o sa mai faca asa! Link to comment
Zmeul cel rau Posted February 4, 2007 Share Posted February 4, 2007 Merci, dar am rezolvat si, oricum, eu vroiam sa se poata trezi cand ii dau comanda din alta parte. Mai ramane acum problema cu retransmiterea imaginilor de pe tuner. Daca era radio stiam cum sa fac, dar tv habar nu am. Link to comment
hawkeye Posted February 4, 2007 Share Posted February 4, 2007 Daca gasesti o varianta te rog s-o faci publica Link to comment
Zmeul cel rau Posted February 4, 2007 Share Posted February 4, 2007 Eu m-am gandit la o transmisie live in reteaua interna, un fel de televiziune on-line in care imaginile de intrare sa fie cele de la tuner. Puteam sa fac cu shoutcast o transmisie live a semnalului audio, dar video nu stiu cu ce as face-o. Link to comment
hawkeye Posted February 4, 2007 Share Posted February 4, 2007 Eu am fibra de 10mbps si m-ar bate gandul sa nu mai platesc la astral abonamentul pentru cablu. Sa fac undeva un fel de server de streaming cu posibilitatea de a schimba canalele. Link to comment
Zmeul cel rau Posted February 4, 2007 Share Posted February 4, 2007 Am gasit asta: http://www.techenclave.com/forums/guide-to...n-lan-2608.html dar mi se reseteaza calculatorul care functioneaza ca server cand incerc sa il fac sa "emita". Link to comment
NFS Posted February 5, 2007 Share Posted February 5, 2007 Are cineva un Detonator de la NVIDIA (cit mai recent posibil), pt o placa RIVA TNT2 M64 ? Pe site la nvidia.com, dupa ce selectez modelul, mi se incarca doar o pagina goala!!! Link to comment
laurentziu83 Posted February 6, 2007 Share Posted February 6, 2007 Are cineva o sugestie pentru un dvd writer bun? Care sa tina mai mult de 6 luni si 30-40 de discuri? Sa nu fie LG GSA-4167B? Si nici Plextor, ca de ala n-am bani. Al meu a inceput de curand sa scrie aiurea dvd-uri, azi i-am facut update de firmware de la DL11 la DL13 si face si mai rau, adica nici sa citeasca se pare ca nu mai stie. L-as da la garantie, dar e luat din metro iar garantia lui e pe la Oradea, si n-am chef pentru 120 de lei cat am dat pe el sa-l fac pachet, sa-l trimit, iar aia de acolo sa mi-l trimita inapoi sa-mi zica cum ca ar fi bun dar de fapt sa nu se uite la el, eu sa ma duc la OPC, etc, etc, etc... Link to comment
dreaQ Posted February 6, 2007 Share Posted February 6, 2007 Eu am un benQ si merge de vreo 2 ani. Nu am tras foarte multe maxim 150 de discuri (cd +DVD). Nu mi-a dat erori la scriere si nici la citire. Probabil ca aceeasi chineji fac componentele pentru toate. Link to comment
alx Posted February 6, 2007 Share Posted February 6, 2007 LG sau ASUS. Ambele se bulesc, dupa cum iti este norocul. Link to comment
