ZDN Posted April 5, 2011 Share Posted April 5, 2011 Lexmarkul=000 x3330,o prostie,am avut una,agata hartia,foarte multe probleme de soft. Canon buna,are 12 ani vechime si inca merge,desigur face precum un tractor HP buna,dar consumabile scumpe,o am multifuncțională,recunoaste imediat produse apple,e silentioasa,foarte buna in raport calitate-pret. Brother ,foarte buna,are si wireless, scoate 7~10 tocuri pe luna. Daca vrei ceva mai bun ia Brother,sau ceva mai ieftin,ia HP.Restu nu prea se merita,parerea mea Link to comment
raven84 Posted April 5, 2011 Share Posted April 5, 2011 Eu merg pe canon, din punctul meu de vedere reprezinta balanta ideala intre cost si calitate. Pana acum am avut 3 sau 4 imprimante de la Canon si nici una nu m-a lasat balta. Link to comment
Englishman Posted April 5, 2011 Share Posted April 5, 2011 On 4/5/2011 at 11:59 AM, VAXXi said: Ia incearca tu sa schimbi default browser si sa vezi daca-ti mai face. Default browser-ul de mail era IE. Schimbat pe Firefox. TOT face. Link to comment
VAXXi Posted April 5, 2011 Share Posted April 5, 2011 1. Open Explorer 2. Select Tools and then Folder Options 3. Select the File Types tab 4. Select Extension: (NONE), File Type: HyperText Transfer Protocol 5. Click Advanced toward the bottom of the window 6. In the Edit File Type window, select open and click Edit 7. Clear the DDE message box (which should contain “%1″) 8. Click OK, Click OK 9. Repeat for File Type: HyperText Transfer Protocol with Privacy Link to comment
Englishman Posted April 5, 2011 Share Posted April 5, 2011 (edited) Ori nu vad unde e Folder Option din Tools, ori...nu vad, si m-am chiorat acolo juma` de ora. Edited April 5, 2011 by Englishman Link to comment
VAXXi Posted April 5, 2011 Share Posted April 5, 2011 Windows Explorer, nu Internet Explorer. Link to comment
Englishman Posted April 5, 2011 Share Posted April 5, 2011 Dobitoc mai sunt. ) Intr-un cuvant, MERGE ! Multam` mult. Link to comment
NFS Posted April 11, 2011 Share Posted April 11, 2011 Unele modele de Sony Vaio vin acum cu SSD. Am cam pus ochii pe unul, dar ma deranjeaza SSD-ul care e cam mic in opinia mea. Are doar 64GB. In ideea ca oricum SSD-urile isi vor mari capacitatea si se vor mai ieftini, ma gandeam ca as putea sa-i fac un upgrade la un moment dat. Mi-e insa frica de astia de la SONY sa nu cumva sa fi facut vreo "duda" si hardul sa nu poata fi schimbat, sau sa fie doar un chip lipit pe placa de baza. Parca n-as vrea sa risc. Stie careva ceva? S"> Link to comment
Tommy Posted April 11, 2011 Share Posted April 11, 2011 Fita maxima e cu doua ssd-uri in raid 0 si restul pe storage extern Nu stiu daca merge insa pe laptopuri, sau pe care din ele, eu unul nu am nevoie de asa multa viteza pe un laptop. Link to comment
NFS Posted April 11, 2011 Share Posted April 11, 2011 Bine, bine, da' io intrebam altceva. Link to comment
Tommy Posted April 11, 2011 Share Posted April 11, 2011 Pai nu prea are cum sa fie ceva lipit pe placa, eu zic sa-i intrebi daca poti pune 2 ssd-uri, macar stii o treaba. Link to comment
Wolfman Posted April 11, 2011 Share Posted April 11, 2011 (edited) SSD-urile se conecteaza pe SATA, deci se va putea face upgrade. Insa cei de la Tom's Hardware au testat pe un Dell Inspiron 630 si concluzia a fost ca SSD-urile nu cresc autonomia unui laptop deoarece au doar doua stari de functionare, activ si inactiv. Citirea unui singur bit de memorie activeaza consumul maxim al SSD-urilor, momentele de inactivitate fiind aproape inexistente, autonomia putand scadea chiar si cu o ora. Edited April 11, 2011 by Wolfman Link to comment
NFS Posted April 11, 2011 Share Posted April 11, 2011 In mod particular, asta are SSD-uri PATA, nu SATA. Dupa ce ca-s mai lente, nici n-am vazut pe undeva de vanzare. )"> Chiar daca SSD-urile n-or micsora consumul, au totusi cateva alte avantaje. Link to comment
madkat Posted April 11, 2011 Share Posted April 11, 2011 Zgomot. Si viteza "de reactie" ceva mai buna. Am experimentat pe acelas lpt si cu hdd si cu ssd, si diferentele nu sunt deloc mari in cazul unei utilizari normale. Prefer oricand un HDD normal de capacitate mai mare in aceiasi bani - sau chiar de 7200rpm. Iar despre lpt Sony, nu pot decat sa iti zic sa te mai gandesti... Link to comment
NFS Posted April 11, 2011 Share Posted April 11, 2011 Deci, in concluzie, inteleg ca nu trebuie sa ma tem ca nu pot face upgrade la hdd. Link to comment
Wolfman Posted April 11, 2011 Share Posted April 11, 2011 Upgrade se poate face, insa laptopul ar trebui sa aiba si SATA, nu cred ca se vor mai gasi SSD pe PATA in cativa ani. Link to comment
mr_ Posted April 11, 2011 Share Posted April 11, 2011 discurile hibride SSD + 7200rpm le-a incercat cineva? Sunt sensibil peste cele clasice la performante? Link to comment
madkat Posted April 13, 2011 Share Posted April 13, 2011 Intrebare posibil stupida. Cu ce soft se poate mixa sunet captat de microfon peste mp3-uri? Nu inregistra, doar sa poti sa faci un fel de karaoke. Preferabil suprapune peste mp3 redat de winamp (playlist etc etc) Merge direct bagand un microfon si atat? si activand din setarile de sunet din windows cursorul de volum microfon? Link to comment
Zmeul cel rau Posted April 13, 2011 Share Posted April 13, 2011 Da, cu posiblitatea aparitiei microfoniei. Link to comment
madkat Posted April 13, 2011 Share Posted April 13, 2011 Lasa asta - ca doar microfonul va fi langa calculator - boxele vor fi la distanta suficienta incat sa nu fie probleme Link to comment
ZDN Posted April 13, 2011 Share Posted April 13, 2011 (edited) Poti incerca 'vocoder', si poti edita vocal,piesa,poti face orice. Folosesc ssd de ceva timp. Ssd are un timp de raspund foarte bun,fata de un hdd normal,e foarte silentios,eu tin pe el os,si toate programele folosite,si jocurile,pentru storage nu se merita,nu se poate da format la ssd,exista riscu sa se strice ssd-u SSD nu are viteza de 7200 rpm,nu are platane & co,se masoara in mb/s,si iti recomand sa astepti pana apar ssd sata3,la ssd diferenta intra sata 2 si sata 3 e sesizabila,fata de hdd normal. Edited April 13, 2011 by ZDN Link to comment
Leutzu Posted April 17, 2011 Share Posted April 17, 2011 SSD-urile merita strict datorita timpului mic de raspuns care este de 0.x milisecunde fata de cele 10-12 ale unui hdd normal de 7200rpm. Totusi acest timp de raspuns mic se simte doar la incarcarea SO-ului si la pornirea aplicatiilor cand se lucreaza cu fisiere mici. Daca se lucreaza cu fisiere mari avantajel ssd-urilor deja dispar. Ca dezavantaje se numara "imbatranirea" lor in timp, care se traduce prin scaderea performantelor la citire/scriere la inceput...spre deosebire de hdd care are aceleasi performante pana crapa. Aceasta imbatranire e mai putin prezenta la ssd-urile care au implementata tehnologia trimm. Am cochetat si eu cu ideia achzitionarii unui ssd insa pentru 20 de secunde cu cat se incarca mai repede win-ul si cateva secunde la incarcarea aplicatiilor uzuale nu am gasit convenabil pretul destul de mare de achizitie al unui ssd de minim 60gb -capacitate pe care o gasesc acceptabila pebtru partitia so-ului.. Link to comment
NFS Posted May 6, 2011 Share Posted May 6, 2011 Oameni buni, tot eu va deranjez cu o problema pe care n-am mai intalnit-o vreodata si - cel putin deocamdata - nici fratele Google n-a reusit sa-mi dea un raspuns. Deci la un laptop DELL Vostro, din senin, tastatura a inceput sa se comporte ciudat. Mai precis, cateva taste bat cate 2 caractere. Exemplu: apesi 1 sau q (deci apesi o singura tasta) -> apare q1 apesi 2 sau w -> bate w2 apesi 3 sau e -> bate e3 si asa mai departe, problema apare doar la tastele 1,2,3,4, 7,8,9,0 respectiv q,w,e,r,u,i,o,p (literele de sub respectivele numere) Laptopul e aproape nou, are vreo 3 saptamani de cand lucreaza omul pe el. I-am dezinstalat tastatura din device manager, a pus-o la loc dupa reset, dar problema persista. I-am dezinstalat limbile, romana... apoi si engleza, din Regional and Language ... reset... nici o imbunatatire. Am deschis On-Screen Keyboard din Programs>Accesories>Accesibility ... aia merge ok, deci problema pare a fi de la tastatura hard. Nu s-a turnat apa pe tastatura, nu are praf, nu s-a dat cu pumnu in ea. Nu e de la NumLock, ScrlLock, etc, le-am sucit on/off degeaba. Nu e nici o tasta ramasa apasata, sau cel putin nu se vede. Poate mai aveti vreo ideie. Link to comment
mihai72ro Posted May 6, 2011 Share Posted May 6, 2011 Eu banuiesc ceva: cauta cu un anti-rootkit; ai probabil un programel de tip "keystroke" autoinstalat. Link to comment
