laurentziu83 Posted January 7, 2006 Share Posted January 7, 2006 (edited) Daca va intereseaza ce masini au fost rechemate la service pentru diverse (posibile) defectiuni din 1992 incoace intrati aici si va minunati. Aici am gasit si problema cu cablul de ambreiaj la matiz, in tarile cu apa calda erau rechemate masinile, numai la noi isi lua Daewoo mana de pe noi, eventual te lasa in plata domnului serviciul de asistenta rutiera zicandu-ti ca daca ei nu ai piese de schimb (si nu aveau) atunci trebuie sa platesti. P.S: se pare ca dracia e cea mai buna masina, ca n-a avut rechemari. Edited January 7, 2006 by laurentziu83 Link to comment
dreamlike Posted January 7, 2006 Share Posted January 7, 2006 (edited) Daca Ai Cap Ia-ti Altceva. merci. Edited January 7, 2006 by dreamlike Link to comment
tatabobu Posted January 9, 2006 Share Posted January 9, 2006 laurentziu83 said: ...P.S: se pare ca dracia e cea mai buna masina, ca n-a avut rechemari. Au avut pentru resoftare si cric la Golan, si pentru izolat niste cabluri la Indolenza. Link to comment
VAXXi Posted December 9, 2007 Share Posted December 9, 2007 Am scotocit si-am gasit niste pagini interesante, detaliind recall-uri auto. Chevrolet Aveo Chevrolet Aveo Sedan 2004303, 2004 On certain vehicles, the rear outboard shoulder seat belts can contact the seat-back-folding release knob during seat belt use and can twist the seat belt webbing. The twisted webbing may not fully retract into the seat belt retractor, preventing deactivation of an activated Automatic Locking Retractor (ALR) mode. The activated ALR mode prevents extracting the partially retracted webbing, which may make the seat belt unusable. Correction: Dealers will attach a seatbelt webbing guide with three screws to the back shelf panel at the outboard sides. Chevrolet Aveo 2007275, pentru modelele 2004-2005 On certain vehicles, the engine throttle may stick in the open position due to throttle body icing in temperatures near or below -20 degrees Celsius. If the throttle sticks open while the vehicle is moving, a crash could occur without prior warning. The vehicle may experience this condition even if one or both of the previous two campaign services have been performed. See recall 2005235 (GM 05521) & 2006239 (GM 06515). Correction: Dealers will replace the PCV and throttle body systems. Chevrolet Aveo 2006239, pentru modelele 2004-2005 On certain vehicles, the engine throttle may stick in the open position due to throttle body icing in temperatures near or below -20 degrees Celsius. If the throttle sticks open while the vehicle is moving, a crash could result without prior warning. Correction: Dealers will repair the PCV system update kit previously installed in recall 2005235 (GM 05521). Chevrolet Aveo 2005235, pentru modelele 2004-2005 Certain vehicles may experience throttle body icing in conditions where temperatures are near or below -20 degrees Celsius. Vehicle with this conditions could have the throttle stick open after a cold soak or they can experience a frozen throttle while driving. Correction: Dealers will install new parts that integrate with the coolant system to heat the PCV lines and avoid PCV freezing. Mai este unul, dar nu se aplica, fiind valabil doar la modelele cu motor de 1.6 litri. Toate recall-urile se pot vedea aici. Nu-s prea multe, si nici unul grav. Buna treaba. Epica Chevrolet Epica 2004304, 2004 A fault in the adaptive fuel control logic can cause certain vehicles to use air-fuel ratios during deceleration that are lean enough to cause engine stalling. Correction: Dealers will reprogram the Electronic Control Module (ECM). Chevrolet Epica 2005021, 2004 On certain vehicles, the stop lamp switch may become misadjusted if an upward force is applied to the brake pedal. The stop lamp electrical contacts in a misadjusted stop lamp switch may not open when the brake pedal is at its natural rest position, resulting in the brake lights staying illuminated continuously without service brake pedal application. Correction: Dealers will replace the stop lamp switch. Daewoo Lanos (care este totusi Cielo) Daewoo Lanos 2004350, 1999-2001 On certain vehicles, the camshaft position sensor may melt resulting in a burning smell and visible smoke, which may subsequently lead to the melting of the camshaft cover and camshaft position sensor wire harness. This could possibly cause an under hood fire. Correction: Dealers will replace the camshaft position sensor and install an additional fuse. Daewoo Lanos 2002105, 1999-2001 (nu se aplica la noi, e pentru modelele cu airbag pasager) Certain passenger vehicles fail to conform to the requirements of CMVSS no. 201, "occupant protection in interior impact." In the event of a crash in which the air bags do not deploy, there is a possibility of increased head injury to the front seat passenger should contact with the passenger side air bag cover occur. Correction: Dealers will install new energy absorbing air bag mounting brackets. Daewoo Lanos 2000021, 1999-2000 On certain vehicles, insufficient wheel bolt torque could result in wheel separation and a possible crash without prior warning. Correction: Wheel bolt torque will be increased to 120nm (88lb/ft). Daewoo Lanos 1999096, 1999 On certain vehicles, a pad located on the left hand and right hand door side impact beam was incorrectly positioned during vehicle manufacturing. The positioning of this pad is integral to the vehicle complying with the requirements of CMVSS 214 - Side Door Strength. Correction: All vehicles have had both left and right door pads re-positioned and secured in their intended position. Daewoo Lanos 2001073, 2000-2001 On certain vehicles, the ECM wiring harness which is located in the passenger footwell area may chafe against a caulked body seam due to movement of the passenger's feet and result in a short circuit to ground. There is a possibility that engine driveablity may be affected and/or the engine may stall. Correction: Extra protection will be applied to the wiring harness and an additional tie strap will be installed to reroute the ECM harness away from the body seam. Leganza Daewoo Leganza 2004350, 1999-2002 On certain vehicles, the camshaft position sensor may melt resulting in a burning smell and visible smoke, which may subsequently lead to the melting of the camshaft cover and camshaft position sensor wire harness. This could possibly cause an under hood fire. Correction: Dealers will replace the camshaft position sensor and install an additional fuse. Daewoo Leganza 2001150, 1999-2001 Certain passenger vehicles fail to comply with requirements of C.M.V.S.S. 201, "Occupant Protection in Interior Impact." These vehicles exceed the maximum allowable Head Injury Criterion value specified in the standard for passenger-side A-pillar target location. Consequently, in a crash, the front seat passenger could suffer increased head injury from contact with the passenger A pillar (forward most roof support). Correction: Dealers will install padding to the A pillar to reduce the risk of injury in a crash. Nubira Daewoo Nubira 2004350, 1999-2002 On certain vehicles, the camshaft position sensor may melt resulting in a burning smell and visible smoke, which may subsequently lead to the melting of the camshaft cover and camshaft position sensor wire harness. This could possibly cause an under hood fire. Correction: Dealers will replace the camshaft position sensor and install an additional fuse. Daewoo Nubira 2002178, 2000-2002 On certain vehicles, the outer rubber layer of the front brake flex hose may crack near the grommet. This could cause the hose to burst. Correction: Dealers will replace both front brake hoses. Alte modele Pentru alte modele, puteti cauta pe site-ul NHTSA sau Transport Canada. Mi s-a parut foarte tare ca exista recall-uri si pentru Dacia 1310 Totaluri Daewoo Lanos 5 Daewoo Leganza 2 Daewoo Nubira 2 Chevrolet Aveo 5 (desi 3 sunt repetate) Chevrolet Epica 2 Link to comment
wappi Posted December 9, 2007 Share Posted December 9, 2007 Oricum, la noi nu prea se practica schema cu rechemarile, daca ar fi fost asa trebuiau rechemate toate matizurile pentru schimbarea cel putin a amortizoarelor spate si etrierilor. Acum uitandu-ne ce recheama altii visam si noi frumos ca poate intr-o buna zi o sa fim si noi respectati ca vecinii mai europeni sau ca vecinii de peste ocean. Numai bine! Link to comment
tolin Posted December 9, 2007 Share Posted December 9, 2007 Nu aveau de ce sa schimbe etrierii la Matiz, trebuia doar sa puna piesa pe care au eliminat-o, arcul care facea sa nu mai joace placutele de frana. Link to comment
wappi Posted December 9, 2007 Share Posted December 9, 2007 Ma rog... nu imi venea exact termenul, oricum nu i-a durut capu de treburile astea, ne-au lasat pe noi sa ne descuracam... Bine ca exista daewooclub.ro Link to comment
Bimm3r Posted December 29, 2007 Share Posted December 29, 2007 Eu nu inteleg bine la Leganza care e problema. Poate cineva sa-mi traduca ? Link to comment
ovi_jer Posted December 29, 2007 Share Posted December 29, 2007 Poti sa stai linistit, a ta nu are ''camshaft position sensor'' Link to comment
hawkeye Posted February 14, 2008 Share Posted February 14, 2008 M-au sunat de la GTT ca cica au primit directiva de la GM sa verifice senzorii de parcare de la Epica. Gargara pe fata, cine stie ce or fi descoperit. Cineva cu captiva a primit vreun telefon similar? Link to comment
ToPser Posted January 15, 2010 Share Posted January 15, 2010 (edited) Opel a rechemat in service mai multe modele din gama utilitarelor Movano.Modelele produse intre 2008 si 2009 cu VIN cuprinsintre 39354877si VIN 41510147,au oproblema la sudarea scaunelor din dreapta fata. Numarul insuficient de puncte de sudura poate duce la desprinderea scaunului, in cazul unui impact ! Unele modele Volvo XC90 cu serie VIN intre 037138si 05122330,produse intre 2007si 2009,prezinta risc de erodare a conductelor servodirectiei,ce a ce poate duce la o golire brusca a instalatiei de servo si la pierdrea asistarii hidraulice a directei! Jaguar a rechemat in service modelele cu motoare de 3,0si 4,2 l pe benzina ,pentru o problema la conducta de alimentare cu carburant,ce poate duce la oprirea motorului .Exemplarele afectate au seriile VIN cuprinse intre R38497si R63047 ! Aceste defectiuni au fost semnalate la vehicule vandute in Grecia si Polonia ! Aoleu sa ma uit repede pe cartile de identitate ! ) Edited January 15, 2010 by ToPser Link to comment
Zmeul cel rau Posted January 15, 2010 Share Posted January 15, 2010 Uita-te si la GP. Si alea au fost rechemate pentru probleme la caseta de directie. Link to comment
ToPser Posted January 15, 2010 Share Posted January 15, 2010 Da si GP cu coloana de directie(parca) niste suruburi slabe ceva ,da asta e putin mai veche ! Link to comment
Zmeul cel rau Posted January 15, 2010 Share Posted January 15, 2010 Procedura e inca in desfasurare. Link to comment
Lucian M Posted January 15, 2010 Share Posted January 15, 2010 La reno au rechemat nushce Kangoo entru probleme minore la directie. Cica au fost doar 5 cazuri in lume, deci nu mi se pare deloc grav. Astept sa ma cheme si pe mine in service sa ma intrebe de zdranganeala din bord... Link to comment
VAXXi Posted January 27, 2010 Share Posted January 27, 2010 Si Toyota desfasoara un recall masiv.Toyota Temporarily Suspends Sales of Selected Vehicles Toyota’s accelerator pedal recall and suspension of sales is confined to the following Toyota Division vehicles: 2009-2010 RAV4, 2009-2010 Corolla, 2009-2010 Matrix, 2005-2010 Avalon, Certain 2007-2010 Camry,2010 Highlander, 2007-2010 Tundra, 2008-2010 Sequoia Link to comment
Axix Posted January 29, 2010 Share Posted January 29, 2010 Cea de la Cruze se pune? E pentru scoaterea comenzii de blocare totala(CB) necesara in timpul transportului. Link to comment
tolin Posted January 29, 2010 Share Posted January 29, 2010 On 1/29/2010 at 6:34 PM, Axix said: ... pentru scoaterea comenzii de blocare totala(CB) necesara in timpul transportului. Cum ai reusit sa pleci cu masina de la dealer din curte ? Link to comment
Axix Posted January 29, 2010 Share Posted January 29, 2010 Comanda o scot la predarea in servis, dar se poate activa accidental printr-o combinatie. Tocmai de asta o scot de tot din calculator. Stiu ca ai intrebat la "misto" dar poate multi nu stiu, unii colegi de-ai nostrii au ramas cu masina blocata, facand involuntar functiile de "intrare in transport". Link to comment
ToPser Posted February 26, 2010 Share Posted February 26, 2010 Se pare ca problemele Toyotei nu s-au incheiat !Computere pe roti ! Link to comment
Tommy Posted October 1, 2010 Share Posted October 1, 2010 Intre timp s-au terminat, dar anuntul unei alarme false nu mai produce audienta. http://www.portalstiri.ro/Masini/masinile_toyota_nu_aveau_probleme_la_schimbatoarele_de_viteze_3677/9/ Concluziile sprijinesc pozitia companiei Toyota si lasa fara temei foarte multe actiuni in instanta impotriva fabricantului japonez de automobile. In urma analizarii datelor privind 58 de accidente, expertii guvernamentali au conchis ca in 35 dintre cazuri, nici macar nu a existat tentativa de franare. In America insa e o moda, se pare ca toti au probleme cu franele sau cu acceleratia acolo http://www.zf.ro/auto/bmw-recheama-in-service-aproape-200-000-de-masini-de-pe-piata-americana-ca-urmare-a-unor-probleme-cu-franele-7437619 Producătorul german de maşini de lux BMW a anunţat vineri că probleme legate de sistemele de frânare au forţat compania să recheme în service 198.000 de modele BMW şi Rolls-Royce de pe piaţa americană, informează AFP. "Este o operaţiune globală şi alte ţări ar putea fi afectate", a declarat un purtător de cuvânt al companiei adăugând că numărul total al maşinilor rechemate se va ridica la 350.000. În SUA, BMW a rechemat 198.000 de unităţi din seriile 5, 6 şi 7, dar şi alte maşini produse de divizia de lux Rolls-Royce. Link to comment
Mircea Posted October 2, 2010 Share Posted October 2, 2010 Si in Ro s-a facut acest recall: http://stirileprotv.ro/stiri/eveniment/masinile-bmw-si-rolls-royce-phantom-verificate-si-in-romania.html Link to comment
Corneda Posted September 22, 2021 Share Posted September 22, 2021 Oare am vreo sansa sa il fac pe undeva sau nu merita sa ma agit? Am dat de curiozitate un mail la Opel si nu m-a bagat nimeni in seama🤪 Link to comment
Akon Posted September 22, 2021 Share Posted September 22, 2021 (edited) Trebuia schimbat contactul dar ma indoiesc ca mai face cineva asta. Vad ca si eu am : Edited September 22, 2021 by Akon Link to comment
