zapacitu Posted January 12, 2009 Share Posted January 12, 2009 Ce placa de baza e?Modelul? Link to comment
vlad10 Posted January 12, 2009 Share Posted January 12, 2009 asus P5KPL-CM , hdd samsung Link to comment
zapacitu Posted January 12, 2009 Share Posted January 12, 2009 Incearca cu astia: Sata_Drivers.rar Sint de intel, ar trebui sa mearga Link to comment
Lucian M Posted January 12, 2009 Share Posted January 12, 2009 Am aceeasi placa + un hdd tot samsung de 250 gb, s-ata 2, 16 mb buffer. A mers instalata win-ul "la sfert". Link to comment
zapacitu Posted January 12, 2009 Share Posted January 12, 2009 Atunci spune-i unde sa umble in bios. Hard-ul nu are nici o legatura. Link to comment
Lucian M Posted January 12, 2009 Share Posted January 12, 2009 Sa mor daca am facut ceva in BIOS. Am facut setarile clasice pentru procesor, boot, usb si data/ora si cam atat. Link to comment
SmartTony Posted January 12, 2009 Share Posted January 12, 2009 asus P5KPL-CM , hdd samsung O asemenea placa de baza are tot ce ii trebuie preinstalat. Asigura-te ca HDD-ul este vazut in BIOS, inainte sa instalezi XP-ul. Daca Nu este vazut in BIOS, configureaza-l sa fie vazut. Pentru asta ai link-ul catre cartea tehnica a placii tale de baza (uita-te la sectiunea 2.3.5). (Poti incerca mai intai o setare a BIOS-ului la valorile "Default"). http://support.asus.com/download/download...SLanguage=en-us Bafta! Link to comment
Lucian M Posted January 12, 2009 Share Posted January 12, 2009 O asemenea placa de baza are tot ce ii trebuie preinstalat. Subscriu. Voiam sa iau un Asrock- insa nu regret nicio secunda ca am luat KPL-ul. Cuplat cu un 7200 si un kit 2 gb dual-channel nu-ti vine sa crezi cum merge. Totusi nu-mi dau seama de ce nu-i vede hdd-ul. Trebe verificat sa fie bine infipte cablurile (date si alimentare). Altceva- verifica daca nu cumva kit-ul de xp nu o fi unul prea vechi. Zic si eu... Link to comment
vlad10 Posted January 13, 2009 Share Posted January 13, 2009 Am rezolvat, am gasit driver-ul pe site-ul samsung(hdd).Va multumesc tuturor pt ajutor! Link to comment
hitman Posted January 19, 2009 Share Posted January 19, 2009 Un review bunicel pentru noul Windows 7 Link to comment
Lucian M Posted January 20, 2009 Share Posted January 20, 2009 (edited) Am o problemuta- ma restarteaza de ma termina. Am gasit cate ceva despre anularea erorii, am dezactivat- zic eu- de 15 min merge ok. Parca am mai avut acum ceva timp (vreo 7-8 ani) problema asta, dar atunci aveam un utilitar. Prin upgrade-ul la SP2 stiam ca se rezolvase. Ca antivirus- bitdefender total security 2009 trial. Edited January 20, 2009 by Lucian M Link to comment
SmartTony Posted January 20, 2009 Share Posted January 20, 2009 Am o problemuta- ma restarteaza de ma termina. Am gasit cate ceva despre anularea erorii, am dezactivat- zic eu- de 15 min merge ok. Parca am mai avut acum ceva timp (vreo 7-8 ani) problema asta, dar atunci aveam un utilitar. Prin upgrade-ul la SP2 stiam ca se rezolvase.Ca antivirus- bitdefender total security 2009 trial. Eu am rezaolvat problema prin format si reinstall Deh minunatele sisteme windows(la linux nu te prindeai de ce nu merge ) Link to comment
Lucian M Posted January 20, 2009 Share Posted January 20, 2009 (edited) Multam fain, win-ul e instalat de doua saptamani si n-am chef (sincer) sa-l iau de la cap si sa-l bichirisesc din nou. Am sa dau o scanare, cu toate ca am dat disable si fara "computer restart" din <dcomcnfg>. Acum vreau sa dau un sistem scan si Bit-ul zice "failed to launch BitDefender scanner"... Edited January 20, 2009 by Lucian M Link to comment
hitman Posted January 21, 2009 Share Posted January 21, 2009 S-ar putea ca mesajul care se afiseaza sa fie de la un virus. Virusul acesta a circulat acum citiva ani, l-am avut si eu. Incearca sa instalezi FreeAvg daca nu merge Bitdefenderul Link to comment
Tommy Posted January 21, 2009 Share Posted January 21, 2009 Luciene, tu ai SP2? Ia incearca sa-i scoti reteaua si sa faci ce spune aici: http://www.tiscali.co.uk/help/msbremove.html Link to comment
Lucian M Posted January 21, 2009 Share Posted January 21, 2009 XP sp3, fara update la zi (ca nu e original). Virusul a fost identificat si scos din schema ( Sasser ). Am facut scan cu utilitarul dedicat- acum mere si scan cu Bit. Un destept pe SP m-a luat in caruta- de parca i-am virusat lui pc-ul. Macar mi-a zis ce virus este. Link to comment
NFS Posted January 21, 2009 Share Posted January 21, 2009 Da, e amicu' Sasser/Blaster! Citeste p-acilea: http://www.smartcomputing.com/techsupport/...p;ErrorID=33567 Daca ai timp, apasa Windows Key-R. Asta iti va deschide fereastra de Run. Scrie acolo shutdown -a. Teoretic ar trebui sa se opreasca shutdown-ul. Link to comment
madkat Posted January 23, 2009 Share Posted January 23, 2009 stati ca am citit treaba cu barele de leduri in loc de ccfl-ul de laptop mai multe detalii se poate? de exemplu cum se impaca cu controlul de intensitate a backlight-ului - ca intensitate - cum sunt fata de ccfl-uri, si ultima chestie - reusesti acceasi temperatura de culoare si dispersie ca in cazul tubului original? Link to comment
zeneseu Posted January 23, 2009 Share Posted January 23, 2009 Se da un calculator cu sistem de boxe 5.1. La testul sistemului cu softul placii audio functioneaza toti satelitii. In cazul in care se asculta muzica, functioneaza doar 2 sateliti. In winamp am instalat plugin 5.1 si tot degeaba. Chiar si cand se inchide/porneste calculatorul, sunetul ce insoteste aceste 2 operatii se aude tot in 2 sateliti. O parere se poate? Link to comment
Bogdan_80 Posted January 23, 2009 Share Posted January 23, 2009 (edited) ZeNeseU ai incercat asta? Ca pe langa ce am scris acolo am avut si manifestari de genul asta. Verifica sa fie si in soun&audio properties din control panel pe 5.1. Edited January 23, 2009 by Bogdan_80 Link to comment
zeneseu Posted January 23, 2009 Share Posted January 23, 2009 (edited) Punctual. 1. In momentul in care introduc mufele, apare fereastra respectiva. Sesizeaza corect mufa introdusa. 2. E setat si in control panel 5.1 Am incercat n'spe variante si tot nimic. Asta in ciuda faptului ca din softul placii audio, la test, merg toti satelitii. P.S. Sistemul a functionat inainte optim. Sa fi miscat ceva in placa de baza cand am desfacut PC-ul sa mai adaug un HDD? Parca de atunci nu mai merge. Edited January 23, 2009 by ZeNeSeu Link to comment
Aygun Posted January 23, 2009 Share Posted January 23, 2009 Da , pot da mai multe detalii ! La noi in service vin , de regula , oameni disperati ca nu le merge notebook-ul ( nu se mai aprinde ecranul - zic ei). Dupa o prima vedere se observa ca lampa nu se mai aprinde . Desfac displayul si am o lampa de proba , daca aceea se apinde e lampa dusa , daca nu se aprinde e invertorul. Booon , am cautat diverse tipuri de invertore insa nu se preteaza scopului deoarece sunt foarte voluminoase ( aproape duble ca dimensiune - grosime - latime - lungime ) pentru ca nu au transformator ridicator de tensiune ci un rezonator piezo. Tocmai am ramas cu unul in gestiune pentru ca l-a refuzat clientul pe motiv ca e prea mare si ca mai bine merge pe monitor extern decat sa il puna pe acela. Ca idee , un invertor cu element piezo este vreo 185 ron pentru o singura lampa . Se gasesc si invertoare cu 2 sau 4 iesiri pentru monitoarele tft desktop. De aici a pornit ideea trecerii la backlight pe leduri smd. In consecinta utilizatorii nu au decat o solutie , sa recupereze notebook-ul asa ca ( de regula ) accepta urmatorul compromis - iluminare fixa ( nonvariabila ) contra consum mai mic si durata mare de functionare / In medie ledurile sunt garantate vreo 100000 de ore de functionare fata de tuburile fluorescente cu circa 16000 ore. Invertoarele din notebook-uri se alimenteaza uzual la 18,4 volti iar unele ( mai rare , cei drept la vreo 14,4 V ) astfel incat am de unde sa iau 12 V necesari alimentarii baretei cu leduri smd. In ultimele notebook-uri "modate" am folosit circa 48 sau 52 leduri conectate serie paralel. Uzual conectez cate 4 leduri serie acestea conectandu-le in paralel cu celelalte grupe de cate 4 leduri serie. Fiecare grupa de cate 4 leduri serie este inseriata si cu o rezistenta de 47 ohmi sau 100 ohmi in functie de cat de tare trebuie sa fie stralucirea ( stralucirea este dictata de client care este la fata locului cand se fac ajustarile ). Pot face si un mic variator de stralucire cu ajutorul unui attiny 13 insa nu am avut timp sa dezvolt si un montaj pentru asta ( ca sa nu mai vorbesc de soft ). Mai de mult faceam potentiometre digitale cu MMC-uri 4011 si 4017 ( in loc de convertoare D/A ). Un attiny 13 sau PIC pe post de variator de curent sau tensiune ( cred ca e mai bine sa jonglezi cu tensiunea ) cred ca este suficient. Invertoarele de pe notebook-uri au un semnal de CE (Chip Enable ) si un semnal ptr Dimmer , cred ca ma pot folosi de ele sa reglez stralucirea . In ceea ce pribeste stralucirea si cantitatea de lumina nu am avut plangeri si este apropiat ca intensitate de 80 sau chiar 90 % din intensitatea data de neoane. Lumina este un alb cald aidoma celor date de lampa. Singurul inconvenient este ca in zona de contact cu suprafata de dispersie ( acel plastic care vine in spatele ecranului) apar mici punctulete. O alta problema o constituie unghiul de dispersie a ledurilor smd ( undeva de 30 - 35 grade ) iar pina in zona in care lumina se intersecteaza se vad usoare zone de penumbra , isesizabile daca nu te uiti atent. Azi am "modat" un tft philips de 19" cu 70 de leduri piranha albe. Sfat , daca doriti s afaceti asa ceva luati fiecare led la testat pentru ca unele led-uri dau o lumina galbuie in loc de lumina aceea alba ca de neon ( am patit-o ). Pina acum cateva notebook-uri lipeam led-urile smd direct de suprafata de dispersie si anume pe muchia unde venea lampa , acum insa , pun ledurile pe un cablaj lat 2mm latime. Cine doreste ( si este din Cta sau imprejurimi si vrea sa vada cum functioneaza aceste lucruri ) ma poate contacta la sediul firmei care se afla langa posta mare din Cta. Sper ca nu se considera reclama . Daca totusi va fi editat ma puteti contacta pe PM. Numai de bine. Link to comment
Abram Burel Posted January 24, 2009 Share Posted January 24, 2009 Arunca o privire cu osciloscopul pe iesirea de dimming de la laptop/lcd. Daca sunt impulsuri cu latimea variabila (in functie de reglaj) s-ar putea comanda usor bagheta cu leduri (PWM). Link to comment
Aygun Posted January 24, 2009 Share Posted January 24, 2009 Sigur ca asa voi face la urmatorl laptop. Cred ca gasesc semnalele de invertor si pe net.Oricum mai bine masor sa vad cu ochiul meu. Te anunt de indata ce am masuratorile. OK ? POate reusim sa punem ceva la punct. Ar prinde bine nitel ajutor . Am gasit acum niste leduri piranha si smd care dau lumina alba difuza nu punctiforma. Plasticul in care sunt invelite este opac. Link to comment
