Cristaky Posted January 13, 2006 Share Posted January 13, 2006 Castrol 5W30 ... ca si andreib >- Link to comment
Razor Posted January 13, 2006 Share Posted January 13, 2006 Castrol Softec TXT - 5w30 Link to comment
paul_marines Posted January 21, 2006 Share Posted January 21, 2006 GM 5W 30 Super sintetic Link to comment
Mad MAX Posted January 22, 2006 Share Posted January 22, 2006 mobil super s 10W40 la cielo si la matiz vreau sa pun tot acelasi ulei ( actual daewoo 10 w 30) este vreo problema daca pun mobil 10 w 40 in matiz(adica daca nu e cu 30 la sfarsit) ? Link to comment
NFS Posted January 23, 2006 Share Posted January 23, 2006 Mad MAX said: ...este vreo problema daca pun mobil 10 w 40 in matiz(adica daca nu e cu 30 la sfarsit) ? Nici o problema! Eu numai din asta am avut dupa revizia de 1000km. (cu o singura exceptie, la un schimb am bagat 5W30 Texaco sintetic, da' l-am inlocuit dupa doar 3000 km ca nu-mi placea cum se aude motorul). Link to comment
ticodriver Posted January 23, 2006 Share Posted January 23, 2006 Mobil DriveClean 10W40. Link to comment
Hijack_3000 Posted March 19, 2006 Share Posted March 19, 2006 Aral 5w40 folosesc momentan, dar la urmatorul schimb ii pun Castrol TXT 5w40( la sfatul lui Ovi_jer ) Link to comment
Mad MAX Posted March 20, 2006 Share Posted March 20, 2006 facut schimb la matiz cu Castrol TXT softec plus 5W30. Maaaaare diferenta fata de daewoo 10W30. Link to comment
marr Posted March 20, 2006 Share Posted March 20, 2006 Liqui Moly 5 W 40 - sintetic. Asta mi-au pus la revizia de 15.000 (dealer-ul este si reprezentant Liqui Moly). Link to comment
Dj_Dark Posted March 20, 2006 Share Posted March 20, 2006 texaco 5w30 f multumit pana acum fata de vechiul 15w40 daewoo schimbat la 4000 fiindca nu-l mai suportam dar vreau sa incerc castrol txt softec 5w40 (5w30 nu prea gasesc) . Link to comment
laur_gle Posted March 20, 2006 Share Posted March 20, 2006 Mobil Super S 10W 40 . Se comporta bine la 6500 km facuti pina acum cu el , motorul e silentios , nu s-a spumat deloc !!!! ( sfat : cel pt diesel de la Mobil e Super M 10W 40 , a nu se confunda !!!!!) As vrea sa incerc Aral Blue Tronic 10W 40 ... dar parerile sint impartite ... nu se prea impaca bine cu motoarele daewoo... Sau sa merg in continuare pe Mobil si sa ii bag sintetic ( 5W 40) ... ...astept ( 1000 de ... ) sfaturi "> !!!!!! Link to comment
Mad MAX Posted March 20, 2006 Share Posted March 20, 2006 mai bine incerci 5w40 decat Aral. Link to comment
Sharpe Posted March 20, 2006 Share Posted March 20, 2006 Castrol TXT Softec 5W-40+DuraLube. Link to comment
el cid Posted March 20, 2006 Share Posted March 20, 2006 aral 10w 40 si sunt multumit. ptr. consum super si la temperaturile extreme din iarna asta. cei care se pling de aral va rog argumentati , ca sa stie si restul tarii. Link to comment
Miste_R Posted March 20, 2006 Share Posted March 20, 2006 Castrol GTX3 Magnatec 10w-40 Link to comment
serban_pc Posted March 22, 2006 Share Posted March 22, 2006 Eu i-am facut motorul si ii bag Castrol RS 10W60. La ultimul schimbat am bagat si duralube motor + alimntare. Link to comment
