Ce ulei de motor aveti acum?
Ulei motor
592 members have voted
GM Requires new dexos oil for 2011 Models
For 2011, General Motors has announced a new oil requirement called "dexos." GM says their new oil performance specification is better than the new GF-5 specification, which also goes into effect this fall. GM says dexos will be required in all 2011 and newer GM engines, and it will be backwards compatible with older engines that use SM oils.
There will be two versions of dexos:
dexos1 for gasoline engines and
dexos2 for diesel engines.
The specification calls for a high quality synthetic base stock with additives that provide high temperature, high sheer characteristics to reduce friction for better fuel economy, to reduce piston ring deposits and sludge, and to extend oil life (necessary for use with GM's Oil Life Reminder System).
Because it uses high quality synthetic base stocks, dexos and other brands of oil that meet GM's dexos specification will likely cost 30 to 60% more than conventional motor oil. GM will license other brands that meet their spec. Pennzoil Platinum and Quaker State Ultimate Durability both claim to meet the new dexos spec now in their SAE 5W-30 viscosity grade motor oils.
Pare bun, nemtesc, kaufland nu vinde produse proaste sub marca proprie..
Mineral 100%, heavy duty, probabil pentru camionete sau chestii de gen pentru livrare marfa. De ce ai pune asa ceva in masina? :)
La Kaufland au cascaval misto, si baterii AAA decente, insa ulei de-al lor nu as baga in motor... Naiba stie ce producator o avea...
Momentan (dupa schimbarea garniturii de chiulasa - detalii pe topicul meu) am ulei GM Dexos2 5W30 - de 2500km, inca arata bine, si se stinge relativ repede becul de ulei dupa pornirea motorului.
Edited by madkat
Stii cum se face uleiul 15w40 la -15 grade? Mananca ulei sau de ce folosesti?
In legatura cu uleiul Kaufland, vroiam niste pareri, e 99 ron 5 litri, dar nu fac experimente, o sa iau de origine GM la 115 ron 5 litri probabil.
Nu mananca neam, e primit. Il tin si eu doo, trei mii si-l arunc. Nu se face nicicum, porneste la prima cheie, mintenas. :)
PS
Ref. la uleiul din K, daca mai ai nitica rabdare, il incerc eu si-ti zic.
Edited by BZN
Acum folosesc Valvoline 5w40. Am vazut si eu uleiul din kaufland si am cautat pe eticheta sa vad cine il face dar nu scrie. Ma intereseaza cel sintetic. Poate ne spune cineva de cine ii facut pentru ca ,,,,,kauflandul nu face nici cascaval si nici ulei de motor :thumbl:
La multi ani! tuturor!
Am pus ieri Motul 8100 X-cess (5W40)  <img src= ">
Acelasi lucru am si eu acum si mi se pare cel mai bun ulei din ultimul timp, macar nu e turcesc ;) . La uleiurile ieftine mai important e unde e facut decat marca lui, am avut mobil synt si bun si prost, la fel si castrol.
Cand voi avea bani (daca ma va lasa inima sa bag vreodata ulei de 240 RON in masina de 1500 euro :) ) o sa incerc mobil 1 si Castrol edge.
Edited by Dj_Dark
Mobil 1
http://www.mobil1.com.ro/cms/Mobil-1-ESP-Formula-5W-30.aspx
Castrol Edge
http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=9034031&contentId=7063626
Iar ne hazardam in afirmatii? :)
PS. Ca idee, mi-au zis mie 2 vecini ca un ulei de TDI merge intr-un motor pe benzina fara probleme. :)
Invers nu.
Edited by Dj_Dark
