robert_11 Posted April 2, 2008 Share Posted April 2, 2008 L-am cumparat, insa acum nu stiu sa-l setez. Cine se pricepe, ma lamureste si pe mine va rog? Link to comment
andrei_xxl Posted April 2, 2008 Share Posted April 2, 2008 laurentziu83 said: in primele cadre ale filmarii nu apare viteza ta, ci 0km/h, apoi apare brusc viteza cu care te-au agatat. Pe baza asta, faci contestatie in instanta prin care sa ti se dovedeasca faptul ca s-a facut autotestarea Deci faza cu luatul din scurt, ca sa zic asa, e ilegala? Link to comment
Zmeul cel rau Posted April 2, 2008 Share Posted April 2, 2008 (edited) Ei la proces aduc oricum doar poze... Edited April 2, 2008 by Zmeul cel rau Link to comment
Elfu Posted April 3, 2008 Share Posted April 3, 2008 (edited) @Zmeu Daca cere sa demonstreze ca radarul si-a facut autotestarea, o sa aiba o problema cei de la rutiera doar cu pozele. Oricum eu zic ca laurentiu are 100% sanse sa castige daca s-a luat de autotestarea radarului. Pe de alta parte am un feeling ca va castiga prin neprezentare (din partea politiei). Oricum, daca castiga ar fi fraier daca nu ar face si plangere de abuz in serviciu agentului respectiv. Edited April 3, 2008 by Night Elf Link to comment
EM!L Posted April 3, 2008 Share Posted April 3, 2008 andrei_ics_ics_el said: Deci faza cu luatul din scurt, ca sa zic asa, e ilegala? Ei "e" legea, si "e" multi ) . Sigur ca e ilegala! Link to comment
Elfu Posted April 3, 2008 Share Posted April 3, 2008 (edited) Daca vedeti asa ceva pe strazi, nu va speriati ca nu sunt radare. E vorba de asta: Spike+ Spike+ is a fully integrated digital number plate reading camera incorporating both the camera and the recogniser within a single sealed enclosure. The unit comprises a monochrome CCD camera with high sensitivity in the IR, surrounded by a ring of IR LED's. Patented filter / flash technique gives suppression of headlights and bright sunlight. Field-by-field control of camera parameters allows the use of patented 'triple flash' technique to reduce problems of plate-to-plate variability. There is an optional integrated colour camera that can be set to the same focal length as the monochrome camera, or it can be set for a wider field of view. Thus an ANPR system can be set to always capture from the monochrome camera, however when lighting conditions allow, a colour overview image of the vehicle can be captured. The use of different focal lengths enables number plates to be read over a much greater range. The integrated number plate recogniser incorporates the PIPS 'AutoPlate' ANPR engine, which has been proven in many countries and states and world-wide. Patented real-time video triggering upon plate presence provides excellent plate detection. A vehicle presence trigger input is also provided for the most demanding applications, e.g. taking an overview picture of a vehicle with a missing plate. Aplicativititate la masinile de politie http://www.pipstechnology.co.uk/applicatio...p;article_id=10 Software http://www.pipstechnology.co.uk/products.p...p;article_id=36 http://www.pipstechnology.co.uk/products.p...p;article_id=37 http://www.pipstechnology.co.uk/products.p...p;article_id=38 PIPS ANPR cameras scan and record the vehicle registration numbers of every passing car. The numbers are then cross-checked against a number of databases, including the Police National Computer, the DVLA and police intelligence records. It can tell police officers within seconds whether a vehicle has been stolen, is known to be involved in a crime, or is untaxed. Even with millions of records in the database, PAGIS will return an answer in a fraction of a second. The Spike Portal receives and processes information from outstations. This information comprises: Text Data Number Plate Read, Date, Time, Location, Confidence of read JTMS™ automatically reads vehicle number plates at two or more points on the road network. Number plate data captured by ANPR at the roadside, is transmitted to a central computer system where the information is matched to calculate the exact travel times between sites. JTMS™ can be applied to a single traffic lane at just 2 locations, up to complete road networks with thousands of multiple lane measurement sites; local, regional, national or international. Masuri de securitate anti-tero cu ocazia summit-ului Nato. Edited April 3, 2008 by Night Elf Link to comment
laurentziu83 Posted April 3, 2008 Share Posted April 3, 2008 (edited) Night Elf said: @Zmeu Daca cere sa demonstreze ca radarul si-a facut autotestarea, o sa aiba o problema cei de la rutiera doar cu pozele. Oricum eu zic ca laurentiu are 100% sanse sa castige daca s-a luat de autotestarea radarului. Pe de alta parte am un feeling ca va castiga prin neprezentare (din partea politiei). Oricum, daca castiga ar fi fraier daca nu ar face si plangere de abuz in serviciu agentului respectiv. Acu pe mine ma intereseaza doar sa castig, nu stau acum sa fac plangere fata de agentul respectiv, ca n-am timp sa umblu prin tribunale. Intr-adevar, fix de autotestare m-am legat, ca am indoieli ca a fost efectuata. Edited April 3, 2008 by laurentziu83 Link to comment
Venom Posted April 4, 2008 Share Posted April 4, 2008 Asta vara treceam din bulgaria in grecia, prin vama. La un moment dat, ceva miliar face semn disperat sa opresc (inca nu iesisem din vama) si zice: mister mister, radar, radar, 1000 euro fine. L-am dat jos in 30 de secunde Link to comment
VAXXi Posted April 5, 2008 Share Posted April 5, 2008 Iliada Beltronics (ar trebui sa ma plateasca pentru cata reclama le-am facut) continua: azi era radarul pus pe Kiseleff, orientat spre Piata Victoriei ca sa prinda din spate pe cei care scapa mai mult de 60 km/h pe sectorul ala de drum cu 4 benzi si sens unic. Detectorul a inceput sa urle constant inca de la Arcul de Triumf, cu un glorios K7 la cativa metri in spatele Solenzei cu radar. La semafor erau 3 politisti de la rutiera care trageau in scuarul ala de la intersectie masinile. S-or fi speriat de incidentul cu fata moarta la trecerea de pietoni de la muzeu ? am vazut ca s-a montat semafor nou acolo. Link to comment
laurentziu83 Posted April 6, 2008 Share Posted April 6, 2008 (edited) Vad ca doar la mine in zona detectoarele sunt inutile. Mi-ar fi si rusine sa ma mai opreasca radarul setat pe constant-on. Edited April 6, 2008 by laurentziu83 Link to comment
mx81 Posted April 19, 2008 Share Posted April 19, 2008 Nici cel mai bun detector nu te scapa de probleme ! Detectorul se ia la valoarea inconstientei proprietarului , adica cit de mult vrea sa sara peste limita legala . Daca vrei un 70 in localitate si 110 afara nu iti iei scule de 2000 lei , dac vrei mai mult sari cu banul . Si apoi oricit de bun este detectorul daca esti singur pe sosea radarul cu autotestare cu tot nu face mai mult de 2 secunde , si de la 120 la 50 km/h nu ai cum sa te incadrezi . Detectorul te salveaza doar daca ai un "iepure " in fata . Link to comment
EM!L Posted April 25, 2008 Share Posted April 25, 2008 Oarecum fftopic: . Din cate stiam eu, durata de autotestare (cel putin la detectoarele ce se alfa in prezent pe masinile M.I.) se situeaza in jurul valorii de 10 secunde. Link to comment
lascarica Posted May 22, 2008 Share Posted May 22, 2008 De vreo 2 zile citesc topicul asta si sint total in aer si confuz. Vreau sa-mi cumpar un detector (pt siguranta mai ales in loc unde merg cu 60-70 max 80) pina in 4-5.5mil. Voi ce i-mi recomandati din : Cobra 9930, Bel 940-955-965 sau alt model si/sau firma? Eventual si o sursa online. Multumesc anticipat! Link to comment
VFX Posted May 22, 2008 Share Posted May 22, 2008 (edited) Bel965 din cele enumerate de tine. Sau RX65 mai bine... Edited May 22, 2008 by s0r|n3l Link to comment
Elfu Posted May 22, 2008 Share Posted May 22, 2008 RX-ul e vreo 700 RON fara factura, nu se incadreaza in buget. @lascarica Mergi pe Beltronic 965 din ce ai enumerat. Link to comment
VFX Posted May 22, 2008 Share Posted May 22, 2008 Si 965 e tot pe la 700. Eu am luat de curand un 955 la 470ron(cu factura + 24luni garantie)...am fost foarte limitat cu bugetul si trebuia sa iau ceva...am ramas fara al vechi...si parca mergeam cu ochii inchisi... Inca nu pot spune o parere despre...momentan si-a facut treaba...la un momet dat noaptea inceput sa bipaie de la brd-turn...iar politia era la piata 1mai cu fata spre Turda... Are si alarme false...dar par mult mai putine ca la cobra... Mai studiem... Link to comment
lascarica Posted May 22, 2008 Share Posted May 22, 2008 (edited) Multumesc pt atentie si raspunsuri. Daca puteti specifica si o sursa de incredere ar fi ideal. Deci conditia bugetara e 5.5 max cu tot cu transport nu toti asigura transport gratuit. Dupa cite am inteles de pe aici pina la urma din gama mai ieftina de la BEL 940 ramine cel mai bun comp. cu 955-965. Rx iese din discutie e pret prea mare pt. un buget mic Sorinel de unde ai luat la pretul asta? Edited May 22, 2008 by lascarica Link to comment
VFX Posted May 22, 2008 Share Posted May 22, 2008 Ti-am trimis pe PM...sa nu facem reclama... Link to comment
Lucian M Posted May 22, 2008 Author Share Posted May 22, 2008 Prastia mea de cobra 6060 a gasit un radar... da' in ce situatie. Eram intr-o parcare, langa Policlinica din Tg. Neamt, masina cu fata la un zid, iar pe partea soferului, tot zid. Detectorul a ramas pornit (alimentare directa de la plafoniera). Revin eu in masina (mi-a bazait doamna doctor pe la dinti) si aud detectorul piuind a radar. De la albinuta si polizor n-am eu halucinatii, dar ma rog... Ma uit in spate-dreapta, vad dupa cateva secunde trecand o masina de-a rutierei. Cei care stiu orasul inteleg locatia masinii. Rutiera venea dinspre Humulesti si a facut dreapta spre Politie, in intersectia mare Distanta de la mine la intersectie- peste 50m. Problema e alta: ce intensitate avea radaru' lui ala, de a prins detectorul meu indreptat spre zid semnalul de la o distanta mare (repet, masina politiei era initial la mai bine de 100m, inainte de trecerea de la bazar), masina fiind parcata nu cu spatele, ci perpendicular cu directia din care venea rutiera. Din punctul meu de vedere, batranul cobra si-a facut inca o data datori, gasind inca un radar. Am sa il mai tin o bucata de vreme, daca nu mi-l ia un vecin. Eu is multumit de antichitate, m-a salvat de la multe amenzi. Link to comment
laurentziu83 Posted May 22, 2008 Share Posted May 22, 2008 Ia cel mai ieftin BEL pe care il gasesti...parerea mea. Eu dupa un an si ceva de Bel 795, nu mi-as mai lua altceva. Eu merg cu el montat si prin oras si pot sa zic ca numai in ultima luna m-a salvat de vreo 2 radare in urban. In afara, cand incepe sa bipaie, clar e radar. Daca e instant-on, aici detectorul oricum nu te mai ajuta decat ca sa stii daca faci contestatie sau nu. Eu nu as fi avut curajul sa fac contestatie daca nu as fi avut detectorul montat si pornit in acele momente. Link to comment
lascarica Posted May 23, 2008 Share Posted May 23, 2008 Baieti tocmai am primit o veste buna (financiara) si ma pot "arunca" la ceva mai scump. Ce ati alege intre 995 si RX 65 sint cam la acelasi pret? Intrebare stupida nu? 995 cica are flash upgradabil la RX nu zice nimic. Cei care au din astea pls dati-va cu parerea. Miine dimineata sint in Bucuresti si vreau sa cumpar unul. Ziceti un magazin mai aproape de intercontinental (sa nu ma ratacesc draq prin Buc. ) de unde as putea sa cumpar. Multam fain pt. ajutor. Link to comment
Elfu Posted May 23, 2008 Share Posted May 23, 2008 Sfatul meu e sa iei RX-ul. E ceva mai linistit la alarmele false. Daca vrei fara factura iti dau eu PM cu datele persoanei de la care am luat, sigilat cu 710 RON. Link to comment
VFX Posted May 23, 2008 Share Posted May 23, 2008 Side la mine...tot RX... nu stiu f. multe despre el, dar am auzit lucruri bune... Link to comment
Elfu Posted May 23, 2008 Share Posted May 23, 2008 Daca iei RX, seteaza-l pe Bands mode si inchide toate benzile mai putin K band. Laser il lasi pe on doar daca ai drum pe la sacele, sau unde e radarul ala laser fix. Link to comment
