augustinionut Posted August 9, 2017 Share Posted August 9, 2017 (edited) Cauta topicul cu contact matiz, se schimba doar miezul butucului si cateii cu arculetele. Juma de ora de treaba. Edited August 9, 2017 by augustinionut Link to comment
Viktor Posted August 9, 2017 Share Posted August 9, 2017 (edited) La mine-s cheile motorului de ca_tare ... Cred ca o sa-i fac citeva clone si le impart. http://www.gmclub.ro/forum/index.php/topic/27891-cum-se-schimba-contact-pornire-matiz-contactul-are-cip/ Edited August 9, 2017 by Viktor Link to comment
augustinionut Posted August 9, 2017 Share Posted August 9, 2017 Pe tine am sa te propun moderator, ca vad ca te invarti cam mult pe aici 1 Link to comment
Viktor Posted August 10, 2017 Share Posted August 10, 2017 Te inscrii la concediu, Ionele ? Link to comment
Viktor Posted August 20, 2017 Share Posted August 20, 2017 Adevar graira-i, buburuza. Contactul electric deveni fumigen, in cazul mai sus mentionat. Treaba e ca nu se arata niciunde, dar din cind in cind se prajea mocnit la interior si asta datorita contactului mecanic ce prezinta uzura accentuata ce in ultima faza, in mers, a pus electromotorul in miscare. Banui ca deteriorarile din al electric conducea la un scurt intre pini ce prajea plasticul. Link to comment
ga6riel Posted August 15, 2018 Share Posted August 15, 2018 Salutare, Daca ma poate lumina cineva! Am un matiz euro 3 cu urmatoarea problema: incalzeste bateria excesiv si blocul de sigurante, iar in circa 6 ore nu mai am curent deloc si evident nu mai porneste... problema a aparut dintr-o data, fara sa fii avut vreo interventie tehnica la masina. va rog daca ma puteti ajuta. Link to comment
nikku1985 Posted July 29, 2019 Share Posted July 29, 2019 Salutare, Imi puteti recomanda un electrician in Bucuresti pentru Matiz? Nu-mi mai merg faza lunga si faza scurta la Matiz. Am verificat sigurantele si nu sunt arse. Link to comment
Negrea Ion Posted September 25, 2020 Share Posted September 25, 2020 Buna dimineata. Am un matiz din 2002 si o data pe zi mi se aprinde senzorul de la motor. Am fost la cel putin 10 servisuri sa fac diagnoza si cand încearca sa se conecteze da eroare de conectare. Ma poate ajuta cineva unde ma pot duce? Link to comment
adrian_r5 Posted September 25, 2020 Share Posted September 25, 2020 On 9/25/2020 at 3:44 AM, Negrea Ion said: Ma poate ajuta cineva unde ma pot duce? Expand Incearca aici - Revizie Matiz La Domiciliu - Preturi De Criza Link to comment
Andreiteodor Posted February 15, 2022 Share Posted February 15, 2022 On 12/18/2014 at 9:35 PM, cris06 said: @Ativix: daca becurile din bord se sting imediat ce pozitia cheii e pe "demaror", cred 100% ca e contactul de cheie defect. Scoate-i mufa din contact si fa un strap cu un fir mai gros intre +30, +15 si +15a. Ar trebui ca martorii de bord sa se aprinda. Apoi, cu o bucata de fir (gros), atinge scurt intre +30 si 50 si ar trebui ca motorul sa porneasca Expand Am aceiași problema,doar că la mine nu se striga martori din bord, de la ce poate fi? Link to comment
