andreib Posted December 21, 2008 Share Posted December 21, 2008 (edited) Not the same shit! Mie imi deschide o pagina/tab nou cu travian, iar update-ul nu merge chiar daca e browserul dechis (cum zicea un user pe acolo). LE: Mai mult, pe celalalt calculator din mini reteaua din casa merge updae-ul si nau apar pop-up uri enervante... Edited December 21, 2008 by andreib Link to comment
zeneseu Posted December 21, 2008 Share Posted December 21, 2008 (edited) Am 2 probleme, marunte dar enervante:1. nici un antivirus nu mai reuseste sa-si faca update de pe calc meu... (avira, avg, bitdefender) ... Chestia asta o patesc si eu cam odata la 2-3 luni. Deja m-am obisnuit sa reinstalez AVG-ul Providerul meu de net nu este rds si am IP automat. Edit: La servici nu am avut inca aceasta problema. Providerul este RDS. Edited December 21, 2008 by ZeNeSeu Link to comment
tolin Posted December 21, 2008 Share Posted December 21, 2008 (edited) Utilitar foarte bun pentru windoze: http://www.download.com/Advanced-SystemCar...cdlPid=10990630 Edited December 21, 2008 by tolin Link to comment
Salex Posted December 21, 2008 Share Posted December 21, 2008 Hehe. Credeam ca e o problema doar la mine, nu prea am mai avut vreme in ultimul timp sa vad ce e si cu mizeria aia Link to comment
darky Posted December 21, 2008 Share Posted December 21, 2008 Am si eu o problema mi-am cumparat un cablu S-Video , si adaptor de scart il bag in tv dau pe av si imi apare o secunda si dispare Placa video este NVIDIA GeForce 9400GT. Link to comment
Satori Posted December 21, 2008 Share Posted December 21, 2008 O fi stiind, dar e pacat sa streamuiesti muzica la 2.1 megabits/sec = 200 kb/s (pe care nu prea ii atingi oricum) cat are BT 2.0 cu EDR pe asa jucarie Who said anything about bluetooth? WLAN, nene Link to comment
NFS Posted December 21, 2008 Share Posted December 21, 2008 Am 2 probleme, marunte dar enervante:1. nici un antivirus nu mai reuseste sa-si faca update de pe calc meu... (avira, avg, bitdefender) 2. am un pop-up care tot apare from time to time care e extrem de enervant... Any ideas? Va anunt solemn, pe toti care ati zis ca aveti aceeasi problema... ca aveti un virus / spyware / troian ... ce vreti voi. Sunt sigur cam 80%. Am patit si eu la servici pe cateva calculatoare. Ba chiar si acasa. Pe majoritatea am rezolvat, pe unul a trebuit sa reinstalez Windowsu, din fericire nu p'al meu. Simptome: 1. Browseru se duce cam unde vrea el, cel putin pagina de start. 2. Nici un antivirus nu-si mai face update. De fapt probabil ca nici nu mai puteti intra pe homepage-urile respective. 3. Programe gen Spybot sau Malware Remover, desi le puteti instala, nu le puteti rula! 4. S-ar putea sa nu mai puteti accesa Task Manager (ctrl-alt-del), nici chiar de pe contul de administrator. Verificati homepage-ul. Daca totul pare in regula dar broserul va duce tot unde vrea el, cautati pe calc un fisier numit hosts (exact asa, fara extensie). Deschideti-l cu Notepad. In principiu ar trebui sa aveti in el o linie ca asta: 127.0.0.1 localhost Daca mai sunt si altele necomentate !!!, verificati... s-ar putea sa fie exact pagina cu travianu. Stergeti-le si puneti-o p-asta de mai sus. Gasiti acest utilitar (sau colectie de utilitare): SmitfraudFix. Cititi cu atentie ce va spune sa faceti. Dupa ce va jucati cu asta, ar trebui sa inceapa sa va mearga programele de la punctul 2. Cu alea mai eliminati o parte (mare) din probleme. Daca mai ramane ceva, mai strigati. Link to comment
Zmeul cel rau Posted December 22, 2008 Share Posted December 22, 2008 Problema cu alimentarea desktopului: Apas pe butonul de pornire si nu se intampla nimic. Daca scot alimentarea de pe placa de baza si strapez firul verde cu un fir negru de pe mufa, sursa porneste (se invarte ventilatorul). Cand introduc mufa cu firele alea doua strapate in placa de baza sursa se opreste, desi cu un moment inainte sa faca asta, da sa porneasca si coolerul procesorului. Imediat insa se opreste. Sursa e ATX. Cum functioneaza sursa asta? Ce o poate face sa se opreasca? Presupun un scurt dar unde? Link to comment
Wolfman Posted December 22, 2008 Share Posted December 22, 2008 (edited) Fa un reset de BIOS, daca tot nu porneste verifica condensatorii electrolitici de pe MB, daca sunt umflati/explodati inlocuieste-i; oricum, te paste un upgrade la placa de baza... Edited December 22, 2008 by Wolfman Link to comment
Zmeul cel rau Posted December 22, 2008 Share Posted December 22, 2008 (edited) Sunt intregi. Cum fac reset de BIOS? E dual Bios dar nu porneste de nicio culoare. Edited December 22, 2008 by Zmeul cel rau Link to comment
andreib Posted December 22, 2008 Share Posted December 22, 2008 Simptome: 1. Browseru se duce cam unde vrea el, cel putin pagina de start. 2. Nici un antivirus nu-si mai face update. De fapt probabil ca nici nu mai puteti intra pe homepage-urile respective. 3. Programe gen Spybot sau Malware Remover, desi le puteti instala, nu le puteti rula! 4. S-ar putea sa nu mai puteti accesa Task Manager (ctrl-alt-del), nici chiar de pe contul de administrator. Gasiti acest utilitar (sau colectie de utilitare): SmitfraudFix. Cititi cu atentie ce va spune sa faceti. Dupa ce va jucati cu asta, ar trebui sa inceapa sa va mearga programele de la punctul 2. Cu alea mai eliminati o parte (mare) din probleme. Daca mai ramane ceva, mai strigati. 1. inca nu intra dar deschidea o fereastra de popup 2. homepage-urile le puteam accesa, update nu 3. spybot mergea, si update si tot 4. mda, incepuse deja sa crash... Oricum ,mersi mult... Dupa rularea programelului merge update-ul si nu am mai vazut nici popup-ul... Link to comment
Wolfman Posted December 22, 2008 Share Posted December 22, 2008 Sunt intregi. Cum fac reset de BIOS? E dual Bios. Daca nu vezi un jumper in apropierea bateriei (unele placi OEM nu au) , deconectezi tensiunea, scoti bateria pt. 30 sec.si cu ea scoasa apesi butonul de power. Link to comment
Zmeul cel rau Posted December 22, 2008 Share Posted December 22, 2008 Am gasit un jumper marcat CLR_CMOS dar nu are calaretul pe el. LE: L-am scurtcircuitat cu alimentarea scoasa. Niciun efect. Link to comment
Wolfman Posted December 22, 2008 Share Posted December 22, 2008 Cateodata a mai mers demontarea/montarea procesorului, in ultima instanta... Link to comment
Zmeul cel rau Posted December 22, 2008 Share Posted December 22, 2008 Da, nu am reusit decat sa imi belesc degetele. Cred ca am ce face in week-end sau de Craciun: il desfac si il fac de la zero. ) Link to comment
rm.popa Posted December 22, 2008 Share Posted December 22, 2008 Am gasit un jumper marcat CLR_CMOS dar nu are calaretul pe el. Păi dacă era "călăreţul" pe el, aveai un BIOS veşnic... "clear" (default, mai precis). Încearcă să mai scoţi/ bagi câteva componente, poate e ceva mişcat pe acolo: placa video ori alte device-uri de pe PCI, procesorul, memoriile, eventual decuplează chestiile neesenţiale (CD/ DVD/ HDD-uri suplimentare etc.). Şi bagă şi un aspirator prin el. Asta dacă n-ai chef să-l desfaci complet, să-l cureţi de praf şi să-l faci la loc (ceea ce ar fi cel mai bine). Link to comment
Lucian M Posted December 22, 2008 Share Posted December 22, 2008 Mai degraba un jet de aer comprimat. Cu aspiratorul mai dai peste ceva si-ti pare rau. Zmeule, daca nu te descurci, trimite-l la mine. Ti-l rezolv eu. Link to comment
Zmeul cel rau Posted December 22, 2008 Share Posted December 22, 2008 Haidi, bre, de dat cu aspiratorul ma descurc. Asta era si planul meu. Ma gandeam totusi ca e vreo chestie care se intampla frecvent si la care ar trebui sa fiu atent. Multumesc tuturor de sfaturi. Link to comment
Lucian M Posted December 22, 2008 Share Posted December 22, 2008 Faza cu condensatori umflati/explodati e pe bune. Poti sa-i inlocuiesti cu unii noi, sau poti "imprumuta" de la o placa defecta din alte motive. Spor! Link to comment
soferucalm Posted December 22, 2008 Share Posted December 22, 2008 Ce recomandati sau mai bine zis ce configurare pentru: laptop+ tv tuner+ receiver+ abonament+ antena satelit? Basca, legaturi 12/24v,amplificatoare, boxe si alte alea. Multumesc! Link to comment
vladawd Posted December 23, 2008 Share Posted December 23, 2008 Cat consuma un computer ? Mai precis : cat ar consuma un calculator (desktop) intr-un an, daca ar fi pornit 24/24 si nu ar face altceva decat sa fie folosit pe post de server de stocare si descarcat fisiere de pe torrente sau de pe de ce++ ? Bineinteles ca fara a avea un monitor atasat. Cablu de internet si alimentare si...dosit bine intr-un colt al casei. Mersi ! Link to comment
Zmeul cel rau Posted December 23, 2008 Share Posted December 23, 2008 Faza cu condensatori umflati/explodati e pe bune. Poti sa-i inlocuiesti cu unii noi, sau poti "imprumuta" de la o placa defecta din alte motive.Spor! Stiu. Am mai schimbat si eu acum vreo 6-7 ani la una. Acum nu se vede nimic umflat... Link to comment
Megaherz Posted December 23, 2008 Share Posted December 23, 2008 Salut Am achizitionat un sistem genius sw-hf 5.1 5100 si am constatat ca nu am semnal pe boxele din spate si centru. Functioneaza ca un fel de 2.1 . SW-ul are pe spate 2 variante: 1) Auxiliare L-R ( RCA ) 2)FL - FR RL - RR Cen - SUB Mufe RCA Mentionez ca folosesc pt placa de sunet un Creative LIve 5.1 In manual scrie ca daca doresti sa conectezi un PC...etc trebuie sa folosesti varianta cu Auxiliare si are sistemul un buton care trece automat pe 5.1. Nu a tinut. Am incercat sa folosesc a doua varianta si anume sa conectez niste cabluri RCA (ALB ROSU) la un capat si mufa jack la celelalt capat. Mai exact fata, spate si CEN - SUB separat, in iesirile placii de sunet. Am reusit sa am semnal in toti satelitii dar nu am bass prea puternic. Mentionez ca in varianta cu 2.1 bass-ul era puternic. Am incercat si placa de sunet incorporata in placa de baza (AC 97). Rezultatul - identic, nu am semnal in satelitii spate si in cel central. Ma puteti ajuta cu niste sfaturi ? Va multumesc Link to comment
Bogdan_80 Posted December 23, 2008 Share Posted December 23, 2008 Megaherz din cate am inteles dpdv hardware e conectat tot cum trebuie si banuiesc ca si din software ai setat pe 5.1. Eu am un Altec Lansing la care cand am mai facut diverse permutari ma loveam de probleme asemanatoare, pe care le-am rezolvat din software si anume softul Sound Max are o optiune de detectare a intrarilor la pornire. Deci dupa ce s-a incarcat widoza apare o fereastra in care te intreaba in jack-ul roz e introdus sw-center, tu avand de facut setarile in functie de ce este conectat corect pe fiecare jack in parte. Eu asa am rezolvat, ca le detecta aiurea. Dupa ce faci chestia asta ii debifezi optiunea respectiva ca sa nu te zapaceasca de cap de fiecare data cand pornesti PC-ul. Link to comment
