Despre calculatoare
VIPER
Au dat o duda la Windows update, e clar. Eu am de 2 zile un update in system tray (apare iconul ala), cica "downloading updates", si procesul sta la 99% ocupare procesor. Il omor, ramane agatat, la reboot revine.
Se pare ca n-are treaba cu licenta.
http://www.theregister.co.uk/2007/05/11/ms_update_glitch/
The latest batch of patches from Microsoft has left some users in the slow lane.
After applying the seven critical updates released by Redmond, some punters are finding their processor's resources eaten by an application called svchost.exe, in a way that mimics a viral infection. Svchost.exe is a generic name for services that run from dynamic-link libraries (DLLs). Outlook 2003 users have been hardest hit, with some linking the application's slow-down to the effects of a cumulative update to Internet Explorer. However, the effect is far from limited to Outlook 2003 users.
The issue has cropped up on the WSUS (Windows Server Update Services) blog and among reports to the SANS Institute's Internet Storm Centre (ISC). The precise cause of the problem remains unclear. Microsoft is yet to respond to our requests to shed some light on the problem.
Some users are experiencing relief by applying a hot fix issued to address problems involving non-response of svchost.exe (not exactly the symptom most are reporting) prior to upgrading their Windows Update client, ISC reports. Your mileage may vary. ®
Si cica rezolvarea:
Again, not new: I've had progressively more customers running fowl of this since November when it first cropped up. The number of problems caused has exploded this week, though.
Come on, Microsoft - this isn't exactly getting people to tun on automatic updates.
This is the best workaround I've found: Has fixed the issue for everyone so far...
1) Manually save then install Windows Update V7: http://download.windowsupdate.com/v7/windo...Agent30-x86.exe
2) Install Hotfix referenced in KB927891
3) Open Microsoft Update, click change settings, and switch back to Windows update
4) Until this issue has been confirmed resolved, do not upgrade PC's to Microsoft Update. If necessary, go back to using Windows Update and Office Update seperatly.
A theory on why Microsoft is keeping this quiet: Some people think it's caused by "Genuine Advantage" checks.
Salut! Am si eu o problema. Uneori mi se blocheaza(ingheata) calculatorul. Banuiesc ca ar fi din cauza unui dispozitiv wireless prin care ma conectez la internet. Wireless-ul se alimenteaza prin USB. In zilele cand dezactivez conexiunea wireless nu se blocheaza niciodata calculatorul. In rest face ce vrea el. Ma poate ajuta cineva cu un sfat? ce ar trebui sa fac sau sa schimb-in afara de dispozitivul wireless? Multumesc.
Eu am intalnit probleme cu niste adaptoare usb wi-fi de la D-Link. Problemele (ecrane albastre) le genera aplicatia proprie a adaptorului. Am dezinstalat aplicatia, am instalat numai driver-ul si am lasat astfel windows-ul sa faca management la conexiune. Asta a rezolvat de fiecare data problema cu aceste adaptoare. Deci daca as fi in locul tau as dezinstala aplicatia lui si as pune numai driver-ul. Pana acum nu am intalnit nici un astfel de adaptor care sa se fi stricat din cauze naturale (nu se pun cele indoite) dar nici nu am prea lucrat cu asa ceva.
Se da un sistem cu MB Intel + procesor Intel 3 GHz, HDD-uri pe SATA, un DVD + 1 HDD pe Ide.
La inceput toate ok (sistemul are cam 2 ani), update de bios la zi, a mers bine pana acum o luna.
De atunci SO Win XP "vede" 8 IDE-uri fiecare din ele o data pe UDMA si o data pe PIO4, se misca execrabil.
Singura solutie ar fi reinstalare de SO, mare consumatoare de timp.
A mai intalnit cineva situatia asta?
Multumesc.
@bogdan_o Din cate tin minte am instalat doar driverul, oricum am sa verific. Cat despre probleme, acestea nu constau in "ecran albastru" ci pur si simplu calculatorul nu mai accepta nici o comanda.Cursorul nu poate fi miscat, nici combinatia ctrl+alt+delet nu face nimic. Singurul lucru ce functioneaza e butonul de reset al caculatorului. Multumesc oricum de informatii :) .
Tocmai m-a "lasat" imprimanta mea d-acasa, un deskjet HP3320, ajunsa la venerabila varsta de vreo 5 ani! Super bine pt o imprimanta din clasa ei, luata la oferta din Metro (doua la pret de una!).
Boon, acu tre sa iau alta. Recomandati-mi si mie ceva care sa respecte urmatoarele:
- color, A4
- regim de lucru destul de lejer.
- fiabilitate, sa ma tina macar tot cit asta dinainte la regimul de lucru de mai sus.
- cit mai mica posibil, sa nu-mi ocupe juma de birou.
- sa nu faca figuri cu cartuse/tonere re-umplute.
- cartuse cit mai mari, sa nu le reumplu zilnic!
Repet, e pt acasa, nu conteaza prea tare nr de pag/min sau alte performante d-astea. Prefer sa fie rezistenta.
De asemenea, banuiesc ca nu merita sa iau laser, mai bine raman la jet de cerneala dpdv al pretului consumabilelor, nu?
Edited by NFS
Ca si modele de imprimante nu pot sa iti dau un sfat dar as vrea sa iti spun urmatoarele: Din punct de vedere al consumabilelor, ar fi bine sa te interesezi in mai multe locuri la ce pret se reincarca cartusele, atat pentru inkjet cat si pentru laser. In alta ordine de idei, nu cred ca ai sa gasesti o imprimanta laser color de dimensiunile uneia inkjet-din pacate si nici la pretul acesteia. Cat depsre fiabilitate, parerea mea este sa mergi in continuare pe HP, sau daca nu vrei asta, sa apelezi la Canon. Cred ca ar trebui sa stii, ca pentru cartusele cu cerneala fie color fie numai neagra, se recomanda cam max. 3-4 reincarcari. Din experienta mea, pot sa iti spun ca am incarcat cu cerneala (ce-i drept neagra) si de 10 ori cartusul si abia atunci a inceput sa faca figuri. Cred ca nu mai trebuie sa iti spun ca unul din dezavantajele imprimantelor cu cerneala este acela ca neutilizarea mai indelungata duce la uscatul cernelei, fapt ce poate determina schimbatul cartusului. Sper ca ti-am fost de ajutor cu aceste informatii, iar daca le stiai imi cer scuze :redface: Iti doresc bafta si sa faci cea mai buna alegere.  <img src= ">
L.E. Din punctul de vedere al imprimanelor alb-negru eu am mers pe varianta cu laser si nu am nici un regret. Incarcarea ma costa cca. 45 ron la un numar de 4000-5000 pagini listate.
Edited by BH ZNS
- color, A4
HP 6940, are niste cartuse imense(cel negru are 21 ml) , refilul merge de multe ori
Pret cca. 400 ron
Edited by uskt2005
Eu as merge pe Canon. Chiar daca poate HP sunt un pic mai bune ca si calitate a tiparirii pentru acasa mi se par ideale cele de la Canon. Se incarca extrem de usor (partea cu duze e separata de rezervorul de cerneala) si sunt cel putin la fel de fiabile. In plus la Canon majoritatea imprimantelor au incarcare superioara pentru hartie (nu au tava orizontala ca la HP), deci spatiul pe care il ocupa pe birou e destul de mic. Partea proasta la Canon e ca rezervoarele de cerneala au capacitati destul de mici si trebuie incarcate mai des ca la HP.
Eu am un HP 845C la care am renuntat (dupa ani buni de folosire) din cauza crtuselor aberant de scumpe si a reincarcarilor dificile. Acum am un LaserJet 1018. Nu am nevoie de imprimanta color acasa ca in proportie de 98% trag doar text iar daca am nevoie de ceva color tiparesc la serviciu unde am o gramada de imprimante color.
Si partea cu duze, daca se usuca si se infunda... nu e mai greu de schimbat/curatat/desfundat? :rolleyes:
La urma urmei, de ce m-ar interesa cit de usor se incarca? Ca doar nu le incarc eu! Si o sa coste cu 2-3 lei mai mult, nu-i mare chestie...
M-am uitat pe net si HP6940 chiar imi face cu ochiul.
Eu am incercat mai pe toate din gama low-end. Acum am un lexmark x1190 (multifunctionala). Merge binisor, chiar daca cartusul tine numai vreo 2-300pag text intre reincarcari (facute in casa). Pana acum eu cel mai bine m-am impacat cu lexmark, cu softul lor si cu modul de folosire.
Edited by andreib
Io chiar vreau sa-mi iau un hp5610 multifunctional cu fax. E 400 ron. Eu personal nu as cumpara alta imprimanta in afara de hp.
Edited by alx
Nu prea am incredere in 7in1 din astea la modul general. Nici cefea 3 in 1 nu prea beau :twisted: Depinde cat de mult vrei din fiecare. Daca ai de printat mai mult am vazut ce stiu multifunctionalele sa faca câr câr câr...daca dai 5-10 pagini pe zi e OK eventual mai ai si scaner. In plus am vazut ca la unele astfel de multifunctionale capacitatea cartuselor e destul de mica - poate zic asa ca la mine spre exemplu Black-ul are 10ml. Cumperi o imprimanta in functie de cat ai de printat. Si ce ai de printat... :rolleyes:
Pai nu conteaza doar cat costa reincarcarea, ca la o adica vorba ta, cativa lei in plus nu cred ca ar face diferenta. Conteaza faptul ca un cartus de HP e foarte greu de incarcat si eu pana acum nu am reusit sa incarc nici unul fara sa ma murdaresc de cerneala (care apropo, se duce abia dupa vreo 2-3 zile oricat ai freca). Firme de incarcat cartuse nu cunosc prin apropierea casei si asta a fost motivul pentru care am preferat sa fac treaba asta singur. Nu se jusifica timpul pierdut pe drum pana la firma respectiva plus ca te mai trezesti la un moment dat ca ai nevoie urgenta sa tragi ceva si te lasa cartusul cand ti-e lumea mai draga. In plus un cartus de HP nu il poti incarca de prea multe ori (cel negru), iar cel color oricat de specialisti ar fi cei de la firma de reincarcari imprima niste culori de o calitate jenant de slaba. Mai mult, din punctul meu de vedere decat sa dau banii pe 2 cartuse noi mai bine iau alta imprimanta.
Prietena mea are o Canon si sunt absolut entuziasmat de cat de bine poate sa mearga imprimanta aia. Imprimanta are cateva zeci de mii de pagini trase si nu a avut absolut nici cea mai mica problema. I-a schimbat o data rezervorul pentru tusul negru si atat. In rest numai cerneala (tuburi) si hartie. Mai erau voci care ziceau ca imprimantele Canon au nu-stiu-ce cip si dupa un anumit numar de pagini se strica dar nu e adevarat, sunt doar inventii.
Una peste alta daca ar mai trebui vreodata sa-mi iau imprimanta inkjet as alege fara sa ma gandesc Canon.
Am fiberlink de la RDS. Este pe o conexiune PPPOE IPul "assigned by DHCP". Intrebarea e: exista vreun utilitar sau pot face vreun batch care sa faca ceva de genul..."ipconfig /release" si apoi "ipconfig /renew". Adica sa-mi aloce un alt IP fara sa mai dau restart. Un fel de renew ip automat. Sper ca m-am facut inteles, astept propuneri. :rolleyes:
De fapt era mai simplu decat credeam. Un simplu disconnect urmat de un connect aduce un nou IP. Ca release/renew se refera defapt la IPul retelei care e fix. Conteaza conexiunea broadband e cea care aloca IPul de iesire. Sau ceva de genul asta. Era simplu. Nu am stiut merci.
