NFS Posted May 6, 2011 Share Posted May 6, 2011 (edited) Wolfman: Da, la fel face si in BIOS, am incercat sa schimb parola de admin si daca apas "1", imi baga 2 stelute. Mihai72ro: am terminat adineauri de scanat cu GMER si cu RADIX, cica e curat curatel. KAV zice ca nu-s nici virusi. Eu unul trag concluzia ca-i defect hard. Si se rezolva la service, cu inlocuirea tastaturii. Curios e ca totusi pana acum a functionat fara probleme (aproape 3 saptamani). Edited May 6, 2011 by NFS Link to comment
john Posted May 6, 2011 Share Posted May 6, 2011 On 4/17/2011 at 7:12 PM, Leutzu said: SSD-urile merita strict datorita timpului mic de raspuns ... se pare ca sunt consumabile deocamdata (impreuna cu datele de pe ele) http://www.codinghorror.com/blog/2011/05/the-hot-crazy-solid-state-drive-scale.html Link to comment
Wolfman Posted May 6, 2011 Share Posted May 6, 2011 (edited) @NFS: Daca face la fel in BIOS e clar defect hardware, mai ales ca se manifesta pt. taste alaturate. Edited May 6, 2011 by Wolfman Link to comment
mihai72ro Posted May 6, 2011 Share Posted May 6, 2011 (edited) In acest caz subscriu si eu! L.E. Inca de cand au aparut, le-am avut la vanzare si au inceput sa se intoarca la garantie nu am avut o impresie prea buna despre acest model. Edited May 6, 2011 by mihai72ro Link to comment
Englishman Posted May 23, 2011 Share Posted May 23, 2011 O poza pentru un prieten de aici care mi-a solicitat o lamurire : 1 Link to comment
Wolfman Posted May 24, 2011 Share Posted May 24, 2011 (edited) Si ce lamurire vrea? Daca e vorba de tracking IP, uite: Edited May 24, 2011 by Wolfman 1 Link to comment
Englishman Posted May 24, 2011 Share Posted May 24, 2011 Se completeaza PERFECT cu postul meu anterior. Era vorba de identificarea autorului unor mailuri. Acum, cu postul tau, e complet. "> Link to comment
Salex Posted June 17, 2011 Share Posted June 17, 2011 Am dat si eu de o belea cu al meu router wireless Siemens Gigaset SE361. De cind l-am luat, l-am configurat la inceput si a mers brici. Pina astazi ! Ce face: - functioneaza DHCP-ul - functioneaza wireless-ul, semnal foarte bun. - netul merge foarte OK si pe cablat si pe wireless - raspunde f. bine la ping, ruteaza bine - merge bine si pe PPPOE, l-am resetat de citeva ori din buton dar si prin scoaterea alimentarii si isi reface rapid conexiunea. - aparent accepta Log Off insa, intrind de pe un alt IP, raporteaza ca exista deja un admin logat Aparent totul merge OK dar ... Ce nu face: - nu imi permite intrarea in consola de administrare mai precis imi permite insa ... nu imi afiseaza complet meniurile . Pe alocuri arunca niste text-fielduri si niste radio-button-uri insa e imposibil de gestionat. Fara interfata de administrare nu prea stiu cum sa-i fac un update. Doua capturi de ecran pentru a vedea cum se manifesta: Are cineva vreo idee salvatoare ? Multumesc anticipat. Link to comment
Wolfman Posted June 17, 2011 Share Posted June 17, 2011 Daca-i faci "factory reset" nu cred ca e asa destept sa-si refaca singur setarile (PPOE, etc). Ai tinut mai multe secunde apasat butonul ingropat din spatele lui pana se restarteaza? Link to comment
ZDN Posted June 17, 2011 Share Posted June 17, 2011 Ai incercat din windows,sa Ii dai restore sau upgrade firmware? Poate merge asa,dupa cum arata,are probleme ori cu memoria interna,ori OS-u is broken Link to comment
hitman Posted June 17, 2011 Share Posted June 17, 2011 On 6/17/2011 at 1:40 PM, Salex said: Am dat si eu de o belea cu al meu router wireless Siemens Gigaset SE361. Incearca asta de pe net: I managed to get it work again , woopy ... all I had to do is : 1- reset the router ... keep pushing the reset bottom for around 20 sec , the power LED fades then it will start flashing again . 2- while it is still flashes ... open the web browser and enter the router's ip to access the config page . 3- you will find that no config page will be opened , instead it will open the software re installation page and ask you to choose the software directory to be installed into the router 4- download the software from : http://gigaset.com/shc/0,1935,hq_en_...131820,00.html 5- install and wait ... __________________ Link to comment
mihai72ro Posted June 20, 2011 Share Posted June 20, 2011 Intamplator, m-am "jucat" cu putin timp in urma cu un asemenea router; am reusit reset-ul, de doua ori chiar, dar l-am lasat in stadiul in care l-am gasit; se deconecta/reconecta singur aleatoriu. De regula reset-ul se face hardware, nu software, iar daca isi reface singur conexiunea inseamna ca nu ai reusit reset-ul. Butonul de reset trebuie sa il tii apasat pentru mai mult timp, mai exact cand se inchide complet frontpanel-ul si reporneste. Atentie, toate porturile deconectate fizic, inclusiv WAN-ul. Dar sincer, cred ca este inceputul sfarsitului; un update de firmware ar merita incercat. Personal am schimbat pe garantie destule. Nu recomand! Link to comment
Salex Posted June 22, 2011 Share Posted June 22, 2011 Si rezolvarea: - in ultimele zile (e un fel de-a spune pentru ca, de fapt, problemele au inceput in jurul lui 1 Iunie agravindu-se treptat) peste problema routerului s-au suprapus o serie de probleme cauzate de echipamentele RDS. Dupa 5 tichete deschise, in cele din urma au acceptat ideea ca switch-ul din scara blocului dadea rateuri (asta daca pierderi de pachete de 85%-100% si imposibilitatea de conectare pe PPPoE mai des decit 1 din 10 incercari se pot numi rateuri !). De prisos sa mentionez cit mi-a luat sa-i conving pe cei de la Serv. Tehnic ca problema nu este de la mine insa, in cele din urma, au inlocuit ce era de inlocuit si acum am revenit online. Din motivul descris, am renuntat la router si l-am scos din priza. Acum 5 minute l-am bagat la loc si ... surpriza !!! Merge ca in prima zi, meniurile au revenit la normal, functioneaza fara probleme. Din pacate nu am de ce sa-i fac update intrucit versiunea pe care o am este cea mai recenta din toate cele pe care le-am gasit pe net. Momentan ramine asa insa il voi inlocui cu o jucarie recomandata de colegul nostru mihai72ro (multumiri si pe aceasta cale). Link to comment
mihai72ro Posted June 22, 2011 Share Posted June 22, 2011 Cu place, oricand, Salex! La fel si pentru toti ceilalti membri. Ma bucur cand pot sa ajut pe cineva. In alta ordine de idei: daca merge, lasa-l asa; si update-ul de firmware ca si update-ul de BIOS se rescrie, chiar daca vorbim de aceeasi versiune. Nu toate prom-urile sunt la fel; unele o mai ia si razna. Iar la prima nemultumire pe viitor, schimba brand-ul. Link to comment
Raresh20 Posted July 1, 2011 Share Posted July 1, 2011 Am 2 cabluri prelungitoare de usb din care unul functioneaza bine, iar la celalalt apare mesajul "Usb device not recognized". Ma poate ajuta cineva cu o rezolvare sau o idee? Sau e bun de aruncat cablul ? Am Xp, daca are vreo importanta. Link to comment
mihai72ro Posted July 2, 2011 Share Posted July 2, 2011 (edited) Daca ai verificat in prealabil acelas dispozitiv (presupun stick de memorie) cu fiecare cablu in parte si pe unul iti functioneaza iar pe celalat nu, dar pe interfete (mufe de conectare) de comunicare diferite problema nu este din cablu; problema este de natura soft. Pe portul respectiv (cel care nu iti merge), de regula se datoreaza sistemului de operare si/sau driverilor USB; la fel de bine se poate intampla ca problema se poate sa fie si din dispozitiv respectiv. Nu cred ca este cazul aici. Mai putin conteaza daca ai Windows XP (la Windows Vista problemele sunt si mai grave). Prin urmare: conecteaza fiecare dispozitiv (stick) pe fiecare mufa USB in parte fara cablu, asta ca sa te asiguri ca sunt functionale; apoi, fiecare cablu in parte pe fiecare mufa USB, prin eliminare. L.E. Nu cred ca problema se datoreaza cablului prelungitor. Asteptam amanunte! Edited July 2, 2011 by mihai72ro Link to comment
Zmeul cel rau Posted July 2, 2011 Share Posted July 2, 2011 Posibil: cadere mare de tensiune pe cablu si dispozitiv cu consuma mare vs 5V aproximativi pe mufa USB. Link to comment
Raresh20 Posted July 2, 2011 Share Posted July 2, 2011 Nu e de la porturile usb pt ca am incercat pe desktop si pe laptop. In orice port bag cablul cu stickul de memorie in capat apare mesajul cu device not recognised. Cablul nu e vechi, e cumparat recent. In acelasi port usb cu acelasi memory stick, unul merge, celalalt nu.La laptop la fel. Ma gandesc ca de era de la drivere nu mergea nici celalalt cablu. Intradevar sunt marci/firme diferite, amandoua de 3 m. @ zmeu :se poate cu un cablu sa mearga acelasi stick pe acelasi port usb si cu unul sa nu mearga din cauza tensiunii? LE:Am pus usb de la mouse in cablu si mouse-ul functioneaza.Stickul usb tot nu vrea. La modemul usb se aprinde beculetu rosu, dar tot nu merge. Link to comment
Viktor Posted July 2, 2011 Share Posted July 2, 2011 (edited) De ceva timp am trecut de la net prin cablu la net mobil (stick). Am incercat sa-l conectez la un alt calculator si nu merge. Adica, toate bune si frumoase pina in momentul conectarii la net, unde nu vrea sub nici o forma. Despre ce poate fi vorba? Ce impiedica conectarea la net? Edited July 2, 2011 by Viktor Link to comment
Zmeul cel rau Posted July 3, 2011 Share Posted July 3, 2011 @raresh20: 3 metri e o lungime destul de lunga. Foloseste unul mai scurt! Daca sunt porturi controlate/alimentate de electronica diferita, tot ce e posibil... La limita, caderea de tenisune poate influenta decisiv functionarea. Link to comment
Viktor Posted August 26, 2011 Share Posted August 26, 2011 Minunea asta de Mozilla Firefox cam face fente in ultimul timp, ce versiune sa aleg? Multam. Link to comment
Viktor Posted August 27, 2011 Share Posted August 27, 2011 Ajutor, problema maaare! Cineva mi-a cerut ajutorul, in legatura cu USB Webcam. Eu fiind mai nepriceput, apelez la voi. Problema e urmatoarea: camera am instalat-o personal cu citiva ani in urma, functioneaza nu-i problema. Problema e microfonul, cel putin asa a crezut si a cumparat altul. Surpriza e ca tot nu merge, setarile sint ok (cel putin asa zice), semnal de microfon are, dar tot nu vrea.Unde-i baiul? Link to comment
