milosh Posted December 11, 2005 Share Posted December 11, 2005 http://www.nexiaclub.com/view.php?cisloclanku=2005121101 Link to comment
Zmeul cel rau Posted December 11, 2005 Share Posted December 11, 2005 Those are some straaange gauges! Are you sure they were the original ones mounted on that Cielo? Link to comment
Maniaku Posted December 11, 2005 Share Posted December 11, 2005 @Zmeu as you can see is not a daewoo nexia, is a Pontiac!!! maybe it has diferent gauges Link to comment
Esperatul Posted December 11, 2005 Share Posted December 11, 2005 Mai merge 180.000 km, ii da o vopsea si o vinde cu 80.000 km la bord. Boboc. Link to comment
NFS Posted December 11, 2005 Share Posted December 11, 2005 Hai, mah, maniakule... daca te iei dupa volan, ce marca e Matizul tau? Link to comment
laurentziu83 Posted December 11, 2005 Share Posted December 11, 2005 P-aia cu "invarte volanul de renault pe Dacia Nova" o stiti? (Parazitii) Link to comment
Maniaku Posted December 12, 2005 Share Posted December 12, 2005 Volanul meu nu este luat de pe alta masina!!! este o marca producatoare!! Link to comment
NFS Posted December 12, 2005 Share Posted December 12, 2005 Stai mah, nu te'ambala... idee era ca volanul se poate schimba. Usor! Si caroseria se poate schimba... da' pina una alta, cind vad o forma de cielo cu embleme daewoo... tot ce-mi vine in cap e un pontiac, nu? Link to comment
aztec Posted December 12, 2005 Share Posted December 12, 2005 (edited) este un daewoo cielo supertaxi.. sau asa inteleg eu pe spate Chevrolet Kadett Opel Kadett (Europa, exceto Inglaterra), Vauxhall Astra e Astra Belmont (Inglaterra; hatch e tręs-volumes; este depois passou a apenas Belmont), Pontiac Le Mans (EUA), Daewoo Cielo, Nexia, Racer, Le Mans e Penta-5 (Coréia do Sul e Leste Europeu), Asüna SE e GT (Canadá), Passport Optima (Canadá), Daewoo Supertaxi (Colômbia), Daewoo Heaven (Chile), Daewoo 1.5i (Austrália), Bedford Astravan e Vauxhall Astravan (Inglaterra; versăo furgăo) Edited December 12, 2005 by aztec Link to comment
laurentziu83 Posted December 15, 2005 Share Posted December 15, 2005 Diferenta e ca asta merge Link to comment
